POV-Ray : Newsgroups : povray.off-topic : I need a new computer: RAID and other questions Server Time
25 Mar 2026 02:41:28 EDT (-0400)
  I need a new computer: RAID and other questions (Message 36 to 45 of 55)
Subject: Re: I need a new computer: RAID and other questions
Date: 28 Jan 2013 03:10:07
Message: <5106325f$1@news.povray.org>
> rsync + cron = backup goodness.
Or robocopy + task scheduler if you're on windows. But both options
assume your computer is on and the backup medium is connected...
Date: 28 Jan 2013 03:12:33
Message: <510632f1$1@news.povray.org>
>  From what I've seen, several revision control systems *claim* to
> support large binary files, but barf if you actually try it...
I don't know how our IT department at work manage it, but on all our
network drives you can right click and folder or file in Explorer and go
Properties->"Previous versions" and help yourself to whatever previous
version you want. I assume that all gets backed up somehow.
Date: 28 Jan 2013 03:42:30
Message: <510639f6$1@news.povray.org>
It's a new feature in Windows Server 2007 (?). AFAIK, it's only
available for the server edition of the OS. But yes, basically it
retains old versions of files for X days. The files are still on the
same physical volume, however. This protects against logical failures
(e.g., some doofus deleted the wrong file), but not against physical
failures such as a head crash.
Of course, then you need to buy backup software expensive enough that it
backs up the hidden previous versions as well as the visible files...
Date: 28 Jan 2013 03:43:21
Message: <51063a29$1@news.povray.org>
Fun fact: I actually did this at my last employer. For real. They
wouldn't cough up the money for a real backup solution...
Date: 28 Jan 2013 17:16:14
Message: <5106f8ae$1@news.povray.org>
A new feature that Novell had in Netware 3.10 back in 1990.
No.  You just need to load $Day's tape (or DVD) with $day's version of
the file.
Presumably, your backup software's DB will be able to provide you with $Day.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 28 Jan 2013 21:43:32
Message: <51073754@news.povray.org>
I was thinking the same thing.  That was the migration feature IIRC.
Migrated data from fast disk storage to slower optical storage.
It's still supported in their current products, though I don't know any
vendors who support it on Open Enterprise Server.
On Linux, btrfs has this kind of capability as well.
Jim
Date: 28 Jan 2013 21:44:37
Message: <51073795$1@news.povray.org>
Sure - and it's kinda hard to do operations with a machine that's turned
off and without backup media in place.  Kinda like running a tape backup
but not putting a tape in the drive every night.
I worked for a retail chain where store managers had to remember to do
that - and often didn't.  So the server would "prompt" them by sounding a
foghorn. :)
Jim
Date: 29 Jan 2013 03:55:11
Message: <51078e6f@news.povray.org>
And Amiga OS had premptive multitasking and a full GUI back when PC
users were still playing with MS-DOS. Your point?
> the file.
> $Day.
The idea being that if you edit the file three times per hour, then
three prior versions get stored. If your backup software is advanced
enough, it can capture all of those prior versions. If it isn't, you
only get the current version at the instant the backup happened. [Which
is still far better than nothing, of course...]
Date: 29 Jan 2013 09:07:07
Message: <5107d78b$1@news.povray.org>
No, I was just thinking of the SALVAGE utility that allowed you to
restore previous copies of files.  (a bit similar to Norton's UNERASE,
but that would work on non-contiguous files)
Date: 29 Jan 2013 09:28:20
Message: <5107dc84@news.povray.org>
That is is hardly a new feature.
>> the file.
>> $Day.
Most software (Office is - or was - famous for that.) no longer rewrite
the entire file when you do a "save".  It only appends a "changes"
section at the end of the file, so unless you do a "save as..." and use
the same file name, you  will not get multiple copies of the file on the
OS file system.
This being said, I wonder how Windows Server 2008 would know that it
should save multiple copies of a 5MB TPS Reports.ppt, but not multiple
copies of a 64GB payroll.dbf.
