POV-Ray : Newsgroups : povray.general : Round-opening hole Server Time
16 Apr 2026 14:49:08 EDT (-0400)
  Round-opening hole (Message 1 to 8 of 8)
Subject: Round-opening hole
Date: 20 Jan 2005 17:16:22
Message: <41f02db6$1@news.povray.org>
I have a box with a hole in it. The whole was made by differencing a
Round_Box so that the corners were nicer than the traditional square
corners. However the opening of the hole still has hard square edges:
___      __
    |____|
How would you go about rounding them?
___      __
    |____|
I've thrown away my first idea, which was to put cylinders around the
four sides of the box (first subtracting the radius as a box) but that
only works along the sides of the hole. I need the corners to be nicely
rounded too.
Any help and suggestions would be greatly appreciated.
Subject: Re: Round-opening hole
Date: 20 Jan 2005 17:36:23
Message: <41f03267@news.povray.org>
> rounded too.
You've got the right idea. The corners are harder, but can be rounded off
using a torus with a minor and major radius both equal to the
roundoff-radius. Cut out one quarter of the torus by differencing (or
intersecting with) two planes. This just leaves a little bit of space
*behind* the torus which can be filled in by a small box differenced by a
cylinder.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Jan 2005 02:51:11
Message: <41f0b46f$1@news.povray.org>
I would try this, maybe in a macro:
First cut out the hole like you did
> ___      __
>    |____|
Then cut out a hole not so deep but with a bigger radius
  __          __
    |_      _|
      |____|
The last thing is placing a torus that way, that it fills the edges. The
major radius for the torus is the radius for the bigger hole and the
minor radius is the radius for the first hole you made.
___ _      _ ___
  | |_\    /_| |
  \___|    |___/<-- this is the torus
      |____|
I hope this is clear enough.
I also could post some code if you wish...
So long,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 21 Jan 2005 03:07:19
Message: <41f0b837@news.povray.org>
Bonsai wrote:
Something thats incorrect because he had not enough coffee, yet. ;-)
The radius for the minor radius is the difference between the radii of
the two holes.
Here is a short example scene:
#default {
   texture { pigment {color rgb 1}}
// create a regular point light source
light_source {
     <20, 40, -20>
     color rgb <1,1,1>    // light's color
// perspective (default) camera
   location  <10, 10, 0>
   look_at   <0.0, 5.0,  0.0>
merge {
     difference {
         box { <-5, -5, -5>, < 5,  5,  5>}
         cylinder { <0, 0, 0>, <0, 6, 0>, 2 }
         cylinder { <0, 4, 0>, <0, 6, 0>, 3 }
     torus { 3, 1 translate <0, 4, 0>}
Hope that helps...
So long,
Bonsai
        www.b0n541.net
Date: 21 Jan 2005 12:02:36
Message: <41f135ac$1@news.povray.org>
> ___      __
>    |____|
> ___      __
>    |____|
> rounded too.
I think the keyword you are looking for here is: *lathe*
Maurice
Date: 21 Jan 2005 12:58:05
Message: <0UxuKBAI1T8BFwIF@econym.demon.co.uk>
>> ___      __
>>    |____|
>> ___      __
>>    |____|
>> rounded too.
Wouldn't that tend to make a cylindrical hole rather than a rounded
square hole?
Mike Williams
Gentleman of Leisure
Date: 21 Jan 2005 13:26:00
Message: <41f14938$1@news.povray.org>
> square hole?
Ah yes. How stupid of me. <blush>
Maurice
Date: 21 Jan 2005 18:47:01
Message: <41f19475$1@news.povray.org>
>> square hole?
But you could use the lathe the difference out the rounded corners and
lip, no?
