POV-Ray : Newsgroups : povray.unix : Compiling 3.5 on RH7.2 Server Time
28 Jul 2024 08:27:32 EDT (-0400)
  Compiling 3.5 on RH7.2 (Message 1 to 10 of 10)
Subject: Compiling 3.5 on RH7.2
Date: 2 Aug 2002 14:35:40
Message: <3d4ad0fc@news.povray.org>
Specs:
	Athlon 1.1 gHz Thunderbird
	RedHat 7.2
	gcc v.2.96 (stock on rh7.2)
Problem:
	Can't get 3.5 source to compile.
Errors:
Making all in src
make[1]: Entering directory `/home/jgentry/temp/povray-3.50a/src'
g++ -DPREFIX=\"/usr/local\"
-DPOV_LIB_DIR=\"/usr/local/share/povray-3.5\"
-DCOMPILER_VER=\".Linux.gcc\" -DSYSCONFDIR=\"/usr/local/etc\"     `if [
"Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -c atmosph.cpp
"Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -c bbox.cpp
In file included from bbox.cpp:47:
optout.h:75: syntax error before `char'
bbox.cpp: In function `int sort_and_split (BBOX_TREE **, BBOX_TREE **&,
long int *, long int, long int)':
bbox.cpp:1872: warning: assignment to `long int' from `double'
bbox.cpp:1872: warning: argument to `long int' from `double'
make[1]: *** [bbox.o] Error 1
make[1]: Leaving directory `/home/jgentry/temp/povray-3.50a/src'
make: *** [all-recursive] Error 1
I solved the "optout.h:49: #error You must complete the following
DISTRIBUTION_MESSAGE macro " problem thanks to Micha's post.  Now I'm
running into all of these different sytax errors during make.  The
configure process went fine, no probs.  I'm not a programmer, so these
error codes mean little.  any help would be appreciated.
-- Jeff
Subject: Re: Compiling 3.5 on RH7.2
Date: 2 Aug 2002 16:16:21
Message: <3d4ae894@news.povray.org>
earthdog wrote:
> Specs:
> RedHat 7.2
> Problem:
  I can't help specifically, but it compiled here with the same system
(only this is 1.2Ghz). I had to update libpng and zlib to the latest
versions, but then it compiled fine. I added then the optimization flags
and it worked a 33% faster. Later I upgraded gcc to 3.1.1 and compiled
again, this time with better optimizations, and now it runs at the same
speed as in windows.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 3 Aug 2002 16:07:26
Message: <3D4C3841.8010104@netscape.net>
earthdog wrote:
> Specs:
>     RedHat 7.2
> Problem:
I finally had a chance to compile 3.5 on my system (rh7.1 Athlon XP
1900+ gcc 2.96). I didn't run into any problems other than having to
edit optout.h like everyone else and creating a povray.conf file in the
/usr/local/etc directory to stop the I/O Restriction problem.
After doing ./configure and make, I tested the resulting binary out and
it worked fine. Then I edited the src/Makefile to add some compiler
optimization flags. The CXXFLAGS now look like this:
CXXFLAGS = -g -O3 -DCPU=athlon -march=athlon -finline-functions \
-fomit-frame-pointer -Wall -funroll-loops -fexpensive-optimizations \
-malign-double $(NOMULTICHAR)
There's probably some redundant flags but it works ;) I then ran
benchmark.pov (+a0.3 +w320 +h240) and got the following results:
windows prebuilt binary = 25m 48s (1548s)
linux prebuilt binary = 55m 40s (3340s)
Micha's p3 optimized = 25m 14s (1514s)
my gcc2.96 optimized = 28m 1s (1681s)
I then applied Micha's patch and got the following result:
my optimized + patch = 28m 14s (1694s)
So the patch didn't really help me but it may help with gcc 3.1. I'm
going to get that next and see what the results are. It sure looks like
gcc has improved :)
 > Errors:
 > Making all in src
 > [ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -c atmosph.cpp
 > [ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -c bbox.cpp
[snip]
Since it looks like the first error is in optout.h and you had edited
optout.h, I'm wondering if something weird happened as a result of the
edit. Perhaps you could yank the original optout.h from the tarball,
edit the DISTRIBUTION_MESSAGE_2, comment out the error line above it and
give it another go.
-Roz
Date: 3 Aug 2002 16:16:28
Message: <3d4c3a1c@news.povray.org>
  I am wondering if it's a good idea to keep such slow version of povray
for linux in www.povray.org if even gcc2 can do such good job at optimizing.
  By the way, how is it possible that the official version is so slow? Was
it compiled with no optimizations at all?-o
Date: 3 Aug 2002 16:27:14
Message: <3d4c3ca2@news.povray.org>
use also -ffast-math
My currently fastest binary was produced with (for gcc 3.1)
CXXFLAGS = -Wno-multichar -O3 -ffast-math -march=pentium3 -mcpu=pentium3
-fomit-frame-pointer -foptimize-sibling-calls -funroll-loops -malign-double
-minline-all-stringops
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 3 Aug 2002 16:45:47
Message: <3D4C413A.8030803@netscape.net>
It looked like the default optimization settings were "-g -O2". Now that
I think about it, that might have been only in the CFLAGS but not in the
CXXFLAGS. Yep, there's the problem. So the default compiling results in
no optimization at all because at least on my system, it's the CXXFLAGS
that are being passed to g++. I placed my optimization flags in both
CFLAGS and CXXFLAGS (leaving the NOMULTICHAR part in the CXXFLAGS
intact). Of course, my optimization settings included targeting the
Athlon architecture. But even without those machine specific flags, the
other optimizations should help.
It would be nice to have a faster pre-compiled Linux binary available
for people to use. Alternatively, maybe some optimized versions like
Micha's p3 one could be provided in addition to the generic (slow :P)
binary.
-Roz
Date: 3 Aug 2002 16:53:15
Message: <3d4c42ba@news.povray.org>
> optimizing.
 Only -O2... but I think what make the great difference is using specific
-mcpu and -march. Perhaps for the official distribution -O3 can be used,
but not much more can be done, I think, except encouraging to compile the
sources for your rendering palataform, perhaps with recommended flags. It's
not that difficult at all: I myself have done it and I've no knowledge
about c, c++, compilers and optimization.
Date: 3 Aug 2002 17:01:05
Message: <3D4C44D5.7020206@netscape.net>
> - Micha
I actually tried the -ffast-math option, then tried to render
balcony.pov and got spammed with the following lines repeatedly:
Warning: Illegal grid value in dda_traversal().
The height field may contain dark spots. To eliminate them
moving the camera a tiny bit should help. For more information
read the user manual!
Weird, huh? Since that scene rendered fine before the -ffast-math flag,
I figured it's better for me not to use it. Maybe it's buggy with gcc
2.96 but works with gcc 3.1?
I'll give the other flags a go and run some more benchmark renders.
-Roz
Date: 3 Aug 2002 18:42:05
Message: <3D4C5C81.6080801@netscape.net>
>>optimizing.
Yes, the cpu targeting helps some. But it turns out to help a lot just
to get the -O2 optimization settings in both CFLAGS and CXXFLAGS. The
default compiliation only put the -g -O2 flags in CFLAGS. I ran
benchmark.pov against a build with only the -O2 optimization flag in
both CFLAGS and CXXFLAGS and here's the resulting times:
default options (only in CFLAGS) = 55m 40s (3340s)
-O2 optimized (in both directives) = 29m 1s (1741s)
So maybe just getting a build based on the intended optimizations would
be a good thing to provide on the POV-Ray web site.
-Roz
Date: 3 Aug 2002 22:34:06
Message: <pan.2002.08.04.02.38.08.500172.2133@povray.org>
> optimizing.
I plan to have an updated binary by the end of the weekend.
-Mark Gordon
