POV-Ray : Newsgroups : povray.binaries.images : N (Captain Nemo) revisited Server Time
18 May 2024 11:31:09 EDT (-0400)
  N (Captain Nemo) revisited (Message 16 to 25 of 35)
Subject: Re: N (Captain Nemo) revisited
Date: 21 Mar 2018 06:52:08
Message: <5ab23958$1@news.povray.org>
Am 3/20/2018 um 8:43 schrieb Thomas de Groot:
> Once in a while, I like to revisit an older scene and remodel it to
> current standards and my changing insights and skills. I did this lately
> with my entry to the TC-RTC back in 2008: "N". I still want to change
> some elements but the comparison over ten years of using POV-Ray are
> notable. Left, is the entry of 2008; right, the new version.
Sorry, but overall I do prefer the original.
The new version seems quite over-saturated, especially the vegetation,
the bricks and the wheel.
While the new camera view is nice it has the unfortunate side effect
that two birds of the flock are very close to the top border and this
hurts the composition.
And a general note to everybody who's posting images to theses
newsgroups: please make sure your JPEG image contains a ICC profile.
Since about 2 months Firefox and Thunderbird have full color management
enabled by default. Chrome and Opera do the same since quite a while,
only IE and Edge don't - but who uses them anyway?
Every contemporary mid-range monitor has a wider color gamut than sRGB,
the one I use even wider than Adobe RGB - and I can assure you, the
difference is NOT subtle.
When I want to make sure to view an image as intended I have to do a few
additional steps and as I'm lazy I usually don't care. As color
management only kicks in for images with ICC profiles I have to save the
image to my local disk and check *if* it contains a profile and if not
use my own image viewer that correctly assumes for images without
profile to be in sRGB and transforms them correctly to my viewing device
profile.
-Ive
Date: 21 Mar 2018 07:30:31
Message: <5ab24257$1@news.povray.org>
How do I do that? Does it apply to PovRay generated png's?
Regards
Date: 21 Mar 2018 08:11:50
Message: <5ab24c06@news.povray.org>
>> lately with my entry to the TC-RTC back in 2008: "N". I still want to
>> change some elements but the comparison over ten years of using
>> POV-Ray are notable. Left, is the entry of 2008; right, the new version.
I agree for the vegetation, maybe the wheel, not really for the bricks.
However, my question would be: where does over-saturation come from?
It is strange. The original is - imo - strongly under-saturated.
Yes. You are perfectly right. Another reason to revisit the birds.
> profile.
Hmmm... I don't know how to achieve that...
Date: 21 Mar 2018 08:23:43
Message: <5ab24ecf$1@news.povray.org>
It looks better in most respects.  I see 3 areas that seem
over-corrected, though:
The corrosion on the plaque is overdone.  It's not that it's
unrealistic, but that the text is mostly illegible.
The vegetation, while in isolation it looks better than the original, is
distracting from the composition (for that very reason).
The new skin tones look overly saturated, although they are better than
in the original.
Date: 21 Mar 2018 09:07:48
Message: <5ab25924$1@news.povray.org>
Am 3/21/2018 um 13:11 schrieb Thomas de Groot:
Gamma! In the ancient time of MegaPOV and its unawareness of gamma
handling you as the user had to tweak scene colors and lighting to
compensate for the resulting inconsistency. Now with proper gamma
handling but some of these *tweaks* making it over results in
over-saturation and slightly hue shifts - as to be expected.
Yes, I agree - saturation is certainly also a matter of taste -
personally I can live with under-saturation better than with
over-saturation.
Contemporary versions of Photoshop and Lightroom do this auto-magical,
older version if you told them to do so and I'm under the assumption
this is also true for other software like Gimp or Paintshop. I do not
use the latter so maybe I'm wrong?
-Ive
Date: 21 Mar 2018 09:14:32
Message: <5ab25ab8$1@news.povray.org>
Am 3/21/2018 um 12:30 schrieb Stephen:
> How do I do that?
See my reply to Thomas.
PNG's are a very sad story and the ones generated by POV-Ray are no
exception. For short: there is absolutely no way you can predict what
anybody else will see when you post a PNG on the web. And there is no
way to work around this.
-Ive
Date: 21 Mar 2018 22:22:44
Message: <5ab31374$1@news.povray.org>
Am 21.03.2018 um 11:52 schrieb Ive:
> As color
> profile.
I'd call that a bullshitty implementation then. After all, the W3C
officially recommends sRGB for all web content, so that's what browsers
should default to if an ICC profile is not embedded.
Also, a lot of images posted here are rendered with POV-Ray, which
currently does not embed an ICC profile. So to comply with your request,
each and every image would have to be post-processed before posting,
which I consider unreasonable.
Date: 21 Mar 2018 22:26:37
Message: <5ab3145d$1@news.povray.org>
Am 21.03.2018 um 14:14 schrieb Ive:
... which, I'd like to emphasize, is not POV-Ray's fault: If output is
set to `File_Gamma=sRGB` (the default), POV-Ray embeds an sRGB chunk,
which according to the PNG standard should communicate plain as hell
that the colour space is supposed to be sRGB.
Date: 21 Mar 2018 22:34:04
Message: <5ab3161c$1@news.povray.org>
Am 21.03.2018 um 13:11 schrieb Thomas de Groot:
Those are Poser figures, so I presume their materials also use Poser
texture images.
MegaPOV 1.2.1 - being based on POV-Ray v3.6 - completely ignored gamma
for input images; if you already used `assumed_gamma 1.0` back then - as
every good sailor should - MegaPOV 1.2.1 / POV-Ray v3.6 would
erroneously presume the input images to match that gamma.
Date: 22 Mar 2018 03:47:59
Message: <5ab35faf$1@news.povray.org>
>> bricks. However, my question would be: where does over-saturation come
>> from?
> over-saturation.
Then the short answer is clear: My latest scene version using
exclusively sRGB gamma all through (and gamma 1.0 where necessary) the
apparent over-saturation is solely due to the original hue of the used
image_maps. I can live with that although I prefer a slightly
less-saturated version; it might me make to consider to tweak the
original images to a "lighter", "flatter" hue, or to apply a colour
transformation within POV-Ray.
I am using Gimp and have not (yet) found thematter. Does your IC do it
by the way?
