POV-Ray : Newsgroups : povray.advanced-users : 2D graphical elements Server Time
9 Jun 2026 23:46:11 EDT (-0400)
  2D graphical elements (Message 11 to 20 of 20)
Subject: Re: 2D graphical elements
Date: 6 Mar 2011 20:30:00
Message: <web.4d7434f01ecabac28693b1390@news.povray.org>
I guess I should have said "in scene" instead of "on screen". I.e. it should be
possible to place the 2D elements *anywhere* in the scene - not just parallel to
the viewing plane.
Date: 6 Mar 2011 23:50:12
Message: <4d746404$1@news.povray.org>
Am 07.03.2011 02:29, schrieb posfan12:
I guess a macro library would be the way to go there. Making the objects
effectively 2D could be achieved by using an almost-zero depth, or
intersecting with a simple 2D shape such as a disk or two triangles
arranged as a square or something.
Date: 7 Mar 2011 00:00:01
Message: <web.4d74663e1ecabac2b05ef170@news.povray.org>
If a true zero depth, 2-D object is desired, then the simplest would probably be
to make the 3D version and intersect it with a 2D box (box with one dimension
zero)
-tgq
Date: 7 Mar 2011 13:12:14
Message: <4d751ffe@news.povray.org>
> zero)
> -tgq
There IS a zero depth object already available beside the triangle. It's
called a polygon.
It can have an arbitrary number of edges, receive any pigment, like an
object pattern for example.
Once created, it can easily be scalled, rotated and mooved around just
like any other object.
No, a disk is NOT a true 2D object. It have a definite interior just
like a plane. That interior does extend lateraly beyong the visible part
and thus will interfere with medias.
Date: 8 Mar 2011 12:41:54
Message: <4d766a62$1@news.povray.org>
Am 07.03.2011 19:12, schrieb Alain:
Didn't know that. Yuck.
Date: 8 Mar 2011 14:22:15
Message: <4d7681e7$1@news.povray.org>
Le 08/03/2011 18:41, clipka nous fit lire :
It's a "bug" from the very first days of povray.
Probably a copy-paste of code at that time.
Date: 11 Mar 2011 22:45:01
Message: <web.4d7aeb3a1ecabac28693b1390@news.povray.org>
What are good candidate 3D objects? They should be smooth and also render fast.
From the W3C:
http://www.w3.org/TR/SVG/shapes.html
Plus the 'path' element, which can be any of:
+ straight lines
+ two types of Bezier curves
+ circular and elliptic arcs
-Mike
Date: 12 Mar 2011 05:17:29
Message: <4d7b4839$1@news.povray.org>
Le 12/03/2011 04:40, posfan12 nous fit lire :
> 9.2 The ‘rect’ element
> 9.3 The ‘circle’ element
> 9.4 The ‘ellipse’ element
> 9.5 The ‘line’ element
> 9.6 The ‘polyline’ element
> 9.7 The ‘polygon’ element
Already seen in FS#63
    * Rectangles can have rounded corners
    * Polygons have last point connected to first
circle = disc
ellipse = disc + scale
polygon = polygon !
rect = flat box, but rounded corners would be a bonus
line = flat box + rotate, but need a pen size!
polyline = sequence of flat box & connecting disc, also need a pen size
> From the W3C:
> + straight lines
Spline! (and it will suck for circular & elliptic arcs)
and you will need a text processing to load the fonts, split each letter
apart and put them along the spline.
Date: 12 Mar 2011 15:20:22
Message: <4d7bd586@news.povray.org>
2 options: 4 sided polygon or very thin box.
The polygon can easily give you a trapeze, parallelogram, or odd quadrangle.
A disk with hollow
An unevenly scalled disk, also with hollow
A thin and narrow box
Already exists.
>  From the W3C:
Look at the spline.
> + straight lines
> -Mike
Date: 13 Mar 2011 09:35:00
Message: <web.4d7cc7481ecabac22e148fbc0@news.povray.org>
> circle = disc
> polygon = polygon !
1. I'm not 100% all of these are usable when you take into consideration the
fact that SVG can have separate fill and stroke parameters, several types of
curved and/or boxy "line endings" (can't remember the correct term for
these...), and so on.
2. I've been considering instead using triangle meshes for everything, possibly
using one of the various parametric object approximation macros/tools people
have created over the years. It would make things a lot simpler since you could
just plug in the formulas and have the macros/tools take care of the rest. (In
fact, I think most software that renders SVG in real-time tends to operate in a
manner more similar to this technique.) Of course, the visual quality might be
inferior in several instances, but it is possible in most cases to tweak the
fidelity/granularity with which the objects and formulas are approximated and
replaced by meshes.
Some food for thought.
-Mike
