POV-Ray : Newsgroups : povray.unofficial.patches : Mini patch Server Time
6 Jul 2026 11:37:28 EDT (-0400)
  Mini patch (Message 11 to 20 of 30)
Subject: Re: Mini patch
Date: 17 Sep 1999 21:29:19
Message: <37e2eaef@news.povray.org>
Try this instead of the two spheres in the minipatch example scene. Is the
blue part supposed to happen? If so, why?
#declare S = 5;
box
 1,-1 hollow
 pigment {rgbf 1}
 interior
  media
   emission 1/9
   sample_method 2 samples 2,3
   intervals 3 jitter 0
   density
    agate
    color_map
     [0.0 Black]
     [1.0 rgb <1,.75,0>]
    scale S
 scale S
Date: 18 Sep 1999 00:52:20
Message: <37e31a84@news.povray.org>
Ron Parker wrote in message <37e2656d@news.povray.org>...
>Um.  No progress recently.  There are a lot of little patches I need to
track
>down and integrate.  So far, I definitely have isoblobs and photons and a
>few other little things, but I had those a month ago.  I'd definitely like
to
>add this media one, and fix a smattering of bugs I've posted in
.bugreports.
>No idea when I'll find time to do that, though.
I've figured out a modification to the Windows version of POV-Ray that can
result in a 1%-5% across-the-board speed increase, depending on how much is
running in the background.  If none of the other patches that have been
added have modified any of the pvengine.* files, integrating the
modifications should take less than a minute (if they have been modified, it
might take as much as five minutes).  Should I send you the source?
Mark
Date: 18 Sep 1999 01:27:03
Message: <37e322a7@news.povray.org>
>running in the background. Should I send you the source?
You don't ask questions like that, you just send it in... ;)
Date: 18 Sep 1999 07:43:42
Message: <37E378E5.254C04ED@aol.com>
Coincident surfaces.  Change S to 4.9999. :)
-Mike
Date: 18 Sep 1999 11:39:54
Message: <37e3b24a@news.povray.org>
OK. Cool. Thanks.
I've been playing around with this thing. It is stupendous. I love it. For
some medias it doesn't make any difference, but for others, my goodness! I'm
changing to sample_method 2 for good. =) I've tested the old vollumetric
light scenes posted about 2 months ago. They rendered much faster and nicer
with way lower settings. I also tested my old flame. It is rendering just
like it used to, except the settings are 1/10 of what they were! This is how
media should have been introduced. Oh, BTW, I would prefer the keyword
"method" instead of "sample_method". Just a thought.
Anyway, thanks Mike!
Date: 18 Sep 1999 15:32:53
Message: <37E3E6DA.DE1908AD@aol.com>
The old method is still good for cetain things, like very large objects with
complex media inside.  I think it's related to the random sampling.  You will
get pretty much the same result with the type 2 version in my patch using jitter
1, though it won't take advantage of variance or confidence and therefore
doesn't make good use of max samples.
Supersampling could offer the best of both worlds - oh yeah, and there's some
other tests I can do to speed things up.  Since the ray is sampled from near to
far, I could check if the total color is completely white and save taking
pointless samples.  The same is true for total absorption.  For example, why
take samples to infinity if you have a global media that turns white 10 units
away?
I should mention that all the stuff I'm doing is garnered from how halo and
atmosphere worked in version 3.
Halo used to be used for things like light glows and flames, and using even
samples is just amazingly smooth for that kind of stuff.  I think I've mentioned
before that doing it that way doesn't actually make it faster, but it puts the
sampling to better use allowing you to use fewer samples.
I like the idea.  You would have hated the original keyword I was using -
media_sampling_method.  If I can get supersampling to work (well down the road)
I will include that change in the new patch.  I guess I should have put
something in there about backward compatibility not gaurenteed.  :)
Happy to hear you are having fun with it.  Try a spherical camera render next
and map it to a sky_sphere using spherical mapping. :)
-Mike
Date: 18 Sep 1999 17:04:07
Message: <37e3fe47@news.povray.org>
Mike <pov### [at] aolcom> schreef in berichtnieuws
37E3E6DA.DE1908AD@aol.com...
render next
> -Mike
Yep, fun it is, displacement mapping spherical camera images on
isosurface spheres. No distortion on the poles, makes perfect asteroids
etc.
Had a quick look at the media, but that will take more time.
So many goodies,
so little time.
Thanks Mike
Ingo
Date: 18 Sep 1999 18:24:35
Message: <37e41123@news.povray.org>
Just stepping in to so I can say I like what I see.
ingo <ing### [at] homenl> wrote in message
news:37e3fe47@news.povray.org...
> render next
> > -Mike
asteroids
> etc.
> So many goodies,
> so little time.
> Thanks Mike
> Ingo
Date: 18 Sep 1999 19:25:21
Message: <37e41f61@news.povray.org>
Mike <pov### [at] aolcom> wrote in message news:37E3E6DA.DE1908AD@aol.com...
next
I thought of this when I was planning to make a scene that used some of
those super-slow media clouds.  First, I thought I'd render the scene with
just the sky and no other objects (using the same camera that the final
image would use).  Then, using a macro I created, I'd paste that image map
on a plane lined up witht he camera in the far background for all subsequent
renders.  But then what would happen to reflections (the scene had glass in
it)?  So I thought I'd render the rest of the sky using a spherical camera
and map it to the sky_sphere (like you suggest).  Then, I'd have a
high-resolution image map directly in front of the camera and a nice
sky-sphere to handle reflections.
But then I never used those slow media clouds in that image, so I never put
this technique to use.
-Nathan
Date: 18 Sep 1999 20:45:02
Message: <37E431C3.4A0AD3FA@teleport.com>
Use the Plane_clouds (stsky.pov) using this method. Excellent Results!
H.E. Day
> next
> -Nathan
