POV-Ray : Newsgroups : povray.binaries.animations : 2 Opal rings Server Time
12 Jun 2026 13:10:11 EDT (-0400)
  2 Opal rings (Message 1 to 10 of 20)
Subject: 2 Opal rings
Date: 23 Feb 2007 00:24:52
Message: <45de7aa4@news.povray.org>
This is just an experiment with coloured lights, reflection, rotation, etc.
I can't work out why the green light appears to be faster than the blue
light when they're both in alignment.
    ~Steve~
Download '2rings3.m1v.mpg' (366 KB)
Subject: Re: 2 Opal rings
Date: 23 Feb 2007 03:50:01
Message: <web.45deaa28cac6833cf1cb1e660@news.povray.org>
>     ~Steve~
Steve, what are you doing here? The base is stationary, the plinth is
rotating clockwise and the world is rotating counter clockwise. Argg! The
mushrooms are sprouting early this year :-)
camera back quite a bit and narrowing the field of view.
Date: 23 Feb 2007 11:08:28
Message: <45df117c@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
news:web.45deaa28cac6833cf1cb1e660@news.povray.org...
     LOL! Well, I'm in the right location for them, but I don't drink tea!
8-)
> As for the lights. I think that it's the camera position. Try pulling the
     Ok, I'll give that a try, and actually, that would be about the same
camera position and distance that I would want for my next animation, which
is going to be a merry-go-round or carousel. I'll use copies of  the Poser
horse and doctor them up to look like proper carousel horses, but because I
want it (the carousel and horses) to spin authentically, how would I make a
horse do the up and down thing as it rotates?
    (Anyone?)
    ~Steve~
> Stephen
Date: 23 Feb 2007 11:30:00
Message: <web.45df1582cac6833cf1cb1e660@news.povray.org>
> 8-)
>     (Anyone?)
That was the second Animation I did in Pov. I used Window clip art turned
into height fields for the horsed. A ducky, a horsy a bunny etc. it was for
Date: 23 Feb 2007 15:07:22
Message: <45df497a@news.povray.org>
>     (Anyone?)
object {
	horse
	translate x*some_num
	translate y*sin(clock*some_num2)*some_num3
	rotate y*some_num4
...Chambers
Date: 23 Feb 2007 15:26:27
Message: <45df4df3@news.povray.org>
news:web.45df1582cac6833cf1cb1e660@news.povray.org...
 but because I
>> a
>>     (Anyone?)
> for
> a friend's baby.
    Cool! I'd love to see it some time.
> Use a sinusoidal displacement in the y axis
  Ok, 'sinusoidal displacement' produced a fascinating 2 hours of Googling
with some great results (loads of PDF files there too), but, I do know what
you mean.  ;)
   ~Steve~
> Stephen
Date: 23 Feb 2007 15:33:56
Message: <45df4fb4$1@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> wrote in message
news:45df497a@news.povray.org...
> St. wrote:
>>     (Anyone?)
> object {
> horse
> rotate y*some_num4
    And that's it? That'll make my horse go up and down whilst rotating? I
imagined some longer code... Thanks Ben, will give it a try when I'm fully
modeled-up for the scene.
     ~Steve~
> ...Chambers
Date: 23 Feb 2007 16:40:00
Message: <web.45df5e0fcac6833cc1fe74300@news.povray.org>
> > object {
> > horse
> > rotate y*some_num4
>      ~Steve~
Actually no, that's not it. You need to multiply the last line (rotate
y*some_num4) by the clock too, to make the horse move in circles.
Date: 24 Feb 2007 05:10:06
Message: <jn30u2p23ii3vos9egjn92vag28knpohq4@4ax.com>
>> > object {
>> > horse
>> > rotate y*some_num4
>>      ~Steve~
It looked right when I came in last night from the pub :-)
Actually I was going to say to Steve that he does not need to render a full
circle. Because of the inherent symmetry of a carousel you just need to render a
fraction. If there are 12 horses in the outer row then 30 degrees is all you
need to do. The way I constructed mine was in sections by groups then the groups
were referenced. So it was the groups that rotated around the y axis and the
horses translated in the y axis.
Regards
Date: 24 Feb 2007 05:16:00
Message: <to30u2572s1p7etdnk2fu3i9uqeq1vgacf@4ax.com>
So would I but it was two laptops, eight years and several system crashes ago.
I probably have it on an Omega zip drive somewhere in storage but when I could
get to it I don't know :-(
My first animation was a Newton's cradle made out of Red Stripe bottles hanging
over Jamaica. I was working at Red Stripe in Kingston at the time. That's lost
too, more's the pity.
Regards
