![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <38EDD167.140A0456@aetec.ee>, Vahur Krouverk
<vah### [at] aetec ee> wrote:
> First, current state with my RM SL patch:
> So far most of my efforts have gone to implementation of shader
> compiler.
> I've considerably improved shader compiler from POVMAN version and now
> it could compile almost everything from RM 3.8 specification (one of
> biggest missing parts is transformation matrixes, others are some
> built-in functions), althogh it has several shortcomings and requires
> more work and cleanup.
> However, now I intend to focus my efforts to implementation of POV-Ray
> shading VM (virtual machine), which will interpret compiled code. For
> this I'd like to hear (err, read) some opinions:
Well, looks like there is no more need for me to work on my shader
patch(which would have been nothing like RenderMan anyway, it would be
much more limiting. Even if I did get it to do more than solid
colors...).
> Which functionality should shader patch have? Easiest would be to allow
> only change of color and opacity, i.e. it is like pigment replacement in
> texture. Actual color of object is still determined by the light
> sources, their position with respect to camera etc, and this will be
> calculated by POV-Ray.
The way I did it was to implement the shader as a pigment type, like
image_map or my blob pigment patch. That way, you could use ambient 1
diffuse 0 in the finish, and get nothing but the results from the
shader, but you could also add in reflection, etc.
I had planned for my patch to eventually have access to a list of light
source positions and colors, camera position, trace functions, etc.
> For now I've plugged shader's call to the function Compute_Pigment and
> added to it some parameters (e.g. normal vector in intersection). This
> allows to use some simple shaders e.g. slope or normal dependent
> texture, bumps, texture, which depends from intersection position,
> opacity modification etc. This accords to the first (easiest) solution.
It might be easier for you to use MegaPOV as a code base, it already has
intersection information passed to Compute_Pigment.
> Is it good enough for use or should I shoot for more complete
> implementation? Or can someone propose good alternative between VM and
> POV-Ray (i.e. which part of resulting rgb should be rendered by pure-pov
> and which part by SL VM)?
I think implementing it as a pigment type would give the most
flexibility...but I don't really know anything about shaders and
especially not RenderMan shaders.
Christopher James Huff - Personal e-mail: chr### [at] yahoo com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> colors...).
Sorry to disturb your plans...
I did same (i.e. new pigment) here.
Well, RM shading language (SL) has same capabilities and I hope, that my
patch will support this eventually. Time will tell.
I already use it. I don't have code here (at work), so I'm not sure,
what I've changed (this has been couple of months ago, when I patched
POVRay, SL compiler was primary target in the meantime).
Hmm, sounds like good idea.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff <chr### [at] yahoo com> wrote...
Also, using MegaPov as your code base will make the port to POV 3.5 easier.
-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> compiler.
This looks very interesting and promising. I don't know much about RM
shaders but if we could plug into free shaders libraries (is there such a
thing by the way ?) this could greatly expand pov's texturing abilities.
Could you give examples of things that could be made possible using shaders
and which are currently impossible (or very difficult) to do with pov or
megapov ? For example, would a "patina" shader be possible ?
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
ooh, renderman shaders in pov *drool*
not sure if it'd be possible, but I'd like displacement shaders...and having
the ability to anti-alias a specific shader would be oh so nice...but if
their is some technical limitation that I am not understanding no biggie
and as for the VM thing, I was kinda thinking the same thing, but more in
regards to the talks I read about pov-ray's (upcomming?) plugin system, I
thought it would be super cool to use a VM for the plugin system....(maybe
in java or C or some other cross platform language)
> Hi!
> compiler.
> Other option would be to use full power of SL and use it to fully
> describe object properties i.e. it's final color, as seen on picture
> (taking into account ambiency, reflectance, illuminance, diffuse etc),
> POV-Ray wouldn't modify it.
> This will be more complicated to implement and its integration with
> other pov-ray code will be more complicated. E.g.
> 1. how will SL shaded object interact with photons or media? One
> possibility is to use to maximum extent pov-ray texture variables in
> shader, but this requires rewrite of RM shaders and I'm afraid, that all
> properties could
> not be mapped easily between 2 products (RM and POV-Ray)
> 2. There is need to get information from light sources in order to
> implement illuminance loops.
> 3. Many of shaders use surface derivatives in order to antialias
> textures. This means that some reasonable implementation for derivatives
> should be created. Ron Parker gave link to paper, which could help
> ("Tracing Ray Differentials"), but I haven't studied it very much.
> (Confession: I'm afraid, that my math ain't good either, so if someone
> is willing to help here...)
> 4. Message passing: some mapping between POV-Ray object attributes and
> RM attributes should be made.
> For an example output look to article with same header in
> binaries.images.
> P.S. Considering uv information: for some objects uv mapping is already
> created, hopefully for others it will be done as well (Nathan, is
> someone working on it?). It would be good, if this follows more or less
> RM convention for uv-mapping.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi!
I really hope you will finish your patch and add it to megapov..
i ve seen some shaders for non-photorealistic rendering that are very
interesting and almost impossible to adapt to current versions of povray
M
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've thought about this too, but I'm not sure, whether it is easy to
implement. AFAIK, RM tesselates surfaces into micro-polygons (each 1
pixel in size), then performs displacement (and normal calculation) and
shading. I don't know, whether (and how) it would be possible without
tesselation.
> and having
This requires derivative information, and as I wrote, it is under
consideration. I hope to release first test version soon and most likely
it will be without derivative support, hopefully POV-Ray antialiasing
compensates it a little bit.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For shader examples look http://www.renderman.org/RMR/RMRShaders.html
for various surface shaders (this is what my patch does).
> megapov ?
Hmm, megapov has many additions, of which I'm not quite aware (haven't
POVed long time) so I could give example, which is invalid ;-) How about
anisotropic surfaces? I don't think, that it is supported by megapov. I
try to create number of various examples, when code is evolved enough.
I guess so, but I'm not sure, that I'm able to do it. Writing shaders in
RM SL is not very easy and requires certain skills. But it is required
for writing POVRay patch too. Hopefully when this patch is released,
then concern of some people, that POVRay gets too bloated, will decrease
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Vahur Krouverk <vah### [at] aetec ee> wrote:
: Which functionality should shader patch have? Easiest would be to allow
: only change of color and opacity, i.e. it is like pigment replacement in
: texture.
What would be the advantage of this?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Can someone give me a (good) example of the use of a shader and why it's
so innovative?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
