POV-Ray : Newsgroups : povray.general : Ior mapping? Server Time
4 Mar 2026 16:36:18 EST (-0500)
  Ior mapping? (Message 1 to 9 of 9)
Subject: Ior mapping?
Date: 11 Jun 2002 07:56:14
Message: <3d05e55e$1@news.povray.org>
I was thinking about this the other night and am not sure how possible or
easy to do it would be.  Would it be possible to make a patched POV that
could use 'ior mapping', i.e., ior values could use something like a density
map for varying ior values within a material.  I was thinking this could
come in handy in some different situations such as mirages or that
appearance you get looking at hot pavement (I can't remember what to call
it) or for modeling of non-homogeneous materials.
I'm not much of a POV programmer myself so I don't think I would be up to
the task, but perhaps someone else is interested in the idea, if it's even
possible.
-tgq
Subject: Re: Ior mapping?
Date: 11 Jun 2002 08:08:51
Message: <3D05E853.50538914@gmx.de>
> possible.
http://www.students.tut.fi/~warp/povQandT/languageQandT.html#variableior
Last updated 02 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 11 Jun 2002 08:23:09
Message: <3d05ebad$1@news.povray.org>
Thanks, I think :(
I guess it makes sense that it would be very difficult to solve. Back to the
drawing board (or rendering screen rather)
-tgq
Date: 11 Jun 2002 09:44:05
Message: <3D05FEA5.AEE7DF3F@my-deja.com>
> possible.
> -tgq
I haven't tried it, but you might be able to get something like it with
a bunch of clear cylinders between you and the mirage, axis of cylinder
perpendicular (or not quite ?) to the camera, different iors in each
cylinder.
Tom A.
The problem was that Apostles were hard to come by and, worse, they had
a nasty habit of getting crucified or beheaded. -Larry Nolte
Deja mail is gone.  Look for me at raugost at yahoo . com
Date: 11 Jun 2002 10:54:00
Message: <3d060f08@news.povray.org>
> cylinder.
  Remember to raise max_trace_level accordingly and be prepared for a
really long render... ;)
Date: 11 Jun 2002 16:55:07
Message: <3d0663ab@news.povray.org>
You know, it's not really impossible. It would just require some sort of
approximated integration, Euler's method at the least. I won't argue that it
would be easy to do though; that depends on how POV-Ray works internally.
 - Slime
[ http://www.slimeland.com/ ]
Date: 11 Jun 2002 17:05:14
Message: <3d06660a$1@news.povray.org>
> require some sort of approximated integration,
Well, I can't say that I know what I'm talking about, but I think that
even the slightest calculation inaccuracies would lead to big visible
differences from pixel to pixel thus giving a very grainy look. Smooth
variable ior would require render times that would make smooth focal
blur seem like nothing in comparison. ...I think... :)
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 11 Jun 2002 17:09:56
Message: <3d066724@news.povray.org>
You're probably right, though it would depend on *how* variable the ior was.
f_noise3d scaled very small would be innacurate, but something like a
gradient scaled very large would be much more accurate.
 - Slime
Subject: Heat Waves (was Re: Ior mapping?)
Date: 12 Jul 2002 15:14:23
Message: <3D2F2A8F.C505A999@my-deja.com>
> > cylinder.
> --//  - Warp -
I just posted an animation on the binaries.animation group that uses an
isofunction to generate heat waves.
Since the question was originally posted here, I thought I'd post a
pointer to it.
And using the single object (admittedly an isosurface) wasn't too bad -
took about 30 seconds per frame, including the 5-10 seconds to parse the
blobman.
Tom A.
Avon: I'm going to reprogram this computer.
Jenna: It still won't make you likable. - Blake 7
