POV-Ray : Newsgroups : povray.advanced-users : custom dispersion curve Server Time
18 Nov 2025 08:19:08 EST (-0500)
  custom dispersion curve (Message 1 to 10 of 10)
Subject: custom dispersion curve
Date: 18 Feb 2008 06:55:00
Message: <web.47b97198297bdf4b256ade900@news.povray.org>
I would like to render a material that has nonlinear dispersion.  For example,
the dispersion property allows us to set only a single parameter giving us the
strength of dispersion.  I don't know for sure about the implementation here,
but I am assuming that this means that the index of refraction has a linear
dependence on wavelength (color).
I want to specify the index of refraction for each color, in the number of steps
that I specify (just as with dispersion) only in a customized way, for example:
n=2 for red part of spectrum
n=1 for middle part of spectrum
n=3 for violet part of spectrum
Since I cannot do this with the dispersion property, how can I do this?  This
looks like it should be very easy to implement, given that POV-Ray can already
handle normal dispersion.  I just need to access the array where the indices
are held, if that is how dispersion works.
Any suggestion or help is very much appreciated.
Subject: Re: custom dispersion curve
Date: 18 Feb 2008 13:36:34
Message: <47b9d032@news.povray.org>
"AaronD" <aar### [at] yahoocom> wrote in message
news:web.47b97198297bdf4b256ade900@news.povray.org...
> steps
> example:
> This
> already
> indices
Not sure about the program source code regarding that but you could do this,
before interior {} was introduced, by using averaged textures. That's
because finish {} had the ior within it in versions prior to 3.5. Checking
on that, I don't think it's backwards compatible even using the #version
change meaning you would need to use POV 3 if doing it in the SDL, if
possible at all.
I have a file made from what Daren Scott Wilson first created, and his idea
became the 'dispersion' used now in POV.
http://webpages.charter.net/omniverse/private/spectrar.zip
Maybe you can do something with it, if not the program source code. This
does NOT work in versions 3.5 or above.
/*bob hughes*/
Date: 18 Feb 2008 19:47:59
Message: <47ba273f$1@news.povray.org>
The 3.7 beta source code is available now so I gave it a look and found it's
done (at least in part) in source\ backend\ lighting\ photons.cpp so thought
I'd mention that. And I'm guessing that might be an easier read than
previous source code, not that I know that for sure either but that's what I
hear.
Didn't look trivial to use more than a single ior, but I don't know the
coding at all. That's what the povray.programming group would be for, or
someone else might have more to say here.
/*bob hughes*/
Date: 19 Feb 2008 03:40:13
Message: <47ba95ed@news.povray.org>
As a very simple solution you can try
to split your scene into separate color channels,
render them independently, and then
just combine them all in a final image.
Date: 19 Feb 2008 04:05:02
Message: <web.47ba9b334c6a5a87256ade900@news.povray.org>
I thought about that too, but I want to render a lot of materials this way and
thought it may be a good addition to POV-Ray anyway, since a lot of transparent
materials have nonlinear dispersion.  I found Element_IOR in lighting.cpp that
returns a modified ior dependent on disp and nelems so perhaps just that one
function could be modified to read from an array instead of disp and nelems,
but I don't know if that is the only place I would have to modify.
Date: 19 Feb 2008 04:07:02
Message: <47ba9c36@news.povray.org>
AaronD napsal(a):
You can find out via T&E
Date: 19 Feb 2008 04:20:01
Message: <web.47ba9e2b4c6a5a87256ade900@news.povray.org>
bart, by the way, if I do that, can you recommend any software that is already
set up to easily combine all the channels, since I would have a huge collection
of images?  I may also want to weight the brightness by the human spectral eye
response curve.
Date: 19 Feb 2008 06:28:47
Message: <47babd6f@news.povray.org>
> response curve.
Check XnView/NConvert (www.xnview.com).It's free, available for many
platforms
and can read raw RGB images. It also has a GFL SDK library for developers.
Date: 19 Feb 2008 07:00:00
Message: <web.47bac4ae4c6a5a87256ade900@news.povray.org>
> platforms
Thanks for the suggestion, but I don't think it will work.  I won't have just 3
channels to combine (RGB).  Instead, I'll have 20 or 30 channels, spaced over
the visible spectrum.  All 30 channels would have to be combined with
appropriate weightings for the illumination source and eye responsivity to
create a single RGB image.  I can write a mathematica code to do it though I
think.
Date: 19 Feb 2008 10:54:00
Message: <47bafb98$1@news.povray.org>
I'm not entirely sure how your input data looks like,
but possibly you can do what you want in SDL by stacking
partially transparent or filtered image_maps on a box
and rendering this with an orthographic camera.
