POV-Ray : Newsgroups : povray.off-topic : Universal Turing Machines Server Time
14 Oct 2026 21:30:22 EDT (-0400)
  Universal Turing Machines (Message 11 to 27 of 27)
<<< Previous 10 Messages Goto Initial 27 Messages
Subject: Re: Universal Turing Machines
Date: 7 Apr 2012 17:17:43
Message: <4f80aef7$1@news.povray.org>
On 4/7/2012 10:28 AM, Darren New wrote:
> That's why real computers can do things that
> Turing machines can't
Consider both Turing machines and "real" computers require very similar
encoding of a problem in order for a computation to be performed, what
are you viewing as the critical distinction between them?  After all
both essentially represent a problem as a string of symbols from an
alphabet.
Real computers can, of course, interact with the physical world in a way
that a TM can't, but I imagine that's not your point since it's a little
like commenting that there's no mathematical algorithm which returns a
sandwich as the result of it's computation.
Date: 7 Apr 2012 18:05:17
Message: <4f80ba1d$1@news.povray.org>
On 4/7/2012 10:34, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> Turing machines can't calculate everything.
>    Are there (provably) solvable problems that cannot be calculated with a
> Turing machine?
Sure. The algorithm for translating a Turing machine program into a UTM
tape. That's the idea. :-) It's an algorithm that humans can follow that
turing machines cannot.
Here's another: Navigating traffic.
http://www.youtube.com/watch?v=peDy2st2XpQ
A TM can calculate an answer *isomorphic* to the answer of an arbitrary
problem, but it can't solve the actual problem as stated. However, that's
pretty much begging the question, since the purpose of Turing inventing his
machine was to define the world "calculate."
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 7 Apr 2012 18:06:53
Message: <4f80ba7d$1@news.povray.org>
On 4/7/2012 14:17, Kevin Wampler wrote:
> require very similar encoding of a problem
I disagree that the encodings are similar.
> in order for a computation to be performed, what are
> you viewing as the critical distinction between them? After all both
> essentially represent a problem as a string of symbols from an alphabet.
Take, for example, quantum computers, for which this is untrue.
That too.
    in the cabinet."
Date: 8 Apr 2012 12:16:09
Message: <4f81b9c9$1@news.povray.org>
I was thinking more of existing computers, but you make a fair point.  I
still find the definition of "calculation" you're implicitly using a
pretty strange though, but to each their own.
Date: 8 Apr 2012 14:26:00
Message: <4f81d838$1@news.povray.org>
Well, the encoding in a real computer consists of varying levels of
electrons, movements of electrons, and/or positions of magnetic moments. In
a Turing machine, they're symbols. Real computers are analog.
> still find the definition of "calculation" you're implicitly using a pretty
Well, Turing machines were intended to offer a definition of computability.
So clearly Turing himself thought anything isomorphic to a computation also
counted as a computation. I just found it amusing that there re things we
have our computers do every day that a Turing machine can't do, including
programming universal turing machines.
    in the cabinet."
Date: 8 Apr 2012 14:50:40
Message: <4f81de00@news.povray.org>
  I don't really understand what the difference is.
  The only isomorphism I'm familiar with is graph isomorphism, and there
it's one of the strictest forms of graph equality. (Not only do isomorphic
graphs define the same language, but they are geometrically identical,
in other words they have the same amount of nodes and arcs, and there's
a one-to-one mapping between each one of them; if the nodes and/or arcs
are named, the names have to also correspond in the mapping.)
  It's hard to get any closer to identical than that.
Date: 8 Apr 2012 18:17:26
Message: <4f820e76$1@news.povray.org>
"isomorphic" means there's a one-to-one mapping from one thing to another
thing. But that doesn't make them the same. It just means there's a mapping.
So a WAV file might be isomorphic to the position of the speaker at each
given sample, but that doesn't mean a WAV file is an actual sound. It can be
mapped to an actual sound.
A Turing machine can decompress a representation of an MP3 file into a
representation of where the speaker would be at each given moment, but it
can't actually play the music.
    in the cabinet."
Date: 8 Apr 2012 22:14:54
Message: <4f82461e$1@news.povray.org>
> that there re things we have our computers do every day that a Turing
> machine can't do, including programming universal turing machines.
I think perhaps this is the crux of the difference in out viewpoints.  I
don't consider a "normal" computer as any more capable of programming a
UTM in the sense you seem to mean it than a normal TM is.  Both have to
operate on some encoding of the TM that the initial program is for, and
I don't see why binary digits represented by electrical means are any
less of an encoding than abstract symbols on a tape.
Date: 9 Apr 2012 01:39:50
Message: <4f827626$1@news.povray.org>
> don't consider a "normal" computer as any more capable of programming a UTM
A TM can't encode any sort of tape for any other TM.
> Both have to operate
> on some encoding of the TM that the initial program is for, and I don't see
> why binary digits represented by electrical means are any less of an
We're confusing two things here. One is that real computers can perform
computations that TMs can't, because TM's don't have cameras, microphones,
etc. One TM can't program another TM at all, because a TM can only write to
its own tape.
The other point is that humans can do things computers can't because we're
capable of encoding things directly from reality with our inputs. (E.g., we
can look at a hand-written representation of a turing machine program and
mentally turn it into an actual turing machine program without outside
assistance.)
I just found it amusing that programming a Universal Turing Machine is one
thing a Universal Turing Machine can't do without assistance.
    in the cabinet."
Date: 9 Apr 2012 04:12:04
Message: <4f8299d4@news.povray.org>
  I don't understand what that has to do with solving a problem. It sounds
to me like you are using a fallacy of equivocation.
Date: 10 Apr 2012 00:14:16
Message: <4f83b398$1@news.povray.org>
Em 09/04/2012 02:39, Darren New escreveu:
> microphones, etc.
Those are still tapes, minus time.  If you recorded all user input from
any device and fed it to a TM, it'd still work the same.  Interaction
means the TM waiting for more tape...
> can only write to its own tape.
I'm not sure I'm following, but this actually reminded me of programs
that output their own source code.  And virus...
Date: 10 Apr 2012 20:49:23
Message: <4f84d513@news.povray.org>
If the problem is "I want to know what song this is" or "I want to listen to
some music", then you haven't really solved the problem.
If the problem is "I have a TM program and I want to know what to put on the
tape of my UTM to run it", you can't solve that with a turing machine. :-)
    in the cabinet."
Date: 10 Apr 2012 20:53:00
Message: <4f84d5ec$1@news.povray.org>
>> microphones, etc.
No, they're really not. They're (possibly) isomorphic to a tape, but they're
not tape. That's my point.
 > If you recorded all user input from any
... you would need to use something other than a TM to do that.
For *some* meaning of "work." Certainly if you tried to do that with (say)
google's self-driving automobile, you'd be in trouble if the computer in the
car didn't have a connection to the laser eye thing.
I don't know how else to say it. If you have two turing machines sitting
next to each other in a room, the one can't program the other. By
definition, the I/O of a turing machine is too limited to allow that. The
output of one machine is not suitable as the program for the other machine.
It's really not all that deep. I just found it amusing when made
self-referential.
    in the cabinet."
Date: 11 Apr 2012 05:13:03
Message: <4f854b1f@news.povray.org>
  Why would pattern recognition or playing music be unsolvable in a TM?
  If you are talking about abstract problems (those which fall more under
the purview of philosophy) rather than problems that can be represented as
a program, you are committing a fallacy of equivocation (namely, you are
using two different meanings of the word "problem").
  My original question was: Are there *provably solvable* (in the mathematical
sense) problems that cannot be solved with a TM. (If you can prove them to
be solvable, then it kind of implies that you can present algorithms to
solve them.)
  Is it a provably solvable problem? If yes, then why cannot it be solved
with a TM?
Date: 12 Apr 2012 12:01:12
Message: <4f86fc48@news.povray.org>
Because a TM, by definition, has neither microphone nor speaker.
Given that "programmed on a TM" is the definition of "solvable", any answer
would be begging the question.
> solve them.)
Not necessarily. There are many non-constructive existence proofs. (I.e.,
there are many proofs of the form "this proves at least one X exists"
without telling you how to find that X.)
> with a TM?
Because the input to the problem can't be represented on a TM tape. If you
encode the input for a TM tape so a TM can solve it, you've just done the work.
    in the cabinet."
Date: 13 Apr 2012 04:45:41
Message: <4f87e7b5@news.povray.org>
  If you go that path, then a TM cannot solve *anything at all* because
it can't read anything from anywhere nor write anything anywhere or do
anything else.
  (If you try to answer "it can solve something that's stored on the tape"
then you are contradicting yourself because you just claimed that "by
definition" there's no interface to write external data to the tape for
the TM to solve. Thus by your "by definition" a TM does nothing because
there's no way to interact with it.)
Date: 15 Apr 2012 20:16:34
Message: <4f8b64e2$1@news.povray.org>
> the TM to solve.
There's no TM hardware to write to the tape. Presumably a human can also
read and write the tape.
Of course, mathematically speaking, yes, there's no way to interact with a
TM at all, but I think most people would consider eyeballing the tape and
doing some conversion into some useful results to be acceptable. But
eyeballs don't come with TMs, only with humans.
    in the cabinet."
