![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Someone once posted here that you could make a bspline tube using spheres &
cylinders.
Is this how it should be done:
cylinder {vectorA, vectorB, radius} sphere {vectorB, radius}
cylinder {vectorB, vectorC, radius} sphere {vectorC, radius}
cylinder {vectorC, vectorD, radius} sphere {vectorD, radius}
where the radius is constant throughout, and the sphere sits at each 'joint'
I tried it this way and it seems the radius of the sphere was slightly too
big.
Mike
mwe### [at] sciti com
www.geocities.com/mikepweber
Don't forget about Santee Schools Family Email Newsletter Sign Up
http://www.santee.k12.ca.us/family/emails.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Weber <mwe### [at] sciti com> wrote:
: I tried it this way and it seems the radius of the sphere was slightly too
: big.
Be sure that your primitives are not scaled too small. There might be
accuracy problems with extremely small values.
It might also be just an optical illusion...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> cylinders.
I don't think so. You could only do a linear spline in this way, but not a
bspline. A bspline could be approximated with sections of torii, but it's a lot
of work. I suggest you use the sphere_sweep object included in Megapov, IIRC it
has a bspline type.
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I didn't know there was difference between a bspline and a spline. I'm
developing this for my dll plug-in for moray - so using Megapov isn't an
option.
Margus Ramst <mar### [at] peak edu ee> wrote in message
news:3901FC0C.33DC51D8@peak.edu.ee...
spheres &
> > cylinders.
a lot
IIRC it
> has a bspline type.
> Margus Ramst
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Margus Ramst <mar### [at] peak edu ee> wrote:
: I don't think so. You could only do a linear spline in this way, but not a
: bspline.
But if the segments are short enough, it's a good approximation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
They would have to be very short indeed for a good approximation, especially if
the spline is significantly convoluted.
Margus Ramst
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 22 Apr 2000 22:22:52 +0300, Margus Ramst wrote:
>> cylinders.
>of work.
Fortunately, it's work nobody has to do. See my webpage at the URL
below.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
These are my opinions. I do NOT speak for the POV-Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> cylinders.
'joint'
> big.
This method should work quite well in standard POV-Ray, provided you use
enough segments to mask the straightness of the cylinders at the desired
rendering resolution. If your spheres seem to be larger than the cylinders,
perhaps you're experiencing precision errors (depending on the radius you
are using)?
Other approximations you can use include cones and spheres (for a pipe with
a varying radius), torii segments as mentioned, or blobs. My own Spline
Macro File offers all these options, but works with interpolating, rather
than approximating, splines. The second page of the tutorial/download site
(http://www.geocities.com/ccolefax/spline) shows renderings of the various
options.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When using cylinders+spheres to simulate a curve, a shading artifact can
(usually) be clearly seen.
This is caused because altough the surface is smooth (it hasn't
sharp edges), the change of the curvature of the surface isn't. The
curvature changes abruptly: First it's straight, then it's spherical
and the again straight. This causes those shading artifacts seen in
the image (ie. the shading starts to change too abruptly).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
