POV-Ray : Newsgroups : povray.beta-test : Render Priority Server Time
11 Jun 2026 22:41:51 EDT (-0400)
  Render Priority (Message 1 to 10 of 41)
Subject: Render Priority
Date: 9 May 2010 04:47:40
Message: <4be676ac$1@news.povray.org>
I seem to remember that Render Priority was switched off during developement
of the betas. If so, it would be nice if this was switched on again now.
Whatever the selection (low, normal, high) the render seems to take up the
full 100% cpu.
Subject: Re: Render Priority
Date: 9 May 2010 05:04:56
Message: <4be67ab8$1@news.povray.org>
> full 100% cpu.
I think this is because the render priority and multi-threaded rendering
kind of logically conflict with each other. Having multiple threads and
using only part of the CPU is, while not mutually exclusive, not really
sensible.
Maybe reducing the number of threads would be sufficient for your purposes?
	Thorsten
Date: 9 May 2010 05:58:32
Message: <4be68748@news.povray.org>
Am 09.05.2010 11:04, schrieb Thorsten Froehlich:
>> developement
>> the
>> full 100% cpu.
> sensible.
Hm... what happens if someone only has a single-core CPU? (Yeah, poor
sod, but still - POV-Ray 3.7 should be able to deal with this I think.)
Date: 9 May 2010 06:04:44
Message: <4be688bc@news.povray.org>
>> sensible.
>> purposes?
Yes, of course, but that problem should solve itself quickly ... few of
those CPUs are able to run a recent Windows _and_ still have resources to
spare for POV-Ray :-)  Of course, your point still remains a valid argument
for a few more years.
	Thorsten
Date: 9 May 2010 09:57:42
Message: <4be6bf56@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> schreef in bericht
news:4be67ab8$1@news.povray.org...
>> developement
>> the
>> full 100% cpu.
> sensible.
You confirm my musing. So this means in fact that Render Priority has become
obsolete, if I understand this correctly. Then logically, the option should
be deleted, shouldn't it?
Date: 9 May 2010 14:39:46
Message: <4be70172$1@news.povray.org>
Having a render priority being set low while still using all the cores in
the event that nothing else is running is a useful combination. Reducing the
number of cores is really only equivalent if you can do this in the middle
of a trace, which I don't think is currently possible. Having the render
automatically drop into the background when more urgent work(*) starts
running is a useful setting.
(*) What, more urgent than a POV-Ray render? I know, I know, but it
occasionally happens.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 9 May 2010 14:55:58
Message: <4be7053e@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Having the render
  That's a task for the operating system to do, not the program. All
modern multitasking operating systems have process priorities (although
I don't remember if you can actually fine-tune it manually in Windows).
  In Unix-type systems you simple start povray with 'nice' (or renice it
afterwards with 'renice' or with 'top').
Date: 9 May 2010 14:58:35
Message: <4be705db@news.povray.org>
> full 100% cpu.
  Btw, I'm curious to know why you wouldn't want POV-Ray taking all the
available CPU.
  The only thing I can think of is if you are suffering from overheating
problems and you want the CPU to be eg. at 50% at maximum in order for it
to not to overheat.
  (If what you want is that other tasks get more CPU than POV-Ray, rather
than the OS distributing the CPU evenly, that's the OS's problem, not
POV-Ray's. In most modern OS's you can set process priorities on a
per-process basis.)
Date: 9 May 2010 15:35:20
Message: <4be70e78$1@news.povray.org>
   I never needed to renice povray... when my CPU it's at 100% tracing a
scene, I barely notice it on my regular work. In fact, I sometimes forget
that there is a scene rendering into another desktop (usually I remember
about it when I just clicked on the "shutdown" button... :).
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 9 May 2010 16:02:02
Message: <4be714ba@news.povray.org>
  Maybe because I'm using an "old" Pentium4, if I try to watch a
H.264-encoded video while povray is rendering, mplayer may have
difficulties (especially if the video has a relatively high resolution).
I have to renice povray if I want mplayer to be able to decode it in
real-time.
