POV-Ray : Newsgroups : povray.unofficial.patches : post_process suggestions? Server Time
16 Mar 2026 21:54:29 EDT (-0400)
  post_process suggestions? (Message 49 to 58 of 58)
Subject: Re: post_process suggestions?
Date: 3 May 2000 19:03:36
Message: <chrishuff_99-20CA54.18064603052000@news.povray.org>
In article <slr### [at] linuxparkerrfwicom>,
ron### [at] povrayorg wrote:
> On Wed, 03 May 2000 06:56:52 -0400, Glen Berry wrote:
> > Modern films don't exhibit this effect.
> But some digital cameras seem to, oddly enough.
Ours doesn't...and I have taken several sun-backlit photos with it.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 3 May 2000 19:07:35
Message: <chrishuff_99-78D02B.18104603052000@news.povray.org>
> >> -1 0 0
> >>  0 1 0   * .5 + .5
> >>  0 0 0
> >The numbers in the matrix above are correct. I'm not sure about the
> >multiplier and offset modifiers. For me, a vaue of one for the
> >multiplier works, and the offset value should be set to one-half of
> >the maximum possible value. I just tested these, and they work.
> A multiplier of 1 can cause clipping at the ends of the range.  The
> two worst-case values of the matrix are -1 (when the upper-left pixel
> is white and the center is black) and 1 (vice-versa.)  To get this range
> into the 0..1 range requires multiplying by .5 and adding .5, as I did.
This sounds like it would best be done as a simple macro using
blur_matrix(which should probably be renamed to "convolution_matrix",
since it can do more than blurring and it seems to be the common name).
> A better way to increase contrast would be to apply the
> filter as I've specified it, then apply an S-curve-shaped correction
> to stretch the midrange.
I have been thinking about this...is there a "standard" curve used for
this, or should I just come up with something?
Date: 3 May 2000 19:10:17
Message: <chrishuff_99-3649B7.18132903052000@news.povray.org>
In article <ie71hscr585hiohhurfjkp8bq9pe1ppnt5@4ax.com>, Peter Popov
<pet### [at] usanet> wrote:
> www.gimp.org
Uh, right. Thanks. :-)
Date: 4 May 2000 01:32:37
Message: <OAoROftXR6qd1ySUb3WprSIpKqpE@4ax.com>
On Wed, 03 May 2000 18:10:46 -0500, Chris Huff
If you want, you could also shorten that to simply "convolve" and save
some typing. Since we are referring to a process and not an object,
the verb might also be more appropriate than the noun as well.
Just an idea...
Glen
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 4 May 2000 12:12:37
Message: <3911a175@news.povray.org>
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-80DFAD.19253627042000@news.povray.org...
> Does anyone have any suggestions for additional filters?
A GTran filter - makes your images look like Giles did them.
Date: 4 May 2000 13:34:17
Message: <vLMROTH8RQpXI=BKlhdeTYhui0Xe@4ax.com>
On Thu, 4 May 2000 17:12:33 +0100, "Tom Melly" <tom### [at] tomandluf9couk>
While we are wishing for the impossible, I want the GTran+10 filter.
It makes your images look like a Giles rendering from 10 years into
the future. (He might be excellent now, but just imagine how great he
will be 10 years from now.) As a small side effect, it also speeds
your rendering time an amount equivalent to the speed increase of
computers in the next 10 years.
Later,
Glen Berry
Date: 4 May 2000 14:52:17
Message: <UcQROZw2W1joV6Ajm0U7uS80aIp5@4ax.com>
For what it's worth, here is one example of an S-curve:
    Output = 0.5-(cos(Input*pi)/2)
For this to work, both input and output need to be constrained between
0 and 1. It should work with other ranges of values with appropriate
scaling. The angular unit is expressed in radians, in this example.
This generates an S-Curve, but I'm not sure of an easy way to add
additional parameters and make it more flexible, without losing the
"S" shape.
This curve is also very similar to a generic representation of the
response curve of photgraphic film. It would need some modification to
work as a film response emulator, a subject I raised earlier. The
input range would need to accept those unclipped float values, and the
ouptput would need to be constrained to a range suitable for the
output file format. I'm not yet sure how to add the extra parameters
to do this properly.
Later,
Glen Berry
Later,
Glen Berry
Date: 4 May 2000 17:45:31
Message: <chrishuff_99-F97DDA.16484404052000@news.povray.org>
In article <UcQROZw2W1joV6Ajm0U7uS80aIp5@4ax.com>, Glen Berry
> "S" shape.
This is certainly "a" S-curve, but I wanted to know if there is a
formula for one which is considered the "standard", official or not...a
possibly better solution would be a polynomial curve, or something
similar to what I posted in .binaries.images a while back, where you
could change it from an S-curve to a straight line to a
backwards-S-curve, by modifying the exponent. This also makes a S shape,
and the version I posted works with "out of range" values.
This sounds like it would best be done with the "curves" filter I am
planning, which takes a 3D spline or a color_map for the curve...
Date: 4 May 2000 23:46:30
Message: <FUMSOZRek52TE5mBLKHN7VYeCs19@4ax.com>
On Thu, 04 May 2000 16:48:44 -0500, Chris Huff
Splines sound like a good idea. I wasn't sure how elaborate you were
wanting to get. It would be really nice to be able to enter a series
of values (input vs output levels), and have the software generate a
smooth response curve from them.
Later,
Glen Berry
Date: 5 May 2000 08:39:56
Message: <chrishuff_99-59A043.07430905052000@news.povray.org>
In article <FUMSOZRek52TE5mBLKHN7VYeCs19@4ax.com>, Glen Berry
That is what I am planning...but I am debating whether to use an
internal spline(probably a cosine spline, maybe an optional cubic
spline), or to use a color_map(easier, multiple "film types" can be
declared in an include file and used in the "curves" filter, but I
suspect only uses linear interpolation.).
Maybe a "blend_type" option should be added to _maps to switch between
cosine, linear, cubic, etc. This would solve the problem with using
color_maps, and make anything which uses color_maps, texture_maps,
normal_maps, etc more flexible as well.
