> "Kenneth" <kdw### [at] gmailcom> wrote:
>> What is the reflection(?) or thingy on the left side of the image? Very curious.
> Hmm, after further scientific analysis, it looks like a shoe footprint(?)
Reflection, probably from an HDR background.
>>> Very curious.
yes ... abandoned paper mill
Looks like the reflection of an arched church window.
>> Very curious.
It does look like the reflection of a stained glass window. Especially
if you flip the image upside down.
Regards
On 7/22/2017 9:42 AM, Jim Holsenback wrote:
> can't decide if marble / subsurface is next ... or glass!
here's a marble version ... there were some problems with the model that
were hidden by the procedural normal i used on the granite version. much
trial and error then smoothing the vertex weights around the cut outs
fixed it ... didn't even have to subdivide or use shade smooth. blender
did do a pretty decent job on the uv mapping as well. i /do/ see a
couple of /hot/ pixels i think a tad too much translucency. a little bit
more work and i think this one's ready for a beauty run!
Download 'rollysphere.png' (697 KB)
Preview of image 'rollysphere.png'
I like the texture and yes a bit too much translucency.
I appreciated the description and must read up on vertex weights. As I
have a model that is showing artefacts that Ctrl + N does not fix.
Regards
The translucency looks ok to me. The marble is gorgeous.
>> that were hidden by the procedural normal i used on the granite
>> version. much trial and error then smoothing the vertex weights around
>> the cut outs fixed it ... didn't even have to subdivide or use shade
>> smooth. blender did do a pretty decent job on the uv mapping as well.
>> i /do/ see a couple of /hot/ pixels i think a tad too much
>> translucency. a little bit more work and i think this one's ready for
>> a beauty run!
I thought it was the translucency that was showing up on the shadow.
Regards
>>> a beauty run!
that's reflection of brick wall and part of window in hdr probe ... but
closer to object the floor is showing the translucency i was talking about
>> a beauty run!
well i'll only take partial credit for that ... it's an image map.
getting the uv mapping correct was the challenge
