POV-Ray : Newsgroups : povray.off-topic : Euclidean infinite detail Server Time
15 Jun 2026 10:27:43 EDT (-0400)
  Euclidean infinite detail (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Euclidean infinite detail
Date: 27 Oct 2016 21:54:47
Message: <5812afe7$1@news.povray.org>
Am 27.10.2016 um 20:51 schrieb Mike Horvath:
> Also, maybe POV-Ray should support point clouds.
You can always read point cloud data at parse time and convert it to a
bunch of spheres (or a set of blob elements if you're low on memory).
If you want something more complicated, then you'd first have to clarify
what that something is; only then will it be possible to even discuss
how that could be achieved, let alone whether it would be reasonable to
hard-code into POV-Ray.
Date: 28 Oct 2016 02:47:24
Message: <5812f47c$1@news.povray.org>
Isn't df3's created by tda2df3 part of the way there?
tda2df3.exe encodes the location and colour component, of each point.
With a bit of work with "DF3 Viewer Oosawa". The colour channels can be
separated and used by PovRay.
Regards
Date: 28 Oct 2016 03:04:17
Message: <5812f871$1@news.povray.org>
Am 28.10.2016 um 08:47 schrieb Stephen:
Not sure what you're referring to there; presumably some external tool,
but certainly not part of the official POV-Ray package ;)
So this probably doesn't qualify as whatever Mike had in mind when
suggesting that "POV-Ray should support point clouds".
Same with this one (though in this case I did manage to figure out what
that thing actually is ;))
Date: 28 Oct 2016 05:35:18
Message: <58131bd6$1@news.povray.org>
Well spotted. But then, you have the source code memorised. ;)
Are you sure we are talking about the same thing?
It seems to me that df3's are point clouds.
Oo! Tell me then, please.
I am lost.
Regards
Date: 28 Oct 2016 08:03:40
Message: <58133e9c$1@news.povray.org>
Am 28.10.2016 um 11:35 schrieb Stephen:
Pretty much so.
Nope. DF3 is a voxel format, which is an entirely different beast.
You can think of a point cloud as just the bare vertices of a mesh, with
no triangles to connect them up. Each point is explicitly specified by
its set of coordinates, and the points are the primary data (although
additional attributes may be associated to them, such as colours). Point
clouds are often used to represent an object's volume by providing
sample points on that object's surface (though there are also measuring
processes that generate data points all across a given volume), and this
type of point cloud data is often the raw output format of
professional-grade 3D scanning devices.
Voxel data, on the other hand, is the 3D equivalent of a pixel image: An
implicit regular grid of "volume pixels" (hence the term) covering a
(typically box-shaped) region in 3D space, and explicit attributes
associated with each and every voxel, with the attribute values
constituting the primary data. That data may represent pretty much
anything: Colour, pressure, heat, wind speed and direction, or whatever.
Representing an object's shape is just one possible application, in
which case each voxel's data will represent what portion of each voxel
falls inside the object's volume. Voxel data is almost always derived
from other input data (such as point clouds).
Date: 28 Oct 2016 09:12:41
Message: <58134ec9$1@news.povray.org>
> Pretty much so.
If I understand what you said. Voxel data can be or is a subset of point
cloud data.
So what is the problem with redefining coordinates in a df3 to points or
small spheres instead of a cubical volume?
To all intents and purposes the df3s I have made in PovRay. Act like
point clouds when using emitting media.
Regards
Date: 28 Oct 2016 10:21:24
Message: <58135ee4$1@news.povray.org>
> cloud data.
Yes, voxel data could just be thought of as point cloud data where all
the points are on a finite uniform grid (with no empty cells) within
known limits. In which case it becomes more efficient to store the data
as a list of values (colour, transparency, whatever) in some agreed
order, rather than listing the coordinates of every point.
Point cloud data is totally arbitrary, you could have points 1mm apart
in one area, but points meters apart in others. This is usual if you got
the data from a laser scanner. The coordinates of each point could be
anything (within the resolution of the number format you are using), so
are not on a grid or equally spaced at all.
Think in 2D, voxel data is like a bitmap image, whereas point cloud data
is like a list of 2D coordinates (perhaps with associated information
like colour as clipka mentioned).
My guess is all the algorithms used to render df3's won't work with just
an arbitrary list of point coordinates.
Date: 28 Oct 2016 11:09:56
Message: <58136a44$1@news.povray.org>
>> cloud data.
Yes, but how is the list ordered if at all, at all?
I never thought they would. But...
You could turn point cloud data into a df3 by defining a resolution and
using that to dived the cloud (magically by hard sums) into averaged voxels.
Not that I am asking anyone to implement this.
'Just exploring.
Regards
Date: 28 Oct 2016 12:45:01
Message: <web.581380818df1bb22b488d9aa0@news.povray.org>
I know we've touched on this topic, and you've even trimmed down the memory
footprint of the spheres - can you give me a better idea of the memory
difference?  I thought you had previously said there wasn't much of one, but
perhaps I misunderstood exactly what you were saying.
I guess I just have trouble seeing how this
  blob {
    threshold 0.6
      sphere { <.75, 0, 0>, 1, 1 }
      sphere { <-.375, .64952, 0>, 1, 1 }
      sphere { <-.375, -.64952, 0>, 1, 1 }
uses less memory than
      sphere { <.75, 0, 0>, 1 }
      sphere { <-.375, .64952, 0>, 1 }
      sphere { <-.375, -.64952, 0>, 1 }
Date: 28 Oct 2016 22:47:52
Message: <58140dd8$1@news.povray.org>
Am 28.10.2016 um 17:09 schrieb Stephen:
Exactly that: Not at all.
(There /may/ happen to be /some/ inherent ordering due to the way the
data is acquired, but you can't rely on that.)
> voxels.
Depending on what the point cloud actually represents, you /may/ be able
to use that approach.
If it is just a bare point cloud representing a surface, then there's
obviously nothing to be averaged.
