POV-Ray : Newsgroups : povray.general : Perspective Grid Server Time
16 Jan 2026 19:14:29 EST (-0500)
  Perspective Grid (Message 1 to 10 of 11)
Subject: Perspective Grid
Date: 9 Nov 1999 13:51:27
Message: <38286d2f@news.povray.org>
I have been putting a perspective grid in my scene that floats just clear of
the floor.
I use it as a visual measuring tool in the final image.
Currently I have used a grid composed of small cylinders but find that the
processing time is substantial and I am looking for an alternate idea.
Has anybody made a similar grid?
Subject: Re: Perspective Grid
Date: 9 Nov 1999 14:10:11
Message: <38287192.23606D41@pacbell.net>
> the floor.
You might try a crossing gradient on a very thin box instead.
Something untested like this:
       box { -1,1
   pigment { gradient x
 color_map {
             [.45 rgbf 1][.45 rgb 1][.55 rgb 1][.55 rgbf 1]
             scale .1
    finish { ambient 1 diffuse 0 }
   pigment { gradient z
 color_map {
             scale .1
    finish { ambient 1.5 diffuse 0 }
             scale <20,.1,20>
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 9 Nov 1999 14:23:54
Message: <382874A4.6BE6D50C@enst.fr>
> the floor.
	I haven't, but if I were to do one, I'd use a plane with a gradient
layered texture, like:
    gradient x
    pigment_map {
      [ 0.9 color rgbf 0 transmit 1 ]
      [ 0.9 color Blue ]
    gradient z
    color_map {
      [ 0.9 color Blue ]
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 9 Nov 1999 14:32:41
Message: <382876DB.E22C3A32@pacbell.net>
I would recommend a thin box instead of a plane because the bounding is more
efficient and they render faster.
Date: 9 Nov 1999 15:24:58
Message: <382882EF.322CB715@enst.fr>
	You're right, but then I would use a very *thick* hollow box instead
(btw the plane should be hollow too). It should be thick enough so that
the bottom edge is below everything in the scene. A thin box would
increase the trace level (and therefore the render time) a lot...
		Jerome
* Then do it.                 *
Date: 9 Nov 1999 16:10:27
Message: <kY0oOExoUkbU8OWC7Mkj3vOy=ksC@4ax.com>
On Tue, 09 Nov 1999 12:24:15 -0800, "Jerome M. BERGER"
>		Jerome
Not if the thickness is 0, like box { <-1000,0,-1000>, <1000,0,1000> }
which, though odd, is perfectly legal.
Peter Popov
ICQ: 15002700
Date: 9 Nov 1999 16:19:10
Message: <38288FD1.3A19238@pacbell.net>
> >               Jerome
Thanks Peter, I was just going to bring that up. It basicaly will make a box
with a thickness the same as a triangle or a disk object.
Date: 9 Nov 1999 16:28:42
Message: <382891E3.BF860F4C@enst.fr>
	I didn't know you could do that... Doesn't it raise coincident surface
problems, though? Or does POV handle it in a specific way?
		Jerome
* Then do it.                 *
Date: 9 Nov 1999 16:35:26
Message: <382893A1.785B40F8@pacbell.net>
>                 Jerome
It handles it just like a triangle with no problems with coincident surfaces.
Renders much faster than a plane does too. Try it you'll like it :)
Date: 9 Nov 1999 18:18:56
Message: <xqsoOCslM2Ip9SCU95TUiIa12Ucc@4ax.com>
Actually it was you who taught me this, so thank you too :)
Peter Popov
ICQ: 15002700
