POV-Ray : Newsgroups : povray.off-topic : Finding a good VM Server Time
16 Jun 2026 09:47:46 EDT (-0400)
  Finding a good VM (Message 8 to 17 of 37)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Finding a good VM
Date: 27 Aug 2012 16:59:09
Message: <503bdf9d$1@news.povray.org>
On 27/08/2012 08:42 PM, Jim Henderson wrote:
> FWIW, I use VirtualBox on Linux pretty much daily, never have stability
> problems at all.
You never had it pop up and say "This process has performed an illegal
operation and must be terminated. Do you wish to send an error report"?
(Oh, well, I guess you wouldn't be seeing a Windows-specific error
message on Linux... But you get what I'm saying.)
You never had a VM working perfectly, and then the next day VirtualBox
utterly /refuses/ to start that VM? (Like, you click "start", and either
nothing happens or VirtualBox instantly crashes.)
You never had it refuse to delete a snapshot for no defined reason?
(E.g., you have a VM powered down, you take a snapshot, realise you
wanted to do something first, go to delete the snapshot you just made,
and it says "sorry, I can't do that Dave".)
> I'm also not sure what you  mean by "manag[ing] disks and VMs separately"
> - the GUI that I use (which is the default GUI AFAIK) doesn't do that.
When you create a VM, it asks to create a virtual disk. (Which isn't
surprising; VMware does this also.) But it seems to want to put all the
VM files in one place, and all the virtual disk files in another place.
And it asks me if I want to reuse one of my existing disk files. (Why
would I *ever* want to do that??) And when I delete a VM, this does
/not/ delete the disk image files with it. I have to manually do that
from the disk management window.
Maybe the GUI is completely different on Linux or something. But on
Windows, you can't even edit a snapshot description while the VM it
belongs to is running. (I can understand, from a technical perspective,
how that could end up not working. What I can't figure out is why the
heck nobody has fixed this. It can't be that damned hard...)
Date: 27 Aug 2012 17:15:53
Message: <503be389$1@news.povray.org>
>> problems at all.
Nope, never.
Nope, never.  I've even had my entire Linux DE crash on me and I've been
able to restart the VM when it came back up.
What version are you running?  Sounds like an old version maybe, or just
that the Windows version is garbage and you should use the Linux
version.  I've had nothing but good luck with the Linux version - enough
so that I stopped using even VMware Player.
Nope, never had it do that, either.
>> separately"
All of my VMs' disk files are with the configuration, but this actually
makes sense on a couple different levels, because you can do 'linked
cloning', in which case deleting the disk file would affect multiple VMs
(ie, it would break them).  But in the Linux GUI, you do have the option
when deleting a VM to also delete the disk files at the same time if
they're not linked/in use by another VM.
That works just fine on Linux.
Jim
Date: 27 Aug 2012 21:43:27
Message: <503c223f@news.povray.org>
On 8/27/2012 13:59, Orchid Win7 v1 wrote:
> asks me if I want to reuse one of my existing disk files. (Why would I
> *ever* want to do that??) And when I delete a VM, this does /not/ delete the
I think you just answered your own question.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 28 Aug 2012 04:32:04
Message: <503c8204$1@news.povray.org>
How so?
If you put the disks from one VM into another VM, then the other VM
*becomes* the first VM. All VMs are essentially identical; the disks are
the only thing that makes them different. Either you want to delete a
VM, or you don't. So deleting the settings file and then still using the
existing disks is a nonsensical thing to do.
Date: 28 Aug 2012 11:18:36
Message: <503ce14c$1@news.povray.org>
> How so?
Not if the disk is a data disk, or is used as something other than the
boot disk.
Or if it's a base for multiple linked clones where you started from a
common base, but the clones are different.  It's not unusual at all, for
example, when testing networked setups of identical OSes to create a
common base image and then customize multiple linked clones.
Jim
Date: 28 Aug 2012 12:03:19
Message: <503cebc7$1@news.povray.org>
> boot disk.
Wouldn't you just clone the disk for something like that? (Otherwise
only one VM can access it at a time.)
Then wouldn't each clone have its own local cloned disk image?
Date: 28 Aug 2012 13:22:55
Message: <503cfe6f$1@news.povray.org>
Am 28.08.2012 18:03, schrieb Orchid Win7 v1:
>> boot disk.
Virtual Box is pretty smart when it comes to saving disk space: When you
clone a disk image, it "freezes" the original disk's state into a save
point, and the clone will actually be a reference to that save point
plus a delta tracking any changes.
Likewise, the original disk will further on be managed as that "frozen"
state plus another delta tracking any changes made by /that/ VM.
(Note that a "frozen" state itself may already be a reference to an
earlier save point plus a delta.)
Date: 28 Aug 2012 13:56:53
Message: <503d0665$1@news.povray.org>
>>> are the only thing that makes them different. Either you want to
>>> delete a VM, or you don't. So deleting the settings file and then
>>> still using the existing disks is a nonsensical thing to do.
>> boot disk.
No, and no.
Linking the clone means that you don't waste the disk space with
duplicate data.
And no, only one VM can *write* to it at a time, but multiple VMs can
*read* from it at the same time.  Changes get written to a secondary file
that contains the differences between the combined images and the base
image - just like a snapshot.
Again, no.  That's not what a linked clone is.
I might be inclined to suggest "RTFM", as the VirtualBox and VMware
documentation both describe what a linked clone is.  Rather than assume
what it is and then make statements based on those assumptions, you could
actually learn what the idea is behind it.
Jim
Date: 29 Aug 2012 03:49:23
Message: <503dc983$1@news.povray.org>
Isn't this how /all/ VM products work?
Date: 29 Aug 2012 03:53:51
Message: <503dca8f$1@news.povray.org>
Oh, so now you're claiming that I don't know how VMware works?
When you create a VM, it starts with one file for the disk image. Each
time you take a snapshot, it stops writing to the current image file,
and creates a new file which is a delta against the previous one. When
you make a "full clone", it copies all the data. When you create a
"linked clone", it creates a new VM, but it's base disk image is just a
delta against the linked VM, just like a snapshot.
I don't know off the top of my head how Virtual Box does it.
I'm still not seeing why you would want to transfer a disk from one VM
to another - except perhaps, as you say, for data transfer (if you can't
get a more sane method to work).
