![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 28 May 2002 23:49:37 +0200, Fabien wrote:
> I have posted the latest release of Pyvon at p.b.utilities
> Beware it's now 127 Kb large.
> Any comments welcomed.
I like the improvements, but get the following command line error:
Exception in Tkinter callback
Traceback (most recent call last):
File "/usr/local/lib/python2.2/lib-tk/Tkinter.py", line 1292, in __call__
return apply(self.func, args)
File "./pyvon.py", line 1289, in Backspace
self.fontify()
File "./pyvon.py", line 774, in fontify
pos_actu=str(string.join((Ligne, column),'.')) # 1.7
NameError: global name 'Ligne' is not defined
This error only happened on the first run.
There are problems with the barcket/block highlighting, the braces stay
highlighted even when I move the cursor to a different block and start
working there, I don't like having to turn this highlighting off manually.
Other things I'd want, a block cursor (which they still don't have in the
Windows version of POV for some reason), I'd also like it to remember
the scene I was last working on and open it automatically, or at least
remember which directory it was in and open the file selector in that
directory as default.
PC editing and selction keys don't seem to work properly, Ctrl-Ins seems
to mark the way I'd expect, then I move down and do a Shift-Ins and nothing
happens?
The key combinations that you have chosen for editing will be confusing
for windows users, they're confusing enough to me.
When text has been marked it changes colour and for some reason remains
that new (random) colour.
And why won't the window maximise to the full size of the screen?
I like the insert menu.
Whatever the problem was with the command dialog box and status line
seems to have gone away with this release.
If you get stuck for a web page I could put it on one of my pages, it's
only a small binary at the moment, it'd fit quite nicely next to PovMenu,
you could have a screen shot too.
Hope some of this helps.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It would be good, if programming is made in _lingua franca_ of internet,
i.e. in English. By this I mean, that comments, variables, method names
etc. are in English. Now it is your private project and this might not
seem important, but I think that this Pyvon has good potential and it
could become common tool for non-windows (and why not for windows!)
platform, as it is done in high-level language and quite
platform-independently. So perhaps in future it will be project,
inovolving many people? In such case having consistent naming and style
ensures better readability of code (which is important thing for
maintenance and further development).
I have also thought about need for such cross-platform interface in some
high-level scripting language (tcl/tk or Python), but haven't had time
to do it. Why in scripting language? Because it is easy to port, it
allows iterative development and easier maintenance. And in case of user
interface speed of compiled code is not so important (although memory
consumption could become issue). Anyway, it's good to see, that someone
has same thoughts and got something working already, this inspired me so
much, that I took Python book from my work and intend at least get more
familiar with Python (I can't promise, that I will read this book from
cover to cover, as it is >800 pages and quite possibly somewhat
outdated, as it is from year 1996).
Anyway, keep up good work! So far I've used under Linux midnight
commander for POV-Ray development (can't stand Emacs!), but seems, that
these days will be gone soon :-)
BTW, if you intend to post your further versions to p.b.u., then perhaps
it would be better to cancel older versions (to avoid unnecessary server
space consuming and possible use of older versions by someone?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You mean that the code is not clean and messy ?
You are quite right. There is a thing that I definitely have to do, but
in the end only, is to clean everything up and split the main file into
several 'include' files.
For the time being, I spend a lot of time adding and debugging new
features. And it takes a loooong time as I knew nothing of Python in
November last year. That's why I still do newbie mistakes.
It's good to know that I have converted someone and that Emacs does not
suit everybody's needs.
The best is a web page from which to download. I've already got a few
proposals
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> self.fontify()
It's a bug I have with Linux (and not windows). I just wanted to
highlight the brace for half a second or so, and then go back to its
original state. As Linux is my main priority, I'll leave as it is for
the time being.
I have fixed that today. It now remembers which directory was open the
last time.
Which one do you find confusing?
I tried to create the same key combinations as in Windows.
That's why I've added the force syntax coloring option (until the
highlighting works fine).
I don't know the Tkinter command for that (yet).
Thanks for the offer. How often are you ready to update your web page ?
Yes it does. Thanks for your comments.
Fabien
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> last time.
That's good.
I mean Shift-Arrow marks text, Ctrl-Ins remembers selection, Shift-Ins
paste remembered selection, Shift-Del delete and remember selection,
Shift-End mark to end of line, Shift-Home mark to beginning of line etc,
just the way you'd do it in Notepad, Word, Edit.ext and so on.
I'd just add a paragraph to http://www.zeropps.uklinux.net/linstuff.html,
and add a link to that section at the top of that page. It is something
that doesn't take long to do. I'd put it either above or below PovMenu.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would like a fixed width font in the status box...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Good idea. I'll fix that right away.
Fabien
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I should start learning python...
The pov-mode of Emacs is very buggy, for me anyways. I got it to run at
all, but rendering didn't seem to work. Now I can edit AND render in one,
and I like that (-;
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
