POV-Ray : Newsgroups : povray.off-topic : Mouth ulcers and chocolate Server Time
10 Apr 2026 09:31:53 EDT (-0400)
  Mouth ulcers and chocolate (Message 1 to 10 of 40)
Subject: Mouth ulcers and chocolate
Date: 23 Aug 2013 18:04:51
Message: <5217dc83@news.povray.org>
When you get a mouth ulcer, it makes sense that spicy and acidic foods
and drinks will hurt like there's no tomorrow.
However, one of life's little mysteries is that chocolate does that too.
It stings like hell. But why? Chocolate doesn't immediately come to mind
when I try to think of foods that would be especially irritating to a
mouth ulcer. What is it in there that causes so much irritation? Normally
chocolate feels so smooth and soothing, like silk. But to a mouth ulcer
it feels like sulfuric acid.
Subject: Re: Mouth ulcers and chocolate
Date: 23 Aug 2013 19:10:01
Message: <web.5217eaea918a91dc73fc9ebb0@news.povray.org>
I'm guessing it could partially be the theobromine, which acts as a vasodilator.
It might open up the blood vessels and cause swelling and irritation - the
opposite effect that caffeine has - which is a vasoconstrictor and reduces the
swelling in the brain so it's not grinding up against the inside of your skull
when you have a throbbing headache.
Chocolate is also known to contain oxalic acid, which I'm guessing is the main
culprit.  It will instantly combine with calcium in your blood to form
needle-shaped calcium oxalate crystals which produce an intense burning
sensation in the mouth.
Get some Anbesol, or see if some tea or coffee (tannins) will form a protective
coating over the affected area.
Date: 24 Aug 2013 04:02:16
Message: <52186888@news.povray.org>
Almost *any* substance will have the wrong osmolarity compared to body
tissues, so almost any substance hurts when poured into an open wound.
(About the only exception is suitably concentrated saline.)
The thing about chocolate is that it's very sticky; it coats things, and
clings to them. So once you get it into the wound, it's quite hard to
get out again.
(Fun fact: The bodily fluids of almost every large land animal have
almost exactly the same salinity as sea water.)
Date: 24 Aug 2013 06:55:27
Message: <5218911f@news.povray.org>
Am 24.08.2013 10:02, schrieb Orchid Win7 v1:
Fun fact #2: The above "fact" is anything but.
The origin of this popular myth is probably that it has been suggested
that the salinity of mammalian bodily fluids resembles that of the
/primordial/ oceans, back when life first evolved.
Today's sea water is about 4 times more saline than human blood.
Date: 24 Aug 2013 14:01:15
Message: <5218f4eb@news.povray.org>
This claim is surprisingly hard to confirm or refute. The trouble is,
there are many, many different ways to measure how salty something is.
Consequently, I'm struggling to find anything that quotes the two
measurements in the same units, or even using the same dimensions.
Regardless, I'm still waiting to hear why the hell the sea has *any*
salt in it to start with... I never did understand that part.
Date: 24 Aug 2013 15:42:03
Message: <52190c8b$1@news.povray.org>
Am 24.08.2013 20:01, schrieb Orchid Win7 v1:
A detailed per-element list can be found in this article:
http://www.answersingenesis.org/articles/arj/v3/n1/sodium-chloride-abiogenesis
See table 1 there.
Yes, that's a creationists' page, and the quoted paper appears to be a
creationist's, too, but I see no reason to doubt the numbers they're
quoting, as the general order of magnitude appears to match numbers from
Wikipedia:
(1) The salinity of blood can be inferred from that of medical "normal
saline" solution:
"The solution is 9 grams of sodium chloridre (NaCl) dissolved in water,
to a total volume of 1000 ml. [...]. It has a slightly higher degree of
osmolarity (i.e. more solute per litre) than blood [...]."
(http://en.wikipedia.org/wiki/Isotonic_saline#Normal)
(2) The salinity of salt water is given expressively:
"Seawater has a salinity of roughly 35,000 ppm, equivalent to 35 grams
of salt per one liter (or kilogram) of water."
(http://en.wikipedia.org/wiki/Saline_water)
Never heard of minerals being washed down by rain into the oceans?
Date: 24 Aug 2013 15:52:37
Message: <52190f05@news.povray.org>
> See table 1 there.
> Wikipedia:
Given the propensity of creationists to lie, distort and misinterpret in
order to promote their religion, that puts into question anything that
they write, even if they are just quoting facts.
I would avoid quoting even facts from that source, and instead quote them
from a more reputable one.
Date: 24 Aug 2013 16:29:36
Message: <521917b0$1@news.povray.org>
> Wikipedia:
> saline" solution:
So 35 g/L verses 9 g/L, basically.
[You see what I did there? Because blood is mildly basic, right? Right??]
I've _heard_ this suggestion, but since salt doesn't occur anywhere on
Earth except in the sea, that doesn't make a lot of sense...
Date: 24 Aug 2013 16:57:12
Message: <52191e28@news.povray.org>
Um what?
http://chemistry.about.com/od/acidsbases/a/aa110204a.htm
And:
https://en.wikipedia.org/wiki/Bonneville_Salt_Flats
Jim
Date: 24 Aug 2013 18:04:49
Message: <52192e01$1@news.povray.org>
Am 24.08.2013 21:52, schrieb Warp:
>> See table 1 there.
>> Wikipedia:
The same thing can be said about most scientific studies as well (except
that there it's not about promoting a religion, but the sponsor's
interests).
As long as it's plain, easily verifiable numbers, I see no reason to be
wary of creationists than of anyone else (as long as it's not the type
relying primarily on populism, but rather the one trying to give
themselves an air of serious science). After all, they have no interest
in making themselves too easily refutable.
I'd have prefered some other source myself, but either there aren't any,
or they're drowning in an overabundance of creationist sources. (Or I
just used the wrong search terms on Google.)
