Op 15/10/2020 om 21:18 schreef Mr:
> Thomas de Groot <tho### [at] degrootorg> wrote:
>> Please find here the (last) version of the scene. Search for the
>> differences ;-)
>> One notable change I want to elaborate on a bit. I dumped Gilles Tran's
>> MakeGrass and replaced it by Lawnmaker from Uwe Gleiss (2004).
>> Unfortunately, his website from where it was downloaded does not exist
>> anymore. Interestingly, the grass blades were made of parametric objects
>> and I remembered the infinite time it took to render a proper scene, so
>> I never used it. William Pokorny's discovery about the optimal settings
>> for parametric objects, made me curious of course and, Lo! Lawnmaker
>> suddenly became a serious candidate. Not stopping there, and interested
>> as I am in using mesh2{} files, I decided to experiment with Meshmaker
>> (thanks Ingo!). With the help of an example file by Friedrich
>> Lohmueller, I made the conversion within a couple of minutes. Taking
>> into account the size of the grasspatches and their grass blade density
>> (which can increase parsing time quite rapidly) a typical lawn renders
>> very fast, hardly slower than the rest of the scene.
>> Thomas
> Hi sorry, is it too late to give suggestions? The potential of this image is big
> ! My first and only remark if too late is that there would me a more immersive
> feeling if silhouette of the castle had more bumpy details for slabs. That would
> be a lot of work (maybe less for an HG POV displacement). So I hold my tong for
> the other possible areas to work on and really appologize if it's too late, I
> enjoy the meteorological effect of clouds falling down to rain a lot, and the
> slopes of distant hills , and the grain on the rusty metal bar and the position
> of wooden ramp to compose image into depth.
Never too late for suggestions; if I am going to do something with them
is another matter. ;-)
For those parts of the castle which show a definite shadow in the Sun
(the tower) I used the displacement feature in Poseray. This is tricky
business because you can easily overdo it and the effect becomes worse.
So, the roof tiles and the stones in the wall were subtly displaced. The
shadowy wall were not displaced though. Overall, I applied a proximity
pattern to make the wall texture more interesting.
There are always more features to work upon in such a scene. I have a
couple of items myself. However, before I get bored I prefer to stop now
and maybe take up the work later (or never). Perfection is not my cup of
tea. :-)
Op 15/10/2020 om 09:26 schreef Kenneth:
>> differences ;-)
> Even more beautiful than your original render.
> I see that the trees have been fattened-up a bit; and one of the rusty metal
> fence-bars has been broken and bent (a nice touch.) It also looks like the
> castle or church has been thrown into more shadow (or maybe with less fill
> light), which nicely matches the late afternoon Sun. The stones under the fence
> seem to have changed too.
Different changes here: besides fattening up of the trees, I threw in a
second one and both are randomly selected. the castle walls have an
added proximity pattern to the texture (the Edouard Poor variant). It
makes them less "clean". New stones under the fence indeed, and I kicked
the metal bars into shape in some places, breaking it at one place (sorry).
> I do like the detailed grass, but my personal preference is for the previous
> 'mossy' appearance; it just seems to go better with the overall 'look' of the
> scene-- maybe because, with its 'lack of detail', it offsets the more-detailed
> valley and trees. And it more clearly shows the shadow of the out-of-frame tree
> that is cast across the lawn.
> I like *both* versions of the fence stones; I think I prefer the previous
> stones' textures, but the new stones' shapes. A difficult decision!
Ha! Here the supremely powerful might of the author comes into play. I
shall leave it as-is.
> It's easy to be an amateur art critic, ha :-P
Sure! Which is nonetheless fully appreciated as it often points directly
to sore places which need treatment.
> You have used so *many* interesting code tools for this scene, tools that I have
> not even started experimenting with yet. Thanks for the detailed descriptions of
> your techniques.
You are most welcome. I need to do something about all this. I have made
a small start into preparing all the stuff for more general use. I met a
lot of loose ends and inconsistencies already so, that is going to take
some time...
> Op 15/10/2020 om 22:38 schreef Bald Eagle:
> > You have sunlight shining on the trees, but no highlights.
> > An effect of the light group?
> No. This is something I am going to look into in my next scene which
> will be on ground level, without the castle. It probably results from
> the billboard settings and or gamma maybe.
An idea off the top of my head: Instead of a flat billboard, you could make a
simple low-rez height_field for the tree (including the trunk too, possibly).
Perhaps 2 or 3 different ones, for variation. (Pre-#declare each HF so that it
doesn't take up 'extra' memory when used repeatedly.) Then the trees would show
some highlights, using phong or whatever.
Since your current billboard scheme has the trees always facing the camera, the
same scheme would be used for the HF 'shells'-- the 'rear' or underside of the
HFs would never be seen.
Hmmm.
If a heightfield is just a displacement based on the grayscale value of the
image pixels, then you could also make an isosurface of it, and abs() should
mirror the
displacement in both directions.
Then I think there's the isosurface approximation macros that could make a
mesh{} of _that_, and then you could possibly make a whole 3D tree from just the
image.
Alternatively, I guess you could just intersect{} it with a box and texture it
with the image_map and see how that turns out...
Just thinking out loud..
>>> differences ;-)
>>> Thomas
>> image is big
>> immersive
>> That would
>> tong for
>> late, I
>> and the
>> position
Maybe not for this one, but for your next master piece 😉
Op 16/10/2020 om 22:42 schreef Bald Eagle:
> Hmmm.
> mirror the
> image.
Yes, all good suggestions needing to be tested... I have a bit too many
things on my daily plate to be able to chew them properly at this
moment. Starting a /new/ ToDo list (as if that would help).
> Hmmm.
> mirror the
> image.
I was actually thinking that a sort of dome-shaped, low-rez crinkly HF (with
'smooth', and 'water_level' to clip off the ground plane), could then be rotated
-90*x, then aligned to the camera view like Thomas did with his billboards. With
the tree texture applied, that would make a quasi-3D tree shape, at least for
the 'bulk of tree leaves' if not the trunk, and it might pick up some
semi-realistic lighting highlights if phong is used. It wouldn't matter that the
HF is just a shell; its underside ('rear') would never be seen, since the HF
would always face the camera.
hi,
> differences ;-)
spent hours, and still couldn't find Wally! :-)
<https://en.wikipedia.org/wiki/Where%27s_Wally%3F>
> MakeGrass and replaced it by Lawnmaker from Uwe Gleiss (2004). ...
> Not stopping there, and interested as I am in using mesh2{} files, ...
some months ago, I played with generated "tufts" of grass, made from a small
number of mesh2 grassblades, and thought the results ok. attached, perhaps you
can put it use.
regards, jr.
Download 'tufts.inc.txt' (31 KB)
Op 22/10/2020 om 10:51 schreef jr:
> hi,
>> differences ;-)
Oh, LOL! this would be a great challenge to do someday in POV-Ray!
[I think that Wally is hidding in the tower... but one of the background
trees is not impossible either.]
> can put it use.
Thank you very much indeed. I shall certainly try it out. I am about
finished with a HowTo document about Lawnmaker. When finished, I shall
post the whole package in these n.g's.
hi,
> >> differences ;-)
a horde of Cousin Ricky's Androids, in bobble hats and striped jumpers?!
> I am about finished with a HowTo document about Lawnmaker. When finished,
> I shall post the whole package in these n.g's.
sounds good.
regards, jr.
