POV-Ray : Newsgroups : povray.off-topic : Skyrim...! Server Time
14 Aug 2026 04:43:07 EDT (-0400)
  Skyrim...! (Message 1 to 6 of 6)
Subject: Skyrim...!
Date: 8 Apr 2013 02:08:35
Message: <51625ee3$1@news.povray.org>
So, more than four months after it was suggested that 'oh hey that'd
look good as a vector-based', I have a not-yet-complete version.  Needs
bathymetry, tree cover, and touch-up on a few labels of water bodies.
And probably a few items from Dawnguard since I think I missed those.
http://anybook.anysize.org/~kasuga_kyousuke/Skyrim.svg
...pity there's not an easy zoom/pan functionality built directly into
Firefox/IE.
Not sure if I'll bother with doing a mineral survey at some point or not.
Tim Cook
http://empyrean.sjcook.com
Subject: Re: Skyrim...!
Date: 8 Apr 2013 03:35:00
Message: <web.516272e7437460785b7d07940@news.povray.org>
Looks excellent! Really interesting result. Are the building plans taken from
the wiki maps or similar?
I had no idea Labryinthian was so big... I should go back there and explore...
as you say, would be good to see the forest cover, and you're right, I think the
mineral deposits would probably just clutter it.
good work :)
Date: 8 Apr 2013 12:24:28
Message: <5162ef3c$1@news.povray.org>
Yeah.  The UESP map is the primary reference for the exact placement of
the Skyrim roads, shore, and the buildings (the whole thing at a few
levels out stitched together for the big-picture and shoreline, zoomed
in for more accurate building footprints).
Labyrinthian's not so bad, most of that is platform.  What boggles me is
how honkin' huge the exterior of Bleak Falls Barrow is.  Completely
out-of-scale compared to basically everything else, even considering
that the scale of the buildings is not the same as the scale of the
terrain as far as canon-distance is concerned.  Interior of it doesn't
match up at all with its exits, either.  (I'd put down the underground
areas of Embershard Mine and Helgen Keep in another layer, since those
can be tied nicely from point A to B, but gave up once I saw that other
interior spaces had nothing to do with Outside Geography.)
Mineral survey would be done as a sort of separate thing, rather than
having the map show individual points, trying to see if it'd be possible
to interpolate between ore deposits into contiguous veins.  Looks
semi-promising from what I poked around on the UESP map, but it'd become
a separate map.
Tim Cook
Date: 9 Apr 2013 03:45:00
Message: <web.5163c55a437460785b7d07940@news.povray.org>
> What boggles me is
Oh yeah, I hadn't noticed that. Maybe because it's the first dungeon you get
offered in the game? Make it nice and impressive for those just starting out...
I guessed that would be the case for most interiors.
I'd love to see a Blackreach overlay, if only to see how badly it matches up.
There's several direct surface access points IIRC, plus the three dungeon
entrances (all several zones each, so I'd hold out no hope for alignment there).
> a separate map.
Interesting, it never occurred to me the designers might try to do that :)
There are some other 'elsewhere' exteriors too, like Sovngarde... Ever think to
have a go at them too, or are they too small to bother with?
Bill
Date: 9 Apr 2013 22:52:44
Message: <5164d3fc$1@news.povray.org>
Tried it.  It doesn't line up, which is dumb.  Even adjusting the scale,
the locations of the Great Lifts, particularly Bthardamz, aren't in the
same pattern.  Suppose could cheat and say the lift shafts are at an
angle through the ground.
>> a separate map.
If you've got Hearthfire, it's interesting to note that the clay
deposits are all along river banks and such.  You can go in the UESP map
and search for different ore veins even when zoomed fully out and page
through them 50 at a time to get an idea of how they're set up.
Well, I'd like to expand the map to include the rest of the Tamriel
worldspace...eventually...(it covers half of Hammerfell, Morrowind, and
down to just north of Valenwood), but unless they did some major changes
for Dragonborn, Solstheim...isn't even where it ought to be on the world
map.  Either it's closer to Vvardenfell and rather smaller, or it
doesn't exist at all.
Tim Cook
Date: 20 May 2013 06:27:36
Message: <5199fa98$1@news.povray.org>
So here's what I'm considering the finished product:
http://skyrim.nexusmods.com/mods/36159
It's not perfect, but it's good enough; the extent of the positive
feedback (and the fact that I somehow managed to make it to the current
top mods on the front page) is pretty mind-boggling.
(a bit of PR for POV-Ray in the comment where I overview the process for
making it, and a shout-out to S. Benge)
Tim Cook
