POV-Ray : Newsgroups : povray.binaries.images : Crackle pattern values Server Time
17 Aug 2025 17:49:01 EDT (-0400)
  Crackle pattern values (Message 1 to 10 of 17)
Subject: Crackle pattern values
Date: 4 Feb 2018 16:05:01
Message: <web.5a7774f01a0c102c5cafe28e0@news.povray.org>
So, I'm mixing the chipboard, Bill P's advice on warp repeat, and a Sam Benge
post to do a little thing I've wanted to do for a while now - mapping out the
values that crackle uses so you can see it in the rendered pattern.
I still have to code up the text pattern so the text face is visible along the x
and y axes as well, but the solution struck me, and I got it coded pretty quick
after a few false starts.  (Thank goodness POV-Ray has a long undo memory)
Download 'cracklelabel.png' (165 KB)
Preview of image 'cracklelabel.png'
Subject: Re: Crackle pattern values
Date: 8 Feb 2018 21:10:00
Message: <web.5a7d02a4bb501a745cafe28e0@news.povray.org>
Hope this is a bit better after some further insights and fixing some errors.
Download '3dtextpattern.png' (517 KB)
Preview of image '3dtextpattern.png'
Date: 11 Apr 2018 19:00:00
Message: <web.5ace9305bb501a745cafe28e0@news.povray.org>
An extension of this little project, which is something that Sven and others
might find useful, is numerically mapping a wood texture, so that you can see
which map entry it is you want to modify.
But, I need a little help here.
I've had to edit the code from the crackle experiment to even get the full
texture map to show up, to get rid of the "suspicious expression after rgb"
warning, and then get the numbers to show up, and now for whatever reason I can
only get two map entries to display.
AND, I can't seem to get the normal and finish blocks to play well in the
texture definition.
I have always had some difficulty understanding the structure and syntax of the
texture definition, so perhaps someone with vastly more experience and skill can
explain where things are going wrong, and give me a better framework for
understanding how to properly construct and assemble the subsections so that
they play well together.
Download 'woodlabel.pov.txt' (2 KB)
Date: 12 Apr 2018 03:20:28
Message: <5acf08bc$1@news.povray.org>
> texture definition.
It would seem to me at first view, that the finish and normal blocks
cannot be used in the wrapping texture, because there  a texture_map is
used. So, they should be defined somehow within the textures used in the
texture_map instead. I have not yet found out /how/, within the context
of the array though, but this will give you an indication.
Date: 12 Apr 2018 07:19:17
Message: <5acf40b5$1@news.povray.org>
On 04/11/2018 06:58 PM, Bald Eagle wrote:
....now for whatever reason I can
> texture definition.
A trick I find useful when working with maps is to hard code a value as
follows using function{} :
// pigment_pattern {NR_wood_grain}
    function { 0.91 }
    texture_map {...}
and doing this in your scene tells me the problem (two value issue) is
with the NR_wood_grain pigment though nothing pops out at me...
You can use differing normals and finishes in your texture_map, but you
have to have added those to the original texture definitions as Thomas
suggested or make your texture_map entries each something like:
[0.9 pigment {} normal {} finish {}]
Bill P.
Date: 12 Apr 2018 13:10:01
Message: <web.5acf91ecbb501a74c437ac910@news.povray.org>
>     function { 0.91 }
>     texture_map {...}
I'm not quite following what you're doing with the function{} here.
I did have a bit of trouble getting the NR_wood_grain to work as a pigment
pattern, but now I'm in a weird intermediate limbo-state where it SORT OF
works...   :|
Yes, that makes sense - I had sort of suspected something like that when I got
the "can't do that with a layered texture" message.   Thanks for clearly
confirming.
Date: 12 Apr 2018 15:14:27
Message: <5acfb013$1@news.povray.org>
>>      function { 0.91 }
>>      texture_map {...}
It's a debug aid. Normally a <whatever>_map responds to a pattern or
function generating a 0 to 1 value based upon the x,y,z position of a
point.
When something is amiss, it's sometimes hard to know whether the issue
is the construction of the map or if the pattern/function generating the
0 - 1 values is incorrect.
Coding 'function { 0.91 }' fixes the value the *_map uses at 0.91 no
matter the x,y,z position of the point. It is a way to verify the *_map
gives you exactly what you expect for color, pigment, texture or density
for any given value. If you wanted to see what the interpolated texture
at 0.25 looks like between 0.2 and 0.3 texture entries in a texture_map,
you'd code 'function { 0.25 }' and render to see.
Bill P.
Date: 13 Apr 2018 09:05:01
Message: <web.5ad0aabebb501a74c437ac910@news.povray.org>
> >>      function { 0.91 }
> >>      texture_map {...}
Ah, I see this clearly now.   Very clever  :)
Presumably one can do function {Val1, Val2, Val3}
to specify any "x, y, z" coordinate to evaluate the map at.
I'll see what I can work out using that method.
I also had some issues getting the text object to work well as a pigment pattern
- is there a trick for getting a text object with infinite thickness - or would
that not be necessary?
Date: 14 Apr 2018 05:34:49
Message: <5ad1cb39$1@news.povray.org>
>>>>       function { 0.91 }
>>>>       texture_map {...}
If you want infinite thickness with an object pattern, you can wrap the
pattern in a function after having centerer the object with thickness
about some plane in space. Say the x-y plane at z=0. Then call your
FnWrapObjectPattern as FnWrapObjectPattern(x,y,0.0) making the pattern
effectively a 2D, infinite in z, x,y pattern.
Bill P.
Date: 14 Apr 2018 18:15:56
Message: <5ad27d9c$1@news.povray.org>
>>>>       function { 0.91 }
>>>>       texture_map {...}
While Willian method is good, if you don't need it to be infinite but
having it just be extremely thick, you can give it a large value for the
thickness, and then scale it very large. If the actual thickness get in
the 1e6 erange, or more, it will effectively /look/ infinite.
Extreeme thickness sample :
text{ttf Fon_Name, Yourtext, 2e6, 0 translate -1e6*z scale<1,1,1e6>}
