POV-Ray : Newsgroups : povray.binaries.images : Secret Passage WIP (TINA CHeP) Server Time
13 Mar 2026 11:08:36 EDT (-0400)
  Secret Passage WIP (TINA CHeP) (Message 27 to 36 of 106)
Subject: Re: Secret Passage WIP (TINA CHeP)
Date: 10 Oct 2014 16:05:01
Message: <web.54383be7cbb3d8155e7df57c0@news.povray.org>
> Well, the truth about those missing values is more along the profane
> Microsoft lines: They have been reserved for /some/ other fancy mappings
> since so long ago - without ever actually being implemented - that even
> the memory of /what/ mappings those were supposed to be is lost in the
> absorbing and scattering media of time.
Yes, I've had a number of "This Space Reserved" issues.
Now if only I'd taken that 2 seconds to add the comment in the code...
This also makes me wonder of you can map things onto media....  :O
> Worth trying at least.
Touche'.
I've hand coded my ceiling lamps out of spheres, cylinders, cones, and sphere
sweeps, so now I'm going to take a whack at the medallion.  I might see if I
have enough interconnecting brain cells to plot pixels varying in grayscale
value with the sine of the distance from the origin, make that a heightfield,
and then slap my image map onto that...
Date: 10 Oct 2014 21:19:23
Message: <5438859b$1@news.povray.org>
Am 10.10.2014 22:04, schrieb Bald Eagle:
Well, you can use patterns to control the density.
> Touche'.
Function image, maybe? (You can generate an internal greyscale image
from a function, and use that as input for a height field.)
Isosurface?
Parametric?
Lathe?
Date: 10 Oct 2014 22:30:01
Message: <web.54389570cbb3d8155e7df57c0@news.povray.org>
http://www.povray.org/documentation/view/3.6.0/379/
That was an option I was unaware of.  Too much cool stuff to play with!  :)
> Isosurface?
That could totally be a very cool option considering what I've seen people do
with isosurfaces.  Especially since it's a small scene element and so might not
be a huge bottleneck.
> Parametric?
> Lathe?
Both good suggestions I'll have to explore.
With regard to the complex topology of some of the furniture, I'm wondering if
something like a sphere sweep would get me the bulk of what I was aiming for
quickly - especially in the case of the scroll work.  IIRC, there's a "cone
sweep" - is there a cylinder sweep?  blob sweep?
I suppose those are all just specific instances of "follow this spline and plot
this object{X} at the current point", so I could try and code that generalized
case by hand...
Thanks for the suggestions as always.  There are few threads I fail to profit
from in some way.
{Have a great weekend everyone!}
Date: 11 Oct 2014 16:16:23
Message: <54399017@news.povray.org>
>> Hmm. If considering your image, which is circular, I guess you will need
>> 'once'...
> I was thinking that since it's circular, if I had it repeat across the surface
> so that I had 2 full images, each hemispherical, then I could map it onto an
> oblate spheroid and then bury it halfway into the ceiling.
> So there.
> With regard to blood sacrifice, clipka has slayed the Gamma Dragon, so now
> THAT's not an option.  Somehow Spline Ducks don't quite have the same sense of
> grandeur.  But then..  wait ...  yes!  The Stanford Chocolate Bunny!!!
> Bring out the Holy Hand Grenade!
Take a simple sphere, unevently scalled, and simply apply your image to
it as an image_map.
Something like this:
sphere{0, 1 scale <1,1, 0.2>
  pigment{
   image_map{ png "Medaillon1.png" translate -0.5 scale 2}
  rotate 90*x
  rotate y*Light_source_Fudge_Angle
  translate Final_Location
As the image is scaled to the same dimention as the sphere, you don't
need to use once.
Now, you only need to make sure that it's correctly oriented relative
the dominent light source so that the shadowings are coherent.
A beter way would be to create a hightfield of your medaillon and use
water_level to cut out the base. That way, the shadows will always be
correct.
Date: 11 Oct 2014 16:30:11
Message: <54399353$1@news.povray.org>
>> Isosurface?
>> Parametric?
>> Lathe?
No and No.
> case by hand...
> from in some way.
The cone sweep is only for prism. It makes the edges converge toward a
point. Good to create a pyramid.
In a sphere_sweep, each point require a radius. That radius can be
negative causing a pinch point in the sweep. OTH, each component can
only be perfectly spherical, NO scalling of any kind and NO other transform.
For a scroll, one option would be to use a sphere_sweep with components
having a very small radius, then, to apply very uneven scalling.
Something like using a radius on 0.001 unit and all points in the same
plane, then scalling by something like <1,1, 300000>.
If you only give 2D coordinates, the Z coordinate should default to zero.
Date: 12 Oct 2014 03:18:59
Message: <543a2b63$1@news.povray.org>
> correct.
The drawback of this is that the shadows from the light source are
incorporated into the height_field. The result may not be what you expect.
Date: 12 Oct 2014 14:16:51
Message: <543ac593$1@news.povray.org>
>> correct.
> Thomas
I should have precised that the hight_field should be made from another
source image. That image should not rely on any light source to show the
relief.
Date: 12 Oct 2014 21:15:01
Message: <web.543b266fcbb3d8155e7df57c0@news.povray.org>
OK, after I got that all squared away, I worked out a shape that very closely
approximates the curvature of the actual medallion, and then after some further
frustration in trying to get THAT mapped it looks pretty good.
Left and top is the hemispheroid, and right, center, and bottom are the modeled
medallion shape.
Download 'medallionfunction.png' (143 KB)
Preview of image 'medallionfunction.png'
Date: 13 Oct 2014 03:09:10
Message: <543b7a96$1@news.povray.org>
> medallion shape.
Yes, this will certainly do indeed.
Date: 14 Oct 2014 00:50:00
Message: <web.543caac3cbb3d8155e7df57c0@news.povray.org>
Fireplace Mantel modeled in SDL.
Still needs a bit of touch-up.
Download 'mantel.png' (248 KB)
Preview of image 'mantel.png'
