![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have been putting a perspective grid in my scene that floats just clear of
the floor.
I use it as a visual measuring tool in the final image.
Currently I have used a grid composed of small cylinders but find that the
processing time is substantial and I am looking for an alternate idea.
Has anybody made a similar grid?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the floor.
You might try a crossing gradient on a very thin box instead.
Something untested like this:
box { -1,1
pigment { gradient x
color_map {
[.45 rgbf 1][.45 rgb 1][.55 rgb 1][.55 rgbf 1]
scale .1
finish { ambient 1 diffuse 0 }
pigment { gradient z
color_map {
scale .1
finish { ambient 1.5 diffuse 0 }
scale <20,.1,20>
Ken Tyler - 1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the floor.
I haven't, but if I were to do one, I'd use a plane with a gradient
layered texture, like:
gradient x
pigment_map {
[ 0.9 color rgbf 0 transmit 1 ]
[ 0.9 color Blue ]
gradient z
color_map {
[ 0.9 color Blue ]
Jerome
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would recommend a thin box instead of a plane because the bounding is more
efficient and they render faster.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You're right, but then I would use a very *thick* hollow box instead
(btw the plane should be hollow too). It should be thick enough so that
the bottom edge is below everything in the scene. A thin box would
increase the trace level (and therefore the render time) a lot...
Jerome
* Then do it. *
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 09 Nov 1999 12:24:15 -0800, "Jerome M. BERGER"
> Jerome
Not if the thickness is 0, like box { <-1000,0,-1000>, <1000,0,1000> }
which, though odd, is perfectly legal.
Peter Popov
ICQ: 15002700
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Jerome
Thanks Peter, I was just going to bring that up. It basicaly will make a box
with a thickness the same as a triangle or a disk object.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I didn't know you could do that... Doesn't it raise coincident surface
problems, though? Or does POV handle it in a specific way?
Jerome
* Then do it. *
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Jerome
It handles it just like a triangle with no problems with coincident surfaces.
Renders much faster than a plane does too. Try it you'll like it :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually it was you who taught me this, so thank you too :)
Peter Popov
ICQ: 15002700
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
