POV-Ray : Newsgroups : povray.unofficial.patches : PovRay faster Server Time
5 Jul 2026 18:58:00 EDT (-0400)
  PovRay faster (Message 60 to 69 of 89)
Subject: Re: PovRay faster
Date: 1 Feb 2001 09:26:40
Message: <3A79721F.FA61D6C3@neuro.informatik.uni-ulm.de>
Ken wrote:
> Warp wrote:
> >   Is it worth the efforts to make this huge amount of work just to
> > optimize one executable binary for one CPU?
> As someone who owns an Athlon machine I consider that a silly question :)
> Besides there are now more than just one person using this CPU. Lots of
> people are buying them.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
I think the whole discussion is obsolete. In the time an cpu optimized
version of POV Ray runs stable and without a few errors more the the
original version, there is a new processor under which the original POV
will run faster than the optimised. Therefor I value all the work for
cpu-optimized POV versions for lost time.
My personal opinion.
Yours Axel Baune
Date: 1 Feb 2001 09:34:18
Message: <slrn97isvc.18h.ron.parker@fwi.com>
Except that the optimized version will run still faster under the new
processor than the original version.  There's a place for optimization,
but it has to be done carefully, with an eye to portability.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 1 Feb 2001 11:10:46
Message: <3a798a86@news.povray.org>
For 1 I need not to rewrite the compiler, I need to write a lot of macros
( not exactly the same, a lot of work) and I need to analyse the source
code, because the code must bee "parallel" so the SIMD instructions can
work. This changes are "native" C and won't speed down the "normal" version
of PovRay. And a special compiler which supports MMX, 3D!Now and SSE. I just
have a beta version of this compiler, the full version cost 499.-- US
dollar.
Date: 1 Feb 2001 11:23:30
Message: <3a798d82@news.povray.org>
I think every new processor will have SIMD instrctions and a
codeoptimization in that direction would speed up PovRay without processor
dependent instructions.
Date: 1 Feb 2001 12:25:11
Message: <3a799bf7@news.povray.org>
> dollar.
I am searching around the web for compilers that you can use... I've found
the following
http://www.cs.virginia.edu/~lcc-win32/
Free. Supports MMX and 3DNow.
http://developer.intel.com/software/products/compilers/c50/index.htm
Free for 30 days. Works if you have Visual Studio. Supports all the stuff in
Intel processors.
http://www.codeplay.com/
"VectorC" with support for MMX, 3DNow! and Intel SIMD. Also integrates into
Visual Studio. There doesn't seem to be a free version (that we could use to
compile POV-Ray), but it's cost ranges from $80 for the special version (no
Athlon or Pentium 4 support, slower compiling and less frequent updates), to
$750 for the pro. version. This one if listed on AMD's developer area.
That's pretty much it. I can't find any more free/sharware compilers that
will do optimizations for this stuff you're adding. Keep up the good work!
Date: 1 Feb 2001 12:33:35
Message: <3a799def@news.povray.org>
Thank you, I will try try them.
Date: 1 Feb 2001 18:57:41
Message: <3a79f7f5@news.povray.org>
About the DLL problem (I was already flamed to death in past for this
subject).
DLLs are binary modules which contain code loadable and callable at runtime.
Windows has DLLs. Linux, BSD, Solaris etc.etc. have shared libraries (look
into /usr/lib for all those .so files...). VMS has shared libraries. I
presume that Mac's have a similar mechanism, OSX being a Mach kernel + GNU
tools is in the U*X pack.
The only OS which I know for sure that 1) has a pov version 2) has nothing
like DLLs is MS-DOS. So, should you decide that MSDOS is dead (well,
actually it was never alive...) you can assume that you have the .dll/.so
capability in ANY case.
With respect to optimizations, you should not put too-atomic ops into
separate code, but try to create macro-ops which, even with the added
overhead of call, gain speed (I don't know if it is possible). A proposal
for a custom compile: create a multithreaded engine which can take advantage
of multi CPU boards (render a different set of lines on each CPU and merge
the result.). The speedup would be almost linear (what about a quad 1GHz
Athlon PC?)
Bye!!!
Alessandro Coppo
a.c### [at] iolit
Date: 1 Feb 2001 21:59:35
Message: <chrishuff-CFE08E.22011001022001@news.povray.org>
In article <3a79f7f5@news.povray.org>, "Alessandro Coppo"
> runtime. Windows has DLLs. Linux, BSD, Solaris etc.etc. have shared
> libraries (look into /usr/lib for all those .so files...). VMS has
> shared libraries. I presume that Mac's have a similar mechanism, OSX
> being a Mach kernel + GNU tools is in the U*X pack.
However, they all do things in their own platform/OS-specific way, so
you still have to (re)write code for handling the libraries for each
platform. Handling the Linux/BSD Unix/Mac OS X group might not be too
difficult, but add in Mac OS versions before and including 9.1, and the
various Windows versions, and other OS's, and you have a problem. There
is no standard C mechanism for doing this kind of thing.
> A proposal for a custom compile: create a multithreaded engine which
> can take advantage of multi CPU boards (render a different set of
> lines on each CPU and merge the result.). The speedup would be almost
> linear (what about a quad 1GHz Athlon PC?)
This is a different matter completely...and very difficult to do
properly, because POV-Ray was never designed to have multiple threads.
Even if you ignore cross-platform differences, you have problems getting
it to share data among the different threads properly (for example,
radiosity, maybe photon maps, etc.). If you don't do this, you end up
with visible artifacts where parts of the image rendered on different
threads join together. You would need to do a lot of reworking on the
source code to get it to work at all.
I think there is a multithreaded version of POV-Ray available (PVM-POV),
but I don't know much about it, and I don't think it works well with
radiosity. I don't even know if it does things on a per-image basis, it
may just distribute different frames to different processors, or give
different chunks of the image to different processors.
Christopher James Huff
Date: 2 Feb 2001 00:14:49
Message: <3a7a4249@news.povray.org>
In article <3a79f7f5@news.povray.org> , "Alessandro Coppo" <a.c### [at] iolit>
> subject).
Nobody said you cannot (easily) overcome the "DLL problem", but you have to
keep POVLegal in mind!
     Thorsten
Date: 2 Feb 2001 01:18:57
Message: <d5kk7tcvc6fc8vcpoi1toteiimldnjg2m3@4ax.com>
On Thu, 01 Feb 2001 22:01:10 -0500, Chris Huff <chr### [at] maccom>
If you mean PMP (PVM MegaPOV), it does work with radiosity. Francois
Dispot was so kind as to keep me informed about the progress while he
and the original PVM-POV author were developing it and from what I've
seen, PMP does a pretty decent job with radiosity. It shares octree
data among the slaves. However, all rad calcs have to be done on
preview stage. Luckily, there are rad options to ensure that.
Peter Popov ICQ : 15002700
