POV-Ray : Newsgroups : povray.bugreports : Suspicious behavior? Server Time
29 Mar 2026 05:25:03 EDT (-0400)
  Suspicious behavior? (Message 1 to 10 of 15)
Subject: Suspicious behavior?
Date: 7 Jan 2014 18:27:30
Message: <52cc8d62@news.povray.org>
DESCRIPTION:
POVray experienced a 'bad allocation' error. Is it supposed to stop
parsing/rendering when this happens? It didn't. I had to stop the render
manually.
After I stopped POVray manually, the offending line 624690 was
highlighted in yellow as it is supposed to AFAIK.
Also after stopping POVray, the program wouldn't surrender the allocated
RAM. I had to manually kill the POVray process in order to get the RAM back.
Have I encountered a bug or is this normal behavior?
Mike
POVRAY VERSION:
3.7.0.msvc10.win64
SCREENSHOT:
http://s421.photobucket.com/user/SharkD2161/media/Support/pov_bad_allocation_error_zps5267f909.png.html
SCENE FILES:
http://www.mediafire.com/download/ldh4jq0ndnoczaf/pov_bad_allocation_error_01.zip
SPECS:
Operating System
	Microsoft Windows 7 Home Premium 64-bit SP1
CPU
	Intel Core 2 Duo E6600 @ 2.40GHz	36 °C
	Conroe 65nm Technology
RAM
	3.00GB Single-Channel DDR2 @ 333MHz (5-4-4-14)
Motherboard
	eMachines EMCP73VT-PM (CPU 1)	26 °C
Graphics
	ASUS VS247 (1920x1080@60Hz)
	767MB GeForce GTX 460 (nVidia)	43 °C
Hard Drives
	466GB Seagate ST350041 8AS SCSI Disk Device (SATA)	35 °C
Optical Drives
	HL-DT-ST DVDRAM GH41N SCSI CdRom Device
Audio
	High Definition Audio Device
http://isometricland.net
This email is free from viruses and malware because avast! Antivirus protection is
active.
http://www.avast.com
Subject: Re: Suspicious behavior?
Date: 7 Jan 2014 18:32:32
Message: <52cc8e90$1@news.povray.org>
I forgot to add that the scene requires LightSysIV.
http://www.ignorancia.org/en/index.php?page=Lightsys
Mike
active.
Date: 7 Jan 2014 18:38:50
Message: <52cc900a$1@news.povray.org>
Am 08.01.2014 00:26, schrieb posfan12:
> DESCRIPTION:
> manually.
It might have been busy de-allocating stuff; it can take quite a while
if a lot of memory had been allocated (and I presume that this was the
case, as "bad allocation" sounds like an out-of-memory situation to me).
> back.
It might either be that manual stopping of the render canceled some
cleanup (which shouldn't be the case), or - again - POV-Ray might have
been busy releasing the RAM but it took longer than you were willing to
wait.
Well "normal behavior" it certainly isn't, but it's difficult to tell
whether that's due to a pathologic use case or a bug.
Date: 8 Jan 2014 01:45:14
Message: <52ccf3fa@news.povray.org>
Here is a log of my most recent attempt at rendering the scene.
10:45	- Started render.
~12:00	- First noticed the "Bad allocation" message. Let the render
continue anyway."Current Memory Usage" indicator hovers around 32MB
despite nearly all my 3GB of RAM being used up.
12:45	- Stopped the render manually. The little tune for ending a render
rings. "Current Memory Usage" starts ticking upward to about 2.5GB.
Toolbar buttons are still grayed out.
1:05	- Most memory has been reclaimed. "Current Memory Usage" indicator
oscillates between ~100MB to ~750MB.
1:30	- The little tune rings again. The toolbar buttons are usable
again. "Current Memory Usage" is still around 175MB.
It takes 45 minutes to reclaim the memory used up by the render? I think
this behavior is very odd.
Mike
active.
Date: 11 Jan 2014 04:13:37
Message: <52d10b41@news.povray.org>
Le 08/01/2014 07:44, posfan12 nous fit lire :
> render rings. "Current Memory Usage" starts ticking upward to about
> 2.5GB. Toolbar buttons are still grayed out.
> indicator oscillates between ~100MB to ~750MB.
The scene is fine... if you have at least 17 GB memory, it renders fast
(the parsing is not that long either, yet longer than the render)
(test done on linux, with enough ram)
The top resident memory size in kbytes is 17320752, 17 320 752 kB !
(data from /usr/bin/time -f "%M" ...)
The issue is that your system has only 3GB, so it is going to use
heavily the swap... and that will crawl, whatever the action of aborting
or continuing.
The nice thing is that you use a 64 bits system. A 32 bits system would
have killed your process at the early start.
Render Statistics
Image Resolution 800 x 600
Pixels:           512705   Samples:         2060397   Smpls/Pxl: 4.02
Rays:            3000442   Saved:                 0   Max Level: 2/8
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                              92985           49203     52.91
Cone/Cylinder                  1815147          711682     39.21
CSG Intersection                 43585           15866     36.40
CSG Merge                         6942            4319     62.22
CSG Union                        36339           20023     55.10
Disc                            505074          139999     27.72
Mesh                           6289760         2675946     42.54
Plane                          5388900         2629308     48.79
Sphere                           41739           13150     31.51
Torus                           188778          121630     64.43
Torus Bound                     188778          143738     76.14
Clipping Object                 965328          196487     20.35
Bounding Box                 393145610       108685620     27.65
Roots tested:                143738   eliminated:                56948
Shadow Ray Tests:           2560983   Succeeded:                331457
Shadow Cache Hits:           186477
Radiosity samples calculated:            21367 (0.88 %)
  discarded due to low quality:            213
  retained for re-use:                   21154
Radiosity samples reused:              2413884
Radiosity sample rays shot:             427340
Radiosity octree nodes:                   3569
Radiosity octree samples/node:            5.93
Radiosity blocks examined:           769436051
Radiosity blocks passed test 0:      769436051 (100.00 %)
Radiosity blocks passed test 1:      125276176 (16.28 %)
Radiosity blocks passed test 2:       86730658 (11.27 %)
Radiosity blocks passed test 3:       29110680 (3.78 %)
Radiosity blocks passed test 4:       23710715 (3.08 %)
Radiosity blocks passed test 5:       22667718 (2.95 %)
Radiosity blocks rejected:           746768333 (97.05 %)
Radiosity Depth 0 calculated:            21367 (0.88 %)
Radiosity Depth 0 reused:              2413884
Radiosity Depth 0 rays shot:            427340
Radiosity (final) calculated:            19963 (0.82 %)
Radiosity (final) reused:              2413385
Radiosity (final) rays shot:            399260
  Pass     Depth 0           Total
  1            104             104
  2            343             343
  3            957             957
  Final      19963           19963
  Total      21367           21367
  Weight     0.183
Render Time:
  Photon Time:      No photons
  Radiosity Time:   0 hours  0 minutes  0 seconds (0.035 seconds)
              using 12 thread(s) with 0.191 CPU-seconds total
  Trace Time:       0 hours  0 minutes  5 seconds (5.202 seconds)
              using 12 thread(s) with 59.732 CPU-seconds total
POV-Ray finished
Download 'l3p_datsville_townview.png' (467 KB)
Preview of image 'l3p_datsville_townview.png'
Date: 11 Jan 2014 19:04:50
Message: <52d1dc22$1@news.povray.org>
> or continuing.
I'm not worried about the scene. I know other people have rendered it
just fine. My question was in regard to POV-Ray's strange behavior. I.e.
not quitting when encountering a memory allocation error, the end render
WAV sound playing twice instead of once, and the program not
de-allocating my RAM.
You raise some additional points though. How big does my swap file need
to be? I raised it to 40960MB and it _still_ results in a memory
allocation error. Do I need to raise it further?
Mike
active.
Date: 11 Jan 2014 19:14:56
Message: <52d1de80@news.povray.org>
> Mike
Here's a newer version of the scene. Transparency, reflections,
radiosity etc. are enabled in this one.
Mike
active.
Download 'datsville_povray_rev385.zip' (2965 KB)
Date: 12 Jan 2014 04:52:51
Message: <52d265f3$1@news.povray.org>
Le 12/01/2014 01:13, posfan12 nous fit lire :
lg_defs.inc is missing.
Date: 12 Jan 2014 22:23:44
Message: <52d35c40$1@news.povray.org>
Ah yes, I forgot to mention that you need the LightSysIV library installed:
As well as the LGEO parts library:
http://www.digitalbricks.org/lgeo.html
active.
Date: 12 Jan 2014 22:30:14
Message: <52d35dc6$1@news.povray.org>
I tried rendering the scene again last night this time with two 40GB
swap files on different partitions (I am running out of storage space).
It got to 30001 tokens before I went to bed. 14 hours later when I
checked to see the render progress it was... still at 30001 tokens.
It basically did absolutely nothing overnight. No errors or messages either.
active.
