POV-Ray : Newsgroups : povray.general : Brick wall with height field Server Time
23 Aug 2025 20:06:40 EDT (-0400)
  Brick wall with height field (Message 1 to 7 of 7)
Subject: Brick wall with height field
Date: 22 Jul 2001 13:51:38
Message: <3B5B1346.88C002EC@pp.htv.fi>
I made a tileable hf from a Marlin Studios sample texture. First it didn't
work so good because of the internal shading of the texture map. When
I removed the shadind and added some dirt to distract the eye the result
was quite good :) Take a look.
http://www.pp.htv.fi/kkivisal/brick.htm
_____________
Kari Kivisalo
Subject: Re: Brick wall with height field
Date: 22 Jul 2001 15:13:11
Message: <Xns90E690B39BDA3revbob@127.0.0.1>
The kindly Rev. overheard Kari Kivisalo <kki### [at] pphtvfi> saying
on 22 Jul 2001:
> didn't work so good because of the internal shading of the texture
> map. When I removed the shadind and added some dirt to distract the
> eye the result was quite good :) Take a look.
It is indeed.  Love the tree, btw -- did it take forever to render with
that invisible tree in there?
Rev. Bob "Bob" Crispen
crispen at hiwaay dot net
Let me tell you what else is in trouble here: the Internet. In the
end, the Internet itself will not be able to survive if it becomes
a haven for illegal activity. - Edgar Bronfman
Date: 22 Jul 2001 15:42:00
Message: <3B5B2D2C.653CD8C4@pp.htv.fi>
It would take if I render with area_light and 3D tree model. To make it
faster I use a blank png with a tree silhouette in alpha channel mapped
to a pair of triangles. For soft shadows I blurred the alpha chanel in
Photoshop, much faster and better results than with area_light. It took
about 5 minutes on 1GHz Athlon.
http://www.pp.htv.fi/kkivisal/tree_alpha.jpg
_____________
Kari Kivisalo
Date: 22 Jul 2001 17:19:30
Message: <MPG.15c561ff42c2603e989816@NEWS.POVRAY.ORG>
In article <3B5B1346.88C002EC@pp.htv.fi>, Kari Kivisalo says...
> _____________
> Kari Kivisalo
This is great: could you modify it to take all kinds of bricks?
Regards,  Sander
Date: 23 Jul 2001 12:35:53
Message: <3B5C52D5.8400B3EF@gmx.de>
That looks good, but it will only work on such fairly 'nice' textures with
mostly orthogonal lighing and not very deep gaps between the stones.
Date: 24 Jul 2001 01:45:08
Message: <3B5D0C09.B094EB1A@pp.htv.fi>
Removing internal shadind doesn't just apply to bimaterial? textures.
All kinds of textures can be processed to reduce the internal shadind but
multiple lighten layers doesn't necessarily work on every texture. The only
requirement seems to be that the illumination on the surface is (close to)
monochromatic, the number of light sources doesn't matter, in fact it's
better to have multiple sources. If Photoshop magic doesn't work I can
always use graphics tablet to edit the tricky parts.
I brought this up because I haven't seen this discussed before. Most of the
textures have limited use because of the shadind. I think Strata sells
textures without internal shadind with hand crafted bump and specularity
maps included.
The ideal texture would be recorded with 48 bit color laser scanner which
also records the geometry. Distortions from surface geometry would be
removed using the large scale 3D data. The small scale 3D data goes to bump
map. I'm not sure how one would record the specularity map but I'm sure
there is a solution. Transparency maps would be nice too. Quite expensive
though.
_____________
Kari Kivisalo
Date: 26 Jul 2001 22:05:59
Message: <3b60cc87$1@news.povray.org>
"Kari Kivisalo" <kki### [at] pphtvfi> wrote in message
news:3B5D0C09.B094EB1A@pp.htv.fi...
with
only
Could you outline what processes are used to do this?
I don't have Photoshop (GIMP, actually) but was hoping I could maybe learn
the basic premise so it could be applied to other paint programs.
Thanks,
Darcy
