POV-Ray : Newsgroups : povray.general : Portraying movement Server Time
4 Mar 2026 00:15:46 EST (-0500)
  Portraying movement (Message 1 to 10 of 16)
Subject: Portraying movement
Date: 7 Nov 2002 18:28:36
Message: <3dcaf724$1@news.povray.org>
Hello everyone
I'm working on an image for the current IRTC stills round 'Frozen
Moment', and I'd like to indicate somehow that a particular object in
the scene is moving. Now, motion blur would probably be ideal for this,
but I'm using POV-Ray 3.5 and I'm not currently aware of any motion blur
patches for it. I could try moving to MegaPOV 0.7, but I'm not sure how
much of the scene I'd have to alter to make it compatible, and I don't
really want to have to go down that route if I can avoid it as it's
needless extra work.
So, are there any other ways to indicate movement of an object?
Unfortunately it's not one that has anything that flaps or trails behind
it. Or can one simulate motion blur with any reasonable expectation of a
half-decent effect?
Thanks
Subject: Re: Portraying movement
Date: 7 Nov 2002 19:35:32
Message: <chrishuff-020725.19353207112002@netplex.aussie.org>
In article <3dcaf724$1@news.povray.org>,
> half-decent effect?
You could imitate it by using multiple transparent copies of the object,
which is how the patch actually did its work. I think transmit will give
the most correct results in this case. The original patch kind of
treated the body of the motion blur statement as the body of a loop, and
parsed it several times with different clock values. Just make sure to
set the max_trace_level high enough...
The only other way I can think of would be to somehow indicate the
object's motion by its effect on the rest of the scene, a rubber ball
with a falling stack of cans behind it for example. You really need
motion blur for a realistic effect...
http://tag.povray.org/
Date: 8 Nov 2002 05:17:45
Message: <3dcb8f48@news.povray.org>
Christopher James Huff wrote:
> You really need motion blur for a realistic effect...
  Not in a perfectly "frozen moment"...  ;)
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 8 Nov 2002 05:40:07
Message: <du4nsusmh28m57s7h7e3aoeao5houbr6p8@4ax.com>
Depending on the render times, you can render multiple copies of your
scene with the object moving a little and then average them together.
The averaging part can be done in POV using image_maps and the average
pattern, so you can stay within the rules of the IIRC.
You can also only render the part of the scene where your object
appears, then use some clever (function-based, most likely) texturing
to paste it into POV - it all depends on your render times.
Peter Popov ICQ : 15002700
Date: 8 Nov 2002 06:22:10
Message: <3dcb9e62@news.povray.org>
Why not just post a screen shot of POV, with the 0 pph included? ;)
Tim Cook
Version: 3.12
Date: 8 Nov 2002 09:54:30
Message: <3dcbd026@news.povray.org>
  Wrong. The patch did not add any transparency anywhere. It simply traced
the same object several times, transforming the object with the given
transformations at each sample, and then averaged the results.
  This gives a lot more realistic result. Using semitransparent objects
will give you unrealistic results. For instance, using semitransparent
objects will make the interior of the object partially visible, which is
usually very unwanted.
Date: 8 Nov 2002 10:08:05
Message: <chrishuff-661DA1.10080408112002@netplex.aussie.org>
In article <3dcbd026@news.povray.org>, Warp <war### [at] tagpovrayorg>
By "how the patch actually did its work" I was referring to the multiple
copies part, which *is* what the patch did. It didn't trace one object
multiple times, it traced multiple copies of the object.
Which is why I said "most correct" results instead of "correct" results.
Maybe I didn't make it clear enough, but this is just a way to imitate
the blur effect without a patch.
Date: 8 Nov 2002 10:53:02
Message: <3dcbddde@news.povray.org>
  The practical difference being...?-)
  What I meant was that it traces the object as-is, without modifying the
surface properties of the object (eg. making it partially transparent).
  It's just that from your post one could get the idea that the suggested
solution is exactly what the MegaPov patch did but just internally and a
bit faster. It's not like that.
Date: 8 Nov 2002 12:18:07
Message: <chrishuff-9A353E.12175708112002@netplex.aussie.org>
In article <3dcbddde@news.povray.org>, Warp <war### [at] tagpovrayorg>
You could use it as a loop, and do other stuff besides simply
transforming the object. For example, you could make an isosurface
changing shape or a moving texture have motion blur, or even completely
change the type of object or remove some "copies" entirely. In normal
usage there was little difference, though.
Right, I didn't mean to imply that it did.
Hmm...I didn't intend that. Sorry.
Date: 8 Nov 2002 12:46:30
Message: <3dcbf876$3@news.povray.org>
Use those elements of composition that imply movement.   An automobile
viewed head on in an orthographic projection in the exact center of the
image does **not** imply movement.
Avoid tacking blurring special effects.
"Matt Walton" <mat### [at] alledoracouk> wrote in message
news:3dcaf724$1@news.povray.org...
