Did I see somewhere that there was a 3D noise function that could be
used in superpatch patterns?
This wasn't in the docs.
Perhaps you refer to noise3d()? Maybe it can be used like this:
#declare Bozo = function {pigment {bozo color_map {[0 rgb 0][1 rgb 1]}}}
box {5,-5 pigment {function {Bozo(x,y,z)+noise3d(x,y,z)}}} ? Haven't
tried it yet, I'm just asuming.
This would work:
pigment{ function{ noise3d(x,y,z) } }
And this is fun, heh heh heh:
pigment{function
abs((noise3d(x*2,y*4,z*4)*.875)&(noise3d(x*4,y*2,z*4)*.875)&(noise3d(x*4,y*4,z*2)*.875))
poly_wave}
Samuel Benge
E-Mail: STB### [at] aol com
Website: http://members.aol.com/stbenge
>This would work:
True, but I thought he might like something more complex. Oh, well, maybe
you're right and I should have just put in the pure noise.
>pigment{function
4,z*2)*.875))
>poly_wave}
Did you just make that up? =)
What happened to the part of your tutorial where you say that you can blob 2
torii? How do you do that? I want to do boxes and spheres right now.
How about...
F=(X^2+Y^2+Z^2+2*Y-1)*((X^2+Y^2+Z^2-2*Y-1)^2-8*Z^2)+16*X*Z*(X^2+Y^2+Z^2-2*Y-
1)
> >pigment{function
> 4,z*2)*.875))
> >poly_wave}
Not just last night, but many nights ago. I was trying to make a fast-rendering
texture that simulated the effect that crackle and granite has, that is, the
"partitions" that make those pigments so neat.
> torii?
It's not made yet. I need to find a free weekend in order to make more
tutorials.
Well, my brief description is to make cubes and spheres using functions, and
adding them together using multiplication symbols. Each piece must be inside of
brackets ( ). So you would do something like this:
isosurface{
function (x^2+y^2+z^2)*(abs(x)+abs(y)+abs(z))
threshold 1 sign 1
pigment{rgb 1}
finish{phong 1}
The first part is a sphere, the second, a cube. I will get more in-depth in that
section of the tutorial. Have fun, I hope that was enough info to get you
experimenting.
Samuel Benge
Looks useful as a wood pigment.
Lance Birch wrote:
> How about...
> 1)
Samuel Benge
In article <37f15de5@news.povray.org>, "TonyB"
I'm getting an error when I use this (float factor expected but pigment
found instead). I'm using the Smellenbergh Unofficial Mac port. Is this a
newer feature, or is there a minor typo I'm not seeing?
Jerry
It's a newer feature, and it's only in the superpatch. Unfortunately, nobody
has yet succeeded in building a Mac version of the superpatch. :(
Fortunately, you can still do a lot with noise3d without using bozo (which
is practically noise3d anyway.) See my recent posting in
povray.text.scene-files for an isosurface-based box with a noisy surface.
The Unofficial has the important ones, for the rest I'm willing to wait
until 3.5 (will this new version of isosurface be in 3.5?)
It wasn't actually bozo I wanted, but the ability to use patterns in
general. Does this feature work to actually create isosurface objects as
well? In other words, does this allow us to use patterns to deform
isosurface objects instead of, but identical to, what 'normal' patterns
fake?
Jerry
>fake?
Ah, well in that case I can't help you much. I'll see what I can do about
getting it in 3.5, but it's not there yet either. I've just discovered
a whole pile of weird parser behavior in the function code in the superpatch
that probably also exists in 3.5 so it looks like I'll be up to my elbows in
it anyway and I might as well try to re-add the pigment-function stuff while
I'm in there. No guarantees, though.
I've found these two things wrong with superpatch code and was wondering
if someone might want to confirm that they're not new in my version:
- Functions don't like having vector components in them. So this doesn't
parse correctly, complaining about getting a vector where it wanted a
float:
#declare myvec=<1,2,3>;
function { myvec.x*x+myvec.y*y+myvec.z*z }
- Macros with functions in them don't do well at all. When you parse this:
#declare c1=<-2,-1,-3>;
#macro testfunction(xx,yy,zz)
function {xx*x+yy*y+zz*z}
isosurface {
function {testfunction( 1,2,3 ) }
It complains about testfunction, because it doesn't understand this usage
of a macro. Worse yet, if you then try to reparse you get an error on the
#declare line because a global variable didn't get reset before the error.
