POV-Ray : Newsgroups : povray.unix : Another 3.5 speed issue? Server Time
29 Sep 2024 02:17:17 EDT (-0400)
  Another 3.5 speed issue? (Message 1 to 10 of 19)
Subject: Another 3.5 speed issue?
Date: 7 Aug 2002 17:03:49
Message: <3D518C26.9020704@att.net>
Before I post my actual timings, I'd just like to air my preliminary gut
reaction that my properly-installed/downloaded 3.5 binary on Libranet
Linux (chiefly based on Debian woody, with 2.4.x kernel) running on a
Celeron 400 with 128 MB RAM, is SLOWER than the Povray 3.0.xx .deb that
came with Debian potato.   I may have to revert, unless I can be
convinced otherwise.  (I'm not an advanced user, and I'm struggling
along on one particular project, so I may not even notice the
improvements for awhile....
Also, my quality param. (Q2 for rough views just to check obj.
placement) doesn't seem to make any difference.  Should I copy a
povray.ini to my home dir. and tweak it for my usual settings?
TIA as always,
Mark
Subject: Re: Another 3.5 speed issue?
Date: 7 Aug 2002 19:15:27
Message: <3d51aa0f@news.povray.org>
Try downloading the source and compiling it.
  Due to a human mistake the official binary was compiled with no
optimizations, which makes it awfully slow. (I don't know if an updated
binary has already been made available.)
Date: 7 Aug 2002 23:39:47
Message: <3D51E839.8070004@netscape.net>
I noticed Mark Gordon posted a note about placing a new Linux binary
up to address the I/O restriction problem. I downloaded it a little while
ago and ran benchmark.pov on it and it is a lot faster than the older
non-optimized version was. It's not as fast as can be achieved with
doing your own compile using various optimization settings but it's
a definite improvement. Thanks Mark :)
Times are as follows:
Windows prebuilt         = 25m 48s (1548s)
older Linux prebuilt     = 55m 40s (3340s)
new (8/7) Linux prebuilt = 34m 10s (2050s)
gcc3 athlon optimized    = 24m 19s (1459s)
-Roz
Date: 8 Aug 2002 08:26:49
Message: <pan.2002.08.08.12.31.00.988473.1787@povray.org>
On Wed, 07 Aug 2002 23:40:41 -0400, Roz wrote:
> Warp wrote:
>>   Try downloading the source and compiling it. Due to a human mistake
> I noticed Mark Gordon posted a note about placing a new Linux binary up
> doing your own compile using various optimization settings but it's a
> Windows prebuilt         = 25m 48s (1548s) older Linux prebuilt     =
> 55m 40s (3340s) new (8/7) Linux prebuilt = 34m 10s (2050s) gcc3 athlon
> -Roz
The error Warp notes in the original binary has been fixed in the updated
one.  Additional optimizations (e.g. Pentium II optimizations) may
sacrifice portability, so I'm not using them in the official binary at
this point.
-Mark Gordon
Date: 8 Aug 2002 12:35:02
Message: <3D529DEA.50502@netscape.net>
> this point.
> -Mark Gordon
Thought ya did that based on the speed I saw last night when rendering
benchmark.pov with the new binary (dated 8/7). I agree with the need
to keep it portable. That's probably why it's statically linked too.
Even so, your "compatible" optimizations improved the speed from
55m to 34m. I think that's a really good improvement!
You could also try the Intel compiler at some point if you're feeling
adventurous. From looking at Micha's speed postings, the Intel compile
was a bit faster than the gcc one.
-Roz
Date: 9 Aug 2002 10:44:52
Message: <3D53D65C.532D8048@ncsl.dcr.state.nc.us>
But for those of us who don't know our way around source code, how easy
is it to find the file(s) to optimize, and make the appropriate
changes.  I'm not just a newbie to POV, I'm a total stranger in a
strange land when it comes to hacking.
Is "rolling my own" a realistic option, then?
--Mark W.
> -Roz
Date: 9 Aug 2002 23:46:52
Message: <3D548CE4.8040202@netscape.net>
> --Mark W.
If you're unfamiliar with Makefiles and editing source files, such as
optout.h, then it would probably be easier for you to download and
use one of the prebuilt optimized binaries others have provided rather
than roll your own. Or at the very least, try downloading and installing
the new Linux binary from:
http://www.povray.org/download
It will be much faster than what you currently have and installation
should be straightforward (instructions are on the download page).
Micha Riser has provided some prebuilt binaries at the following url:
http://www.povworld.org/povray/binaries.html
Unfortunately, I cannot pull this page up right now to see what cpus
have been targeted. You have a Celeron and I'm not sure if the Pentium
optimized ones will work. It won't hurt to try though (except for
bandwidth). Just extract a prebuilt binary into its own directory and
run it from there with './povray [options] [scene-file]' (no quotes).
But at the very least, try the new one from POV-Ray's site and save
yourself some rendering time.
-Roz
Date: 10 Aug 2002 03:55:21
Message: <3d54c6e8@news.povray.org>
> have been targeted.
Unfortunately the server's connection is broken and I have no physical
access to it till Monday :( So be a bit patient.
I am not sure if the Pentium III-optimized binary runs on Celerons but I
suppose it does (at least on some, AFAIK there are quite some different
sub-types of Celeron CPUs). Otherwise there is also a version for generic
pentium compatible cpus (which probably is still quite a bit faster than
the new official).
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 12 Aug 2002 14:07:15
Message: <3D57FA5A.C9B9DDBC@ncsl.dcr.state.nc.us>
Thanks! But now the power supply on my box is dead, so it will be
awhile.... >:-(
--Mark W.
> > --Mark W.
> -Roz
Date: 12 Aug 2002 15:08:05
Message: <3D58089A.1FC6F590@ncsl.dcr.state.nc.us>
Ugh, would I always have to run it from its own directory?  I suppose
adding said dir. would be too confusing, assuming I hadn't uninstalled
the other binary, and that's the reason?
Am I correct in thinking that the new on the POV-Ray site is a "revised"
3.5?
--Mark W.
