POV-Ray : Newsgroups : povray.general : height field object of new type Server Time
25 Apr 2026 15:11:30 EDT (-0400)
  height field object of new type (Message 1 to 10 of 15)
Subject: height field object of new type
Date: 27 Aug 2000 15:59:14
Message: <39A97366.15742219@ij.net>
I haven't been reading here in months so perhaps I am being repetative.
	How about a type that is not image related?
	It would be specified simply by
	height_field {
		RAW { length, width, point 1, point 2, ...}
	Reason: (See 'concept to visualization' and '... II' in binaries) This
is related to visualizing z(x,y).
	I first implemented a visualization with a mesh save that generated 19M
data files, took forever and would crash a linux graphics terminal.
	It was suggested I use a height field so I had to hack an image file
format.
	Why should I or anyone have to hack an image file format? Not having
stared at the source files I assume all it is doing is extracting the
above data in the first place. Why not simply a format to read it
directly?
	POV is directly an aid to visualization of molecules in chemistry. This
can make POV a direct aid to the visualization of math in science and
engineering without the need to do image file hacks.
Remember, if the conspiracy isn't vast
it isn't right wing.
	-- The Iron Webmaster, 55
Subject: Re: height field object of new type
Date: 27 Aug 2000 16:25:13
Message: <chrishuff-661D99.15264227082000@news.povray.org>
In article <39A97366.15742219@ij.net>, matt giwer <jul### [at] ijnet>
> 	height_field {
...snip...
I think a better solution would be to just add a new image type, so you
wouldn't be limited to height fields, but could use it in media density,
image/texture maps, isosurfaces, etc. It is a good suggestion, though.
Some of the image formats useable by POV are very simple though...some
only slightly more complex than this.
Christopher James Huff
Date: 27 Aug 2000 16:32:38
Message: <39A97B28.6307E7A1@schunter.etc.tu-bs.de>
>         height_field {
Looks nearly identical to a pgm file, but what format did you intend for the
"point1, ..." ?
IMO, the advantage of Image files for this purpose is mainly the small filesize
and fast parsing due to binary format, and the possibility to edit them in
regular image manipulation programs.
Your idea is surely quite interesting for small heightfields, but in most cases
I would prefer an image file format.  You can always use pgm, if you want an
ascii file.
Date: 27 Aug 2000 16:37:39
Message: <8F9DE3567seed7@204.213.191.228>
How different would it be from the "i_dat3d" library with data_2d_1 or
data_2d_3, if at all ?
Ingo
Date: 27 Aug 2000 16:53:51
Message: <chrishuff-3E493F.15552127082000@news.povray.org>
In article <8F9DE3567seed7@204.213.191.228>, ing### [at] homenl (ingo)
There would be very little difference...actually, I think this and other
3D voxel formats would be useful additions to the readable file formats.
If they could be used in pigments, it would eliminate the need for
specialized isosurface functions and provide more flexible textureing
options.
Date: 27 Aug 2000 17:09:31
Message: <39A983CE.351F4573@schunter.etc.tu-bs.de>
> options.
If i understand things right they can be used in pigments although i never tried
it.
BTW, what's the difference between the 'i_dat3d' stuff and a density_file /
image_map pigment function except the syntax ? maybe speed ? I just saw that you
can also use df3 files for those functions and found everything quite
irritating.
Date: 27 Aug 2000 17:25:09
Message: <chrishuff-A506EC.16263927082000@news.povray.org>
In article <39A983CE.351F4573@schunter.etc.tu-bs.de>,
> never tried it.
They can be used as function patterns in a pigment, but I don't think
they can be used directly in a pigment.
> density_file / image_map pigment function except the syntax ? maybe
> speed ? I just saw that you can also use df3 files for those
> functions and found everything quite irritating.
I think the i_dat3d format allows for colors, while df3 only stores
8-bit grayscale. And the i_dat3d *function* can read df3 files, but not
the other way around.
If a 3D image map was allowed, it would solve some of the problems with
mapping image maps without obvious stretching, tiling, or deformations.
The memory use would skyrocket, though...3D bitmaps are big. And there
currently doesn't seem to be much software that supports them, though I
plan to write a couple Mac programs...
Date: 27 Aug 2000 17:28:24
Message: <39A9884D.2F8F8B1B@ij.net>
> >         height_field {
> "point1, ..." ?
	Whatever makes the POV team programmers happy. Any user who can write a
program to create the file can do any scaling required. I'd guess 0-255
would be the least effort since that is most commonly what it being
extracted from image files. 64k would be desirable but since this is for
visualization not measurement I don't see a pressing need for it.
	It could also be an external data file RAW "filename.ext"
> ascii file.
	What I find I have to do is the intermediary step of creating the image
file for POV so that POV can take the same numbers right back out of it.
	As for size, in my first attempt at this, it is 257x257 + 60 for the
TARGA format. The time is trivial on a PII/300.
"I'm going to find that damned butterfly and kill it."
Attributed to a Florida resident after hurricane Andrew.
	--	The Iron Webmaster, 50
Date: 27 Aug 2000 17:36:28
Message: <39A98A1E.990B6849@schunter.etc.tu-bs.de>
> > never tried it.
That's what i meant.
I agree, the color aspect really seems quite useful.
Date: 27 Aug 2000 22:20:45
Message: <39a9cc7d$1@news.povray.org>
"matt giwer" <jul### [at] ijnet> wrote...
You could try using MegaPov's mesh2 - it uses less space to store the same
data.
> directly?
If you're getting your data from some sort of pattern (such as an
iso-function), then you could use the "pattern" image type in MegaPov.  It
will generate image data internally from a pigment.
You could also use the iso-function directly in an isosurface, though the
render time may be slower that way.
-Nathan
