POV-Ray : Newsgroups : povray.off-topic : Hire car Server Time
16 Jun 2026 21:21:02 EDT (-0400)
  Hire car (Message 3 to 12 of 42)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Hire car
Date: 17 Oct 2011 11:31:56
Message: <4e9c4a6c@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Now, needless to say, they aren't exactly going to lend you a Ferrari
> 911 for a few months.
  I think you are confusing car manufacturers and models.
Date: 17 Oct 2011 11:33:51
Message: <4e9c4adf$1@news.povray.org>
...OK, they are *definitely* not going to lend you a Ferarri 911... o_O
Date: 27 Oct 2011 04:44:15
Message: <4ea919df$1@news.povray.org>
Le 17/10/2011 17:13, Invisible a écrit :
> - It does not appear to be possible to adjust the seats. I've never seen
> that in any car, ever. (You can move the seats forwards and backwards,
> but you apparently cannot adjust the back.)
On Opel Corsa (as Vauxhall is a sister-company in GM of Opel), you can
adjust the back with a knob (not a lever), on only one side of the seat.
And that knob (which has the size of a big hand) is usually hard as hell
to turn. (memory of Opel Corsa 1.7D... D for Gasoil/Diesel)
> - The dashboard has two identical dials on it. Obviously one is engine
> speed and the other is road speed. There is no way to determine which is
> which, except that the right-hand dial has a second scale printed on it,
> marked "kph" in almost illegibly tiny writing.
So at least you know it's the second one for the speed...
> - There is no temperature gage. Arguably you don't need one, but it
> would be nice to know when my hands are going to stop freezing.
Is there at least a heating air system ? And is it set correctly ?
Are the traps opened ?
> - It is not possible to turn the lights off. You can have sidelights,
> sidelights + headlights, or just headlights. But you cannot have no
> lights at all. Even if you're driving through Death Valley at high noon,
> you have to have your lights on, so you look like a complete tosser.
just thanks the laws...
> - The steering seems surprisingly heavy. I'm presuming it just lacks
> power steering; all the cars I've driven recently had that.
Guess what, a 1.2L is not going to have any assisted steering. That
would not be economic.
> The big, big issue, of course, is performance. Or rather, the utter
> absence of anything resembling it.
1.2L corsa is a petrol engine. As such, it's best performance is
probably in the 3000 to 6000 rpm zone. It has nearly no tork at lower
speed.
Such small price make no room for sound isolation, so it's noisy.
> Now obviously a 1.2 litre engine is never ever going to perform like the
> 2 lire fuel-injected engine I'm used to. It's just not gonna happen. On
> the other hand, when you drive down the road and lorries, buses and dump
> trucks are overtaking you, something isn't quite right there. :-P
the tests of 1.2 Corsa (old or twinport) says; 0 to 60mph in 12s or
11.8s. You have to learn the gearbox to stay in the power zone of the
engine. The fifth gear is a cruise gear, on flat ground. you might need
to go back to fourth to get some reactivity.
In deed, web search told me: the engine has 80 hp at 5600 rpm, and
11.2mKg torque at 4000 rpm.
You need to push that engine so that the next gear start at least at
3000 rpm.
> The car has 5 gears. I eventually realised that when you get to a
> certain speed, a little light comes on warning you to change up a gear
> before you break the engine. And my god, the engine seems to struggle
> *constantly*! You know that sound an engine makes if you try to do 45
> MPH in first gear? This car sounds like that ALL THE TIME!! I don't
> *care* if the rev counter says it's only doing "20" and the engine
> red-lines at "70"; it STILL sounds like it's about to explode!
When the light blinks, you are already too far.
And as a petrol engine, it is exploding... half the rpm speed per cylinder!
Those who would give up Essential Liberty to purchase <br/>
a little Temporary Safety, deserve neither Liberty nor Safety.<br/><br/>
Benjamin Franklin
Date: 27 Oct 2011 05:13:10
Message: <4ea920a6@news.povray.org>
Isn't that how *all* cars adjust the seat back?
Yeah, when you eventually spot the tiny writing.
The heating system uses heat from the engine to warm the air. It doesn't
work until the engine is hot. Most cars have a temperature gage, so you
can tell when this has happened. (OTOH, usually you drive a few miles
before the needle lifts off zero.) Not critical, just irritating.
I'm not aware of any law that you have to have your lights on.
I've seen cars that turn the lights on automatically when it gets dark.
But I've never seen a car where you just cannot turn them off.
I did manage to get to 60 in less than 90 seconds on time... :-P
I tried staying in 4th gear, but the car stops accelerating when it
reaches 50. The only way to make it go any faster is to change into top
gear. Then it will, reluctantly, accelerate to higher speeds.
> 3000 rpm.
Assuming that "30" on the dial corresponds to 3000 RPM, the engine seems
very reluctant to go that fast, and sounds like it's going to die at any
second while revving that high.
Well, that happens at "25", which is presumably 2500 RPM. And you say
it's supposed to reach 3000 RPM before you change gear?
Date: 27 Oct 2011 06:01:42
Message: <4ea92c06@news.povray.org>
Not all cars. My current one as a lever to allow moving the back.
Pull the level, adjust the back, release the lever, done!
> I've seen cars that turn the lights on automatically when it gets dark. But I've
European Union Directive 2008/89/EC for all new cars after 7 February
2011 ( August 2012 for bus and truck).
UK had a regulations for new cars after 1 April 1987 to have dim-dip or
dedicated daytime running lamps, (with exception... ); Prosecuted in
1988, dim-dip is no more mandatory for UK, but many new cars from UK
have that functionality. It's no more mandatory, for the moment.. (in
1990+... and see now the European directive.)
Date: 27 Oct 2011 12:32:20
Message: <4ea98794$1@news.povray.org>
The heater in my car won't even blow air until the engine is warmed up. It's
nice, because you can set the temp, and when the engine warms up, the heater
turns on, and you don't have to think about it.
In the USA, they did studies and figured out it made a surprisingly large
difference in head-on collisions, so they made it a law you have "daytime
running lights."
Crossing death valley, you want to pass the truck, and you see a car way
down the road in the lane that handles oncoming traffic. Is that car coming
towards you, or is that car someone going the same direction passing someone
else?
Look at any car less than about 10 or 15 years old shipped to the USA.
   People tell me I am the counter-example.
Date: 31 Oct 2011 08:03:53
Message: <4eae8ea9$1@news.povray.org>
It's been like that since 1991 in Canada.  It DOES make other cars more
visible, even at high noon in the middle of Death Valley.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 31 Oct 2011 08:13:29
Message: <4eae90e9@news.povray.org>
> running lights."
> else?
  In countries where there's no such law (such as was the case in Spain at
least years ago) it seems that for some reason there's a natural aversion
to having a car's headlights on during daylight. If you drive with the
lights on, almost every single other car that you pass by in the other
direction will flash their lights at you.
  I don't really understand why. What exactly is the problem in keeping the
lights on? They don't burn out all that often even when they are always on,
and even when they do, it's not really a huge monetary investment. The safety
that it introduces is much more important.
Date: 31 Oct 2011 08:51:23
Message: <4eae99cb$1@news.povray.org>
> lights on?
It's like writing an email using only capital letters. Technically,
there's no problem with doing that. But socially, it's frowned on.
Generally the only people who drive around in daylight with their
headlights on are people with expensive cars who turn their lights on to
let you know that they're important and you should get out of their way.
In other words, arrogant morons with lots of money. Obviously, nobody
wants to be mistaken for those guys...
Date: 31 Oct 2011 09:08:57
Message: <4eae9de9@news.povray.org>
  So you would decrease safety in order to make yourself not look like a
hipster? Makes sense how?
