POV-Ray : Newsgroups : povray.general : Tiled Background Images... Server Time
17 Jan 2026 12:21:42 EST (-0500)
  Tiled Background Images... (Message 1 to 9 of 9)
Subject: Tiled Background Images...
Date: 13 Jun 1999 01:48:54
Message: <376346DC.4B9F50C@usa.net>
Greetings,
  Can SOMEONE please help me???  I'm looking for info on how to make
seamless tiled images, using Pov-Ray to render them....anyone know where
I can find this info???  I thought I once found it on a web-site or in
the help file, but alas, that was several months ago, and I've forgotten
where I read that information, or if I even did in the first
place...please help if you can..:)
John Shadow
JSh### [at] usanet
Subject: Re: Tiled Background Images...
Date: 13 Jun 1999 02:05:22
Message: <376449df.87192908@news.povray.org>
On Sun, 13 Jun 1999 00:51:24 -0500, John Shadow <JSh### [at] usanet>
  Chris Colefax has a tile generator include file that can do this:
http://www.geocities.com/SiliconValley/Lakes/1434/
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 13 Jun 1999 23:18:01
Message: <37647469@news.povray.org>
FYI, I asked this same question a few weeks ago and was also referred to
Chris Colefax's code. Turns out that what he does is use a gradient to sort
of blend the pattern. This kind of works ok if the pattern isn't too
complex, or if its an even (v.s. an odd) number of regular elements. I
haven't found a really good solution yet. Please let me know if any of you
out there have any better suggestions. But even so, my compliments to Chris
Colefax. This and all of his other work is extraordinarily educational, at
the least.
Here's an example you can play with to see what I mean:
// TexTileTest.pov
// This is for testing the TextureTile.inc utility.
// 22-May-99
// D. Cook
#include "woods.inc"
#include "stones.inc"
global_settings
  assumed_gamma 1.5 // this is a dark scene, make it brighter
light_source {-z * 100000 rgb <1, 1, 1>}
file:#declare TileTexture = texture {T_Wood32 scale 4 rotate <80, 0, 10>}
// looks like dried mud
file://#declare TileTexture = texture {T_Stone28 scale .2}
file://#declare TileTexture = texture {T_Stone31 scale .2}
// classic checkerboard
// This illustrates how the TextureTile works, which is by blending
// the texture from the corners by means of a gradient. As you can see,
// if the number of squares is an even number, everything is fine. But
// if it has to do a blend, things get fuzzy in the middle. This is the
// problem with using sharply defined textures such as stone, marble, etc.
// as a tile texture - they get fuzzy in the middle.
// Oh well, you can't have everything...
  pigment {checker color rgb 1 color blue 1 scale 0.0666}
  file://pigment {checker color rgb 1 color rgb 0 scale 0.5}
  finish {reflection 0.2}     // original version
  file://finish {reflection 0.5}   // more reflecton
#include "TextureTiler.inc"
--- End of TexTileTest.pov
Alan Kong <ako### [at] pacbellNO-SPAMnet> wrote in message
news:376449df.87192908@news.povray.org...
> Alan
Date: 14 Jun 1999 00:05:30
Message: <37647f8a@news.povray.org>
John Shadow wrote in message <376### [at] usanet>...
>Greetings,
If you want to tile a single existing image file, there is a way of
modifying it so it will seamlessly tile a plane.  Using a paint program,
copy the image.  Then, create a new image with each dimension being twice
that dimension in the original image.  Paste a copy of the original image
into the top-left corner.  Paste another copy in the bottom-left corner, but
flip this copy around the horizontal axis so it is upside-down.  Paste a
third copy in the top-right corner, flipped so it is mirrored around the
vertical axis.  Paste a fourth copy in the remaining corner flipped both
horizontally and vertically.  Save the resulting image.  This image then can
be tiled seamlessly with itself.  A similar variant done entirely in POV-Ray
can be used to make 'infinite' height-fields and similar things.
Mark
Date: 14 Jun 1999 00:06:49
Message: <37697f3d.166402607@news.povray.org>
On Sun, 13 Jun 1999 20:15:47 -0700, "David Cook" <nos### [at] homecom>
  Hi, David. I think there will always be limitations to creating a tileable
image that wasn't designed to be tileable. I found a link for a Photoshop
plug-in to make an image tileable (I think it's usable with Paint Shop Pro
v5.0) somewhere on Truman Brown's pages and it had similar limitations.
http://www.websharx.com/~ttbrown/tbtwfs.html
  I suppose the only alternative is to tweak the scene code to manually
blend the image to be as tileable as possible, though this may be difficult
in many cases.
Alan
Date: 14 Jun 1999 10:15:07
Message: <37650e6b@news.povray.org>
>in many cases.
You can always tweak the POV source code.  It should be possible to make
crackle, bozo, turbulence, and whatnot be tileable with some relatively
minor changes in the code, though you might need to change the lacunarity
of the noise code to make it work.  If you do, make it an option and give
us a patch.
Date: 14 Jun 1999 19:46:26
Message: <37659452@news.povray.org>
difficult
>>in many cases.
>us a patch.
Another way is to use a special camera...
This method will distort the texture (or scene) in strange ways, but it
remains absolutely clear and unblended.
In the code below you can replace the textured sphere with any scene, and
you can change the location and look_at of the camera to whatever you wish.
You will be able to get some really interesting effects...
// Width and height of output image must be equal.
   ultra_wide_angle
   location <0,0,0>
   up y
   right x
   angle 360*pi
   look_at <1,1,1>
sphere {
   0, 1
   pigment {spiral1 1}
   finish {ambient 1 diffuse 0}
   hollow
Greetings,
Rune S. Johansen
http://welcome.to/rsj
Date: 16 Jun 1999 20:24:20
Message: <3767016A.ED8F3742@ledanet.com.au>
> the least.
Yes, this is exactly what the first version of the Texture Tiler include
file did (ie. use gradient blends), and some patterns don't blend well
this way.  The question, though, is how would you *expect* to blend a
checker pattern that doesn't quite fit into the available space...?
The good news is that the Tile Generator macro file offers plenty of
other blending options.  You could try the new blob tile, which allows
you to blend textures/pigments mapped to tiled blobs, giving a more
"organic" seam.  Or, you could create a layered, random object tile that
includes blue and white boxes (you won't get a regular checker pattern,
but if that's all you want then you don't need the Texture Tiler or Tile
Generator anyway!).
Date: 17 Jun 1999 18:55:26
Message: <37697D7A.1A5377F7@aol.com>
> Generator anyway!).
Wow, Kewl!! Chris Colefax actually had a message in my news thread!:D  By the
way, thanks for everyone who replied to my post.  This has helped alot, if only
pointing me in the directions I need to search further:)
John Shadow
