Subject: Re: Is this the end of the world as we know it?
Date: 12 Oct 2011 01:55:00
Message: <4e952bb4$1@news.povray.org>
On 10/11/2011 12:01 PM, Orchid XP v8 wrote:
>>> a product that you already have lying around and try to sell it to a
>>> completely different audience...
>> You'll notice that Blender is free, right?
> Sure. That doesn't mean it's well designed. ;-)
Often, if its like the first 10... or so versions after the "in house"
version, its pretty much a given that it *won't be* well designed.
Though, as the poor bastard that has to figure it out, and doesn't have
the original company to "help them" do that, design isn't necessarily
the problem so much as an inordinate need to know what drugs they where
taking when they wrote it, so you can inform the local equivalent of the
ATF, so they can keep an eye out for it on the streets.
Date: 12 Oct 2011 02:03:59
Message: <4e952dcf$1@news.povray.org>
On 10/11/2011 12:17 PM, andrel wrote:
> On 11-10-2011 21:08, Darren New wrote:
>> It also means it isn't being sold to a different audience than it was
>> built for.
> Missed most of the communication on Blender (lack of time forces me to
> stop reading deep down levels of long communications).
> Just dropping in here that Blender is very useable, provided that you
> work with it for some time. Unlike perhaps other software where the
> learning curve is shallower but much longer.
> I have two students now to create some models, one mainly using Blender
> and one Maya. We will be playing around for one month and then decide
> which one we are going to use for the rest of their internship. It is
> not a clear cut win for Maya so far.
In my case, I need something to "build with". All the other crap,
including the "paint on the mesh", is well.. either a distraction, or no
where near as close to "full" as I could get just mangling an image in
Photoshop, and trying to "fit" that to the UV of the object (not that
doing that is all that easy, if the mess, even unwrapped, is stupid
complicated). So.. I have something hard to learn, with 50 times the
features I need, and the ones it "does" have, are incomplete, in strange
places, or... well, not quite what I am looking for.
The sad thing is, since Linden Labs picked, for some strange reason,
Collada as its import mesh type, its also the only one that supports it
"natively", with having to convert. So, even if I had Rhino, I would
have to export from the "native" 3DM, to like OBJ, then, if Blender
supports that, maybe export to the right one, or, if not, load it into
something that exports to something Blender can use, or which the
Collada converter they suggest can convert "from", to the correct one.
All with my fingers crossed, that the result won't be a disaster.
I have been through this before, with POVRay, and 50 different formats,
no two of which where supported by every application, and some of which
where supported (and still are) by *none* of them. Like, a few mesh
formats where the last known converter was from the days when Raytracing
Worlds was published...
All I want is something to build meshes in, and has as many bloody ways
to do that as possible, without all the other stuff getting in the way.
Apparently, I am on the wrong planet to find that. lol
Le 11/10/2011 21:31, Orchid XP v8 a écrit :
> On 11/10/2011 08:21 PM, andrel wrote:
>> On 11-10-2011 21:15, Orchid XP v8 wrote:
>>>>> Uh, what's a serial terminal? Also, what's a kernel debugger?
>>>> you are showing your age.
>>> Well, yes... I thought it was common knowledge? :-}
>> Too young to have met with a VT100 and too old to have met Google.
> I was under the general impression that the VT100 was "expensive".
> Although I'm not sure exactly where I got that impression from. But
> anyway, rather too expensive for anybody to just have one laying around
> in their house...
VT100 was/is a CRT terminal, usually monochrome (either green or amber
display). As any CRT, it was expansive to manufacture.
It also had a keyboard (no mouse, you pervert) and a dedicated firmware
to handle a serial line (the 25 copper-line connector one) as DTE.
The serial line could be long enough to cross a few room.
Coupled with a relevant concentrator/server at the other end of the
serial line, you could ends up having multiple sessions at once on the
VT100, toggling between session with a set of keypress.
Display is 80x24 characters, usually ascii only. (or was it 80x25 ?)
Underline & Bold are possible, as well as inverse video, but not italic,
IIRC. It could also be able to flash (alternating video).
The expensive part is not the VT100, it was the computer you would
attach it to. No point in having a VT100 in everyhouse at that time.
The computing power of VT100 is nearly none, when Compared to
intelligent terminal such as IBM 3270.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
> Underline& Bold are possible, as well as inverse video, but not italic,
OK. So... this discussion started because it was pointed out that the
Amiga flashes the power light to warn you to press DEL on your serial
terminal to start the kernel debugger. Now given that the Amiga is a
home computer, how many homes have a VT100 just laying around?
Well, I guess a home user isn't going to be trying to run a kernel
debugger anyway. But how many business in the 1990s had a VT100 laying
around?
I gather Blender was originally impossible to work, and they've now
spent time on improving that. I don't think I've ever tried to use
Blender personally (but I may be wrong about that...)
>> RC4 has weaknesses concerning related keys. Also, the first few KB of the
>> keystream is quite weak. Also, the keystream has certain statistical
>> weaknesses. Also...
> Yep. I'm not saying it's the best protocol. I'm saying it hasn't been
> broken wide open as you seemed to be implying.
It just makes me twitchy, that's all.
On 11/10/2011 09:13 PM, Darren New wrote:
> On 10/11/2011 13:02, Orchid XP v8 wrote:
>> So Microsoft has secretly implemented an undocumented system to allow any
>> unauthenticated Internet node to bypass all security restrictions and
>> access
>> any port on a Windows PC?
> You mean the "secret" IPv6 standard documentation on how to do this
> tunneling?
The "secret" part being that they didn't warn anybody "hey, we've
implemented a new feature to completely disable the security of your
network".
>> (Although I still don't quite get how it can bypass a firewall that
>> doesn't
>> allow inbound traffic. Still, Wikipedia says it does, so it must be
>> true.)
> The same way IPv4 ssh does. It tunnels out first. It's not like anyone
> can connect to your machine that you don't know about, any more than
> returning IP packets from a TCP connection "bypass" your firewall.
Either it does allow more people to connect, or it doesn't. Make you
mind up!
The thing about NAT is that [in the default configuration] it allows
outbound connections only. Either Teredo tunnelling changes that
invariant, or it doesn't.
Date: 12 Oct 2011 12:17:33
Message: <4e95bd9d@news.povray.org>
On 10/12/2011 1:13, Invisible wrote:
> Now given that the Amiga is a home computer, how
The VT100 is not the only serial terminal. Anything that talks RS232 serial
is sufficient. You know, like, another Amiga, say?
How come I never get only one kudo?
Date: 12 Oct 2011 12:19:24
Message: <4e95be0c@news.povray.org>
> implemented a new feature to completely disable the security of your network".
It's no more disabling the security of your network than telnet or pop3 or
http is. You have to tunnel out before you can get any answers back.
Besides, it's part of IPv6. How much more do they have to warn you, other
than publishing it worldwide in RFCs?
> Either it does allow more people to connect, or it doesn't. Make you mind up!
Why don't you read up on how it works?
On 12-10-2011 7:50, Patrick Elliott wrote:
> On 10/11/2011 12:58 PM, Orchid XP v8 wrote:
>> On 11/10/2011 08:41 PM, Darren New wrote:
>>> On 10/11/2011 12:10, Orchid XP v8 wrote:
>>>> I suppose Windows also doesn't stop responding when you change your
>>>> TCP/IP
>>>> configuration settings?
>>> Um, no?
>>>> (Actually, that one seems to vary. On some
>>>> computers, you change it and it doesn't even blink. On others, you
>>>> change it
>>>> and have to sit there for multiple minutes before it wakes up again...)
>>> Maybe your DHCP server is hosed up or something?
>> It seems to be more common with laptops, so maybe it's related to Wi-Fi
>> or something... Or maybe I'm imaginig that part.
>>>> Since Explorer is 90% of the Windows GUI, that's not a particularly
>>>> drastic difference...
>>> Only if you don't interact with actual programs. Saying "the GUI locks
>>> up" on Linux, for example, means every program stops responding because
>>> you just crashed the X server.
>> OK. I can't change window [because the task bar isn't working, and
>> Alt+Tab isn't working], I can't open Task Manager to see what's
>> happening, I can't lock or unlock the screen [Ctrl+Alt+Del doesn't do
>> anything]. But sure, if I happen to have an application open, maybe it
>> stays running. [I haven't ever tested that.]
> This is actually possibly the case. I have had "other" things cause a
> similar result. Generally, they peg some process, or memory handling, or
> something to max, and only lock the application *causing it*. The
> problem of course being, if you are in the application that created the
> problem, the whole thing seems to stop bloody working, and you can't get
> out of it, to do anything else, including ctrl-alt-del.
That is what 'surprises' me everytime. How can you design an OS where it
is possible to prevent a task switch to a taskmanager. I assume it is
because it wasn't designed but grown. Still, by now they should have
solved that, I would assume.
To Andy: I have some programs that when fed enough input will apparently
freeze the machine, if I wait 5 minutes I get it back when the process
has processed the data. So, yes it stays running. Unfortunately that 5
can also be 2 or 20, there is nothing to indicate what will happen. In
defence of Bill, my Ubuntu version just crashes. It does not freeze the
machine, but it also gets nothing done.
BTW this is when reading a 1-2 million faces text file in into Blender.
And when going into edit mode after that and...
(but Maya can not even handle halve as much).
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
On 12-10-2011 8:03, Patrick Elliott wrote:
[snip]
The only thing I use Blender for is to build meshes. That works great
for me. My alternative would be something like Maya, but that has an
even more complicated interface (from a GUI point of view).
In the next few weeks I will use it too to make meshes, so I'll keep you
posted on the progress.
citizen per day.
I have used both the pre 2.5 versions and the post 2.5 versions (that is
really completely redesigned) and although I know this common complaint
I cannot confirm it.
citizen per day.
On 10/12/2011 13:31, andrel wrote:
> That is what 'surprises' me everytime. How can you design an OS where it is
> possible to prevent a task switch to a taskmanager. I assume it is because
> it wasn't designed but grown. Still, by now they should have solved that, I
> would assume.
It's really not too hard. Modern desktop OSes suck at scheduling disk I/O,
so if you're locked up because of disk I/O and you launch a new program,
you're going to be locked up.
Sit down at a Linux machine with 16G of RAM. Create a directory with
1,000,000 one-block files, then type "sync", then type "rm -r xyz;sync" and
watch Linux "lock up" for several minutes as anything that wants to touch
the disk waits for the sync to finish.
Same thing can happen if you have a whole ton of data paged out when you
terminate the application, as AFAICT both Windows and Linux will happily
page everything back in as it terminates the job.
> BTW this is when reading a 1-2 million faces text file in into Blender. And
Disk I/O sucks in every modern desktop OS. Android also "locks up" on
occastion for several seconds at a time, as some random program launches a
check for something online when you're in the middle of typing something,
for example.
Contrast with CP/V, a mainframe OS from the late 1960s, that ran on a
computer with *maybe* a 500KHz CPU running out of 256K of magnetic core that
happily supported 40 or 50 users before you started to notice any slow-down.
How? They had something like 30 or 40 different priority bumps depending on
what you were waiting for and what woke you up. Waking up from waiting for
free memory (i.e., someone else's page-out completing) vs waking up from
waiting for pages to page in vs waking up from waiting for a directory entry
to come from disk vs waking up when disk data has arrived vs etc all had
different priority bumps, including on whether you're in core, out of core,
finished your quantum last time, waited before your min-quantum expired last
time, etc etc etc.
> serial is sufficient. You know, like, another Amiga, say?
Oh, OK.
So what can you actually do with a "kernel debugger", anyway? Just look
around the machine's memory or something?
>> network".
> or http is. You have to tunnel out before you can get any answers back.
OK. So how is my statement that "you cannot log in to it from outside
the building" invalidated then?
Date: 13 Oct 2011 04:28:09
Message: <4e96a119@news.povray.org>
What I can't figure out is why no matter how many billion bytes of
physical RAM you have, Windows seems to swap stuff out to disk, even if
it isn't short of physical memory. Like, if you start up Windows, open a
few applications, walk away, and come back four hours later, as soon as
you touch anything, it starts desperately paging all the data back into
memory.
Um, why did it page it *out* in the first place?! I thought it was only
supposed to swap stuff out if the space was needed for something else?
>>> network".
Because you assume that the firewall/Nat will protect you for that purpose.
Local teredo will send packets from inside to the outside, using UDP...
and most firewall/Nat will track that as "open a temporary route for the
UDP answer". Ergo, you will be exposed.
The nice thing, is that you are not aware that teredo might or might not
send some packets... whereas usually for telnet, you asked for the
application and the connection.
Of course, you can argue that your firewall setting is using the
explicit whitelist only approach. But usually, that does not work.
you often need whitelist + tracking of outgoing connection... and there,
you're stuck with teredo.
Have a nice day.
around.
it's free.
>> it is
>> because
>> that, I
>> would assume.
> I/O, so if you're locked up because of disk I/O and you launch a new
> program, you're going to be locked up.
Might be, but why design it this way? Why has cntrl-alt-del not a higher
priority than disk-IO and indeed any other program/process? (and on
really modern machines: why not dedicate one core to the OS and the OS
alone?)
> and watch Linux "lock up" for several minutes as anything that wants to
> touch the disk waits for the sync to finish.
>> Blender. And
> a check for something online when you're in the middle of typing
> something, for example.
> that happily supported 40 or 50 users before you started to notice any
> slow-down. How? They had something like 30 or 40 different priority
> bumps depending on what you were waiting for and what woke you up.
> Waking up from waiting for free memory (i.e., someone else's page-out
> completing) vs waking up from waiting for pages to page in vs waking up
> from waiting for a directory entry to come from disk vs waking up when
> disk data has arrived vs etc all had different priority bumps, including
> on whether you're in core, out of core, finished your quantum last time,
> waited before your min-quantum expired last time, etc etc etc.
IIRC also the Amiga did not suffer from virtual lock up (nor do I
remember it so badly from earlier version of MS-DOS).
citizen per day.
Date: 13 Oct 2011 14:48:13
Message: <4e97326d@news.povray.org>
Other stuff, like Windows Update or disk defragger, might have run in the
background. Note that processes like Superfetch are supposed to minimize
this effect. (I saw an interesting lecture on the changes they'd made to
prevent "back from lunch syndrome.")
Sure, but what's it going to do when it gets that keystroke? It has to fire
up the code that handles it, presents the UI, etc. *That* is what takes
time to page in.
> modern machines: why not dedicate one core to the OS and the OS alone?)
The core isn't the problem. The disk is the problem, because rescheduling
disk is slow. You can interrupt the CPU in a few hundred machine cycles. You
can't really interrupt a disk seek.
Indeed, I suspect if Windows figured out your startup programs, figured out
that you actually have more than enough RAM to load them all, and would just
load the entire file sequentially instead of letting them page in on demand,
you'd cut boot time tremendously.
> IIRC also the Amiga did not suffer from virtual lock up (nor do I remember
The Amiga didn't have demand paging, so you only suffered a long shut-down
time when you had allocated a lot of small chunks of memory and needed to
deallocate them before exiting. That happened on occasion.
Date: 13 Oct 2011 15:16:22
Message: <4e973906@news.povray.org>
> the background. Note that processes like Superfetch are supposed to
> minimize this effect.
I thought that's only in newer versions of Windows. I'm using XP here.
> they'd made to prevent "back from lunch syndrome.")
Yeah, I vaguely remember reading something like that... Can't remember
how I found it now.
http://blog.orphi.me.uk/
Date: 13 Oct 2011 15:55:17
Message: <4E974227.10306@gmail.com>
> fire up the code that handles it, presents the UI, etc. *That* is what
> takes time to page in.
So that moves the question to: why is the ctrl-alt-del handler paged
out? And the UI: why has that to be on the GUI, with all the page faults
that may result from swapping pixels to disk? Remember we are sending a
low level high importance interrupt and the user knows that.
I know. I am just asking if there is still a reason to handle the kernel
like any other user process.
> rescheduling disk is slow. You can interrupt the CPU in a few hundred
> machine cycles. You can't really interrupt a disk seek.
But, is there any reason to stop the entire kernel because of a disk seek?
> out that you actually have more than enough RAM to load them all, and
> would just load the entire file sequentially instead of letting them
> page in on demand, you'd cut boot time tremendously.
>> remember
> shut-down time when you had allocated a lot of small chunks of memory
> and needed to deallocate them before exiting. That happened on occasion.
That is true. And on many occasions it would still be sensible to load
no more than what you have as memory. At least I am normally only using
one large dataset at a time. Whenever it starts paging heavily I quit
anyway to rethink what I am doing.
citizen per day.
On 10/13/2011 12:55, andrel wrote:
> So that moves the question to: why is the ctrl-alt-del handler paged out?
How much of it do you want to keep in core? I've had very little trouble
getting the CAD handler to come up in things like Vista, but the next step
of picking something off the menu can cause a new program to get launched.
However, it launches task manager or some such in XP, I forget.
> And the UI: why has that to be on the GUI, with all the page faults that may
> result from swapping pixels to disk? Remember we are sending a low level
Well, yes. That gets handled right away, most likely. Then it has to *do*
something in response. I'm not sure what your point is. Your keystroke is of
course taken into the kernel pretty much immediately. It's the thing that
comes after I'm talking about.
The problem is not in the kernel's response. It's the fact that the
complaint is the task manager takes a long time to come up, preventing you
from killing the task.
In UNIX terms, it's like complaining that /bin/kill takes a long time to
load when the system is thrashing, and you asking why the kill() kernel trap
would be paged out in the first place.
No. Nor does that happen. Otherwise, disk seeks wouldn't continue to get in
the way?
Date: 13 Oct 2011 18:15:03
Message: <4e9762e7@news.povray.org>
IIRC, MS-DOS did not use paging nor virtual memory.
The main reason probably been that it was made to run on a computer
without any hard drive but just a single floppy or possibly two, at
least, initialy.
Some applications did implement some paging using internal or external
modules that where used only by a single application at a time.
Date: 13 Oct 2011 19:01:12
Message: <4e976db8@news.povray.org>
It also didn't have multi-tasking, so you didn't need to deallocate just
the
memory for the job that was exiting. You could just delete all the memory
allocated since the program started.
Date: 14 Oct 2011 12:28:58
Message: <4E98634F.50408@gmail.com>
To address most issues in one: you have normal operation in a system and
emergency situations. You should not design normal operations in such a
way that you can not handle emergencies.
What i'd do* is have the CAD handler (and a primitive task handler) in a
small space. Preferably in one self consistent page. Immediately suspend
all running user level programs and switch to vga to prevent the GUI
manager from page swapping.
*) at least without thinking all problems completely through.
> step of picking something off the menu can cause a new program to get
> launched. However, it launches task manager or some such in XP, I forget.
>> that may
> *do* something in response. I'm not sure what your point is. Your
> keystroke is of course taken into the kernel pretty much immediately.
> It's the thing that comes after I'm talking about.
> you from killing the task.
Because the task manager is implemented at the same priority level as
Blender?
> trap would be paged out in the first place.
Can that happen?
>> seek?
> in the way?
What apparently happens is that a program causes a page fault, possibly
holding up the kernel because it also needs a page. After the page is
loaded it then gets an opportunity to create another page fault before
the scheduler hands control back to the kernel.
My reaction as a user is: 'hello, I just pressed CAD, stop all other
programs and process that interrupt before doing anything else!'
Something is terribly wrong with the priorities of my machine.
citizen per day.
Date: 14 Oct 2011 13:09:03
Message: <4e986caf@news.povray.org>
> small space.
I think this is more like what post-XP OSes do.
> Immediately suspend all running user level programs
Always mount a scratch monkey.
You really don't want the guy at the keyboard hitting CAD and suspending
your corporate web server.
> and switch to vga to prevent the GUI manager
> from page swapping.
I don't think it goes that far, but certainly the newer CAD handlers could
do something like that, visually speaking.
> Because the task manager is implemented at the same priority level as Blender?
No it isn't. The problem isn't with the CPU. The problem is with the disk.
Now, the problem is that when the task manager pages in a page, now it's
going to run long enough for Blender to ask for a page. Now you've started a
disk seek, which you can't satisfy or abort before the task manager needs
its next page.
One simple solution might be to page in the entire task-manager task rather
than doing it on demand, but that's exactly the sort of "disk scheduling
sucks in modern desktop OSes" that I'm talking about.
> Can that happen?
No. That's my point. You're complaining CAD is unresponsive, when the
problem is that the user-level program you're trying to launch via CAD is
unresponsive.
The kernel doesn't need a page. That's why it's the kernel. The task manager
needs the page. The task manager is a user-level program.
Analogously, kill(1) doesn't need a page. But /bin/kill does, because it's a
user-level program, and it's the quickest way to actually invoke kill(1).
> After the page is loaded
> it then gets an opportunity to create another page fault before the
A page fault *is* handing control back to the kernel.
> programs and process that interrupt before doing anything else!' Something
Well, first, CAD is used for lots of stuff besides "I have too many page
faults". Second, you don't want anyone sitting at the keyboard to shut down
any process running on your machine. These *are* multi-user machines, you know.
>> small space.
Nor do you want him to effectively freeze it for 10 minutes by doing
something stupid. See also below.
>> from page swapping.
> could do something like that, visually speaking.
>> Blender?
> disk.
IIRC you have said that before. Actually several times and I have never
contradicted you.
> now it's going to run long enough for Blender to ask for a page. Now
> you've started a disk seek, which you can't satisfy or abort before the
> task manager needs its next page.
> rather than doing it on demand, but that's exactly the sort of "disk
> scheduling sucks in modern desktop OSes" that I'm talking about.
>> Can that happen?
> is unresponsive.
Actually my point is that it *should not* be a user program.
> manager needs the page. The task manager is a user-level program.
> it's a user-level program, and it's the quickest way to actually invoke
> kill(1).
I know that (long, long time ago I studied OS's a bit). I obviously
meant the part of the kernel (and user level program in badly designed
systems) that handles the CAD.
>> Something
> down any process running on your machine. These *are* multi-user
> machines, you know.
I disagree, there is no other user on my machine than me*. And that is
also why your corporate webserver is a wrong example. webservers and
user machines are something different. You should not mix those. Or at
least the OS should behave different. Specifically in the area that we
are discussing. CAD on a webserver should leave everything running
(probably should even be disabled), but when I press CAD on my keyboard
because I want control, i *want control* and I know what other processes
I am also stopping.
*) that is at least my view of the machine. Technically it is not true.
citizen per day.
Date: 14 Oct 2011 19:02:44
Message: <4e98bf94@news.povray.org>
Agreed.
>>> Blender?
>> disk.
> contradicted you.
Well, sure. But the problem is that nobody implements effective disk
priorities any more (which is what I'm saying), so just saying "priority"
implies CPU priority.
That's likely true. However, the frequency with which this happens probably
doesn't warrant a kernel mechanism for a UI for picking a task and killing
it, either. Especially since many times it happens, it's nothing to do with
a task that's still running that you could actually do anything about.
Indeed, it would seem what you'd really want is a way to indicate that if a
job got to the point where it was paging too often, that would be enough to
kill it or deprioritize its disk I/O, to the point of suspending it for a
second or more each time some other process went after the disk, sort of
like how Linux (seems to) does "low priority" disk I/O.
> I know that (long, long time ago I studied OS's a bit). I obviously meant
> the part of the kernel (and user level program in badly designed systems)
Oh, well, you want an entire process management system built into the
kernel, invocable by a simple keystroke. Probably not realistic in modern OSes.
> I disagree, there is no other user on my machine than me*. And that is also
> why your corporate webserver is a wrong example. webservers and user
If your corporate web server is thrashing, how are you going to stop it?
> OS should behave different. Specifically in the area that we are discussing.
> CAD on a webserver should leave everything running (probably should even be
> disabled), but when I press CAD on my keyboard because I want control, i
> *want control* and I know what other processes I am also stopping.
Well, as the Linux enthusiasts would say, "we eagerly await your patch." :-)
CAD should certainly not be disabled on a web server, as it does far more
than just bring up the task manager. That's the other half of the problem.
In pretty much every situation other than disk thrashing, CAD works pretty
much instantly. In many cases of disk thrashing, there's nothing you can do
about it, like my example of sync'ing gigabytes of changes to the disk. And
modern OSes are set up to treat file reading and page faulting as
essentially similar in many ways (and then there's memmap, which adds
another confusion on top), so it's not really even obvious when there's
thrashing which process is causing it or what to do about it, because it's
entirely possible there wouldn't be thrashing if there weren't 3 or 4
programs all doing something at once.
Well, that's kind of the point I'm making. :)
> probably doesn't warrant a kernel mechanism for a UI for picking a task
> and killing it, either. Especially since many times it happens, it's
> nothing to do with a task that's still running that you could actually
> do anything about.
> if a job got to the point where it was paging too often, that would be
> enough to kill it or deprioritize its disk I/O, to the point of
> suspending it for a second or more each time some other process went
> after the disk, sort of like how Linux (seems to) does "low priority"
> disk I/O.
> modern OSes.
Taking both points together. Breaking out to a program that just lets
you modify priorities would be enough. If that process runs at the
highest level itself it would solve most of the problems.
That said, windows does have a priority mechanism, and the taskmanager
is running at a high level, two levels higher than Blender and Matlab,
so why does it not work?
>> also
If it is because someone is using it for other things, like POVray,
Blender or a game fire that person. If it is because of tasks that
should run there fire the IT manager or the financial director,
depending on who was responsible for buying the wrong infrastructure.
>> discussing.
>> even be
Windows is open source now? I missed that.
> more than just bring up the task manager. That's the other half of the
> problem.
> pretty much instantly. In many cases of disk thrashing, there's nothing
> you can do about it, like my example of sync'ing gigabytes of changes to
> the disk. And modern OSes are set up to treat file reading and page
> faulting as essentially similar in many ways (and then there's memmap,
> which adds another confusion on top), so it's not really even obvious
> when there's thrashing which process is causing it or what to do about
> it, because it's entirely possible there wouldn't be thrashing if there
> weren't 3 or 4 programs all doing something at once.
citizen per day.
On 10/15/2011 2:08, andrel wrote:
> That said, windows does have a priority mechanism, and the taskmanager is
> running at a high level, two levels higher than Blender and Matlab, so why
> does it not work?
Because you're confusing disk priorities with CPU priorities, and you can't
easily interrupt a disk seek. That's kind of what I've been saying. In the
length of time it takes the Task Manager to get to the next page-in, Blender
has already run far enough to trigger a page fault on its own.
> If it is because someone is using it for other things, like POVray, Blender
> or a game fire that person. If it is because of tasks that should run there
> fire the IT manager or the financial director, depending on who was
But you might not know. And you might not be able to easily tell. And you
might be running multiple tasks on the same machine, or even multiple
operating systems nowadays.
No. Fix it in Linux. :-) Linux does exactly the same thing.
Date: 16 Oct 2011 18:22:44
Message: <4e9b5934$1@news.povray.org>
On Mon, 10 Oct 2011 11:11:45 +0100, Invisible wrote:
>>> So, just because it does strong authentication, you think that means
>>> the actual data is encrypted?
>> It's actually a certificate verification message, not a 'strong
>> authentication' message. It's asking about an SSL certificate that's
>> used to encrypt the entire communications channel.
>> You know, like actual security.
> Fact: It doesn't matter how strong the authentication process is. This
> does not automatically mean that the data that follows is encrypted in
> any way at all.
No, it doesn't - the fact that it actually *is* encrypted is what means
that it is, you know, encrypted.
>> Don't believe me? Fine, I'll do a wireshark trace on it.
>> Nope, 1200 packets, nothing in the clear.
> And how do you tell whether random binary data is encrypted or not?
There's nothing "in the clear". I connected to the system, opened a CMD
window, and listed directory contents.
That, plus the fact that it, you know, actually is *documented* to be
encrypted.
The fact that you don't *believe* the documentation doesn't, you know,
actually mean it's not encrypted.
How do you know your VPN is encrypted? Because it *says* so? What are
you, nuts? ;)
>> "128-bit encryption, using the RC4 encryption algorithm, as of Version
>> 6.
> RC4? Man, how ancient is that? You realise it was a weakness in RC4 that
> allowed WEP to be broken, right?
Yes, I do. However, *weak* encryption is still, you know, *encryption*.
>> Nope, I guess you're right. Adding 128-bit encryption isn't security.
> Fact: The number of bits in the encryption key is not directly related
> to how secure the encryption is. Triple DES has a 168-bit key, and it's
> widely considered far too insecure to use.
But it's still encryption. You asserted that it's not encrypted. I
proved that it was. Now, if you want to talk about encryption
*strength*, that's different than, you know, whether it's encrypted or
not.
>> "Support for Transport Layer Security (TLS) 1.0 on both server and
>> client ends (set as default)."
> Now that's more like it.
> (Sadly, on further investigation, it appears that TLS 1 still uses RC4
> or Triple-DES. So much for HTTPS being secure...)
But it's still *encrypted*, which you categorically claimed it wasn't.
>> Clearly I don't have a clue what I'm talking about.
> I'm still left wondering how many of these features are actually turned
> on by default. Every Windows protocol I know of sends everything
> unencrypted by default, and most of them offer no possibility of adding
> encryption. I'd be rather surprised if RDP is different.
Well, it's just documented as being enabled by default. Like your VPN.
How do you know your VPN is actually encrypted?
>> Oh, and I pointed you at an SSH server for Windows. It comes with
>> Cygwin.
> Right. I didn't know about that when I set this up.
You knew about it before you made this post. So now you know it's
available so you can use it. That is if you believe that SSH is actually
encrypted. After all, you just have the documentation to tell you that -
because it's a stream of random binary data. It may well not be
encrypted. You don't know. Just like RDP.
Jim
Date: 16 Oct 2011 18:23:50
Message: <4e9b5976$1@news.povray.org>
On Tue, 11 Oct 2011 09:00:11 +0100, Invisible wrote:
>>> Also, it contains far less information than a STOP message does.
>>> Basically
>>> an error code (plus textual translation) and a memory address. Good
>>> luck working out, say, what was *at* that address or anything...
>> That's why the power light flashes 3 times before the message comes up.
>> That's you're cue to hit DEL on the serial terminal plugged in to the
>> back to launch the kernel debugger.
*facepalm*
Jim
Date: 16 Oct 2011 18:24:46
Message: <4e9b59ae@news.povray.org>
>>> Now given that the Amiga is a home computer, how many homes have a
> Oh, OK.
Yes, that's exactly what a kernel debugger is for. Debugging the kernel,
hence the name. ;)
Jim
Date: 16 Oct 2011 18:25:39
Message: <4e9b59e3$1@news.povray.org>
On Mon, 10 Oct 2011 11:00:02 +0100, Invisible wrote:
> On 09/10/2011 10:00 PM, Jim Henderson wrote:
>> The point was that Andy said that binary blob data could be stored in
>> the registry and not a Linux configuration file. Point is, it could be
>> stored in a Linux data file, but since it's common to change
>> configuration items with an editor in Linux, it's not common to use a
>> binary format (though the timezone file is an exception to that IIRC).
> The point being, if you want to store some binary data in the middle of
> a textual configuration file, you have to base64 encode it or something
> (which is less efficient). If you want to stick some binary data in the
> registry, you can just store it as binary.
No, you don't have to encode it as base64. It's perfectly legal to
create a file with text components and binary components. Because it's
just a file.
Jim
Date: 16 Oct 2011 18:26:03
Message: <4e9b59fb$1@news.povray.org>
On Mon, 10 Oct 2011 10:00:49 -0700, Darren New wrote:
> On 10/9/2011 21:43, Jim Henderson wrote:
>>> I didn't catch that assertion. OK. It's fairly unique in being a
>>> standard searchable format with an API, but not in that it stores
>>> binary data.
>> grep -ri text /etc/*
>> Works pretty well for being a standard searchable format on Linux. ;)
> Without an API. Or transactions. And there's really no standard
> searchable format there besides "a text file". Tell me what standard
> Linux tool will give you a list of all the Document roots that Apache is
> serving.
grep.
Jim
Date: 16 Oct 2011 18:32:20
Message: <4e9b5b74$1@news.povray.org>
On Mon, 10 Oct 2011 10:42:46 +0100, Invisible wrote:
>>>> Well, yes and no. Users of SUSE products (openSUSE and SLE*) often
>>>> do know how to do the manual edits, but prefer using YaST anyways.
>>> If you pull up the documentation for (say) Apache, it won't tell you
>>> how to use the Apache YaST module. It will tell you how to edit the
>>> underlying text file.
>> If you use openSUSE for configuration, you use the openSUSE
>> documentation to see how to use YaST to make those configuration
>> changes.
> Wait - YaST has documentation?
Um, yes. man yast for starters.
>> And if that
>> doesn't get you where you need to be, you ask a question in the
>> community.
>> OSS is big about community.
> That sounds very nice and all, but if I'm trying to quickly set
> something up, I don't really want to have to go onto the Internet and
> beg for help, and then spend a week or two hoping that somebody
> knowledgeable will just happen across my message and actually take the
> time to give me a helpful response. I want to read a manual that tells
> me how to do this RIGHT NOW.
Right, you'd rather struggle with it for weeks and weeks and then bitch
about how difficult it is to do anything.
Instead of asking a question and getting an answer within a couple of
days so you can actually use it.
>> I guess I imagined all those Technet articles that have the warning I
>> sited earlier about how editing the registry can screw your system up.
>> That must be it, because of course Microsoft would *never* recommend
>> you do something that might bork your system.
> The warning is partly there because if you're a clueless user who
> doesn't know how to work a computer properly, it's very easy to do a
> hell of a lot of damage using a registry editor. Personally, I have
> almost never borked my system by editing the registry. The only time
> it's happened is when I started deleting stuff at random in a desperate
> attempt to make something work. If you follow the instructions, it works
> fine.
So, modifying it is dangerous. Or not. The warnings don't exist. Or
they do.
Gotcha.
> My point remains: It's very uncommon to /need/ to touch the registry in
> the first place. Whereas under Unix, the text configuration files are
> the first port of call, not the last. That's just the difference in
> design mentality.
Unless you use YaST, webmin, or one of a myriad of other Linux
configuration tools.
>> Obviously you don't know many Linux users. I know at least 5,000, and
>> many of them not only love and use the GUI, but tend to have religious
>> wars over which GUI is better.
> And yet, the vast majority of all Linux software is strictly CLI-only,
> and developers always seem to expect somebody /else/ to build the pretty
> front-end for it.
That's just incorrect. But since you believe it is, it must be true,
regardless of evidence to the contrary.
>>> I notice that there's always a lot of stuff "happening" with Linux.
>>> I'm never sure what the hell any of it actually /does/.
>> Linux (and most OSS software) evolves rather than going through
>> discrete cycles.
> Sure. The "release early and often" approach. I'm just saying, as an
> outsider, it's not always clear what actually changed between versions.
> (I guess often it's stuff under the hood that you won't notice anyway.)
Of course it isn't, that's what evolutionary development models do.
>>>> Transactionality is a function of the filesystem, and I use a
>>>> journaled filesystem.
>>> Doesn't stop two scripts both trying to update the same config file at
>>> the same time. If you do that with the registry, it works. Because
>>> it's a proper database engine, not just a flat file.
>> I'm not sure how "proper" that database engine is - IIRC, it's JET, and
>> most DBAs that I know would say that's certainly not a proper database
>> engine.
> JET is no match for an enterprise database engine, sure. But it's more
> transactional than a flat file.
> Also, I'm not completely sure that the registry is actually JET. It
> might be, but I didn't think it was. For one thing, registry files grow
> as needed, but never shrink. I don't think JET has that limitation.
FFS, *Active Directory* is (was) JET. Maybe they moved to something else
now, but I know from personal discussions with AD architects at Microsoft
that it is/was JET.
JET has been MS' solution for simple database storage for a number of
years, possibly decades.
>>> Personally, I'm not very impressed by the Windows Update system. Like,
>>> it'll install a bazillion updates for IE6 in the same session as it
>>> also installs IE8. And then you go back and it wants to install a
>>> bunch of IE8 updates. Um, why couldn't you do that the first time
>>> around??
>> Yep, I've been frustrated by that as well.
> I'd ask if Linux gets this right - expect Linux generally won't replace
> one version of an application with a totally different one just because
> you asked for security updates...
Depends on the distribution and the updater, but on openSUSE, that's true.
>>> I love how multiple courts have proved that what MS is doing is
>>> illegal, and as a result they have received NO PUNISHMENT OF ANY KIND.
>>> That's such a big motivation for them to stop casually disregarding
>>> the law...
>> Oh, I don't know, having to admit that Firefox is a reasonable browser
>> to use and they should change Windows architecturally to decouple IE
>> from it (or at least loosen the coupling) is a pretty significant
>> sanction.
> Admitting you're wrong is one thing. But they did something illegal;
> where is the *financial* pain for that?
Obviously you missed the fact that they paid fines to the EC for their
illegal activities. And they had to reengineer some things - and
engineers at commercial software companies don't tend to work for free.
>> Maintaining multiple versions of an entire operating system can be time
>> and resource intensive.
> Maybe it's there then. Still seems like a fairly tiny price for, you
> know, BREAKING THE LAW...
Go look at the fines they paid.
Jim
Date: 16 Oct 2011 18:34:12
Message: <4e9b5be4@news.povray.org>
On Mon, 10 Oct 2011 10:52:52 +0100, Invisible wrote:
>>> Oh, tremendously. But they're still a PITA compared to Windows'
>>> explorer, methinks.
>> Depends entirely on what you're used to.
> Not /entirely/, no. Many things are subjective, but not all of them.
When it comes to user selection of tools, yes, they are. If I find
something easy to use, who are you to tell me "no, that's not easy"?
>> In VMware, if you "pause" the VM, VMware grabs the state and commits it
>> to disk, freeing up the memory for other VMs. I find VMware's usage
>> makes a lot more sense.
> Personally, I'd prefer having two separate buttons for these functions.
> Sometimes I just want to pause a VM just for a sec so I can use the CPU
> power for something else. So I hit pause in VMware, and facepalm as I
> have to wait ten minutes for it to trash the hell out of my HD. The
> /entire/ computer is unusable until this finishes. And when I decide to
> unpause the VM, we go through the same dance again.
Yes, two separate functions would be good, I agree.
> Also fun: Pausing a VM makes the display go away. So it's useless if
> you're trying to quickly pause the display so you can *read* that error
> message that flashes past too fast to see...
I could see that being frustrating, having been there myself.
Jim
Date: 16 Oct 2011 18:39:20
Message: <4e9b5d18$1@news.povray.org>
On Mon, 10 Oct 2011 10:44:54 +0100, Invisible wrote:
>> A more appropriate comparison is latest against latest.
> I don't know how big the latest version of Windows is. I've never
> installed it. More to the point, I don't know of anybody who's using it
> yet.
Windows 7. You might have heard of it.
And I've got it installed in a VM, as I'd mentioned before.
>>> It's still frustrating that I have to download multiple GB of data for
>>> libraries that I'm not actually going to use, just because the package
>>> dependency system isn't a little more fine-grained.
>> You don't know that you're not going to use them.
> That's an absurd argument.
> If the PC doesn't have a sound card then I know, for a fact, that I
> don't need the sound daemon. If there are no Windows machines on the
> network then I know, for a fact, that I don't need Samba. I could go on.
Are you never ever ever ever going to install a sound card? Put your
machine on a Windows network?
It's a weak argument, I'll concede; it's not an absurd argument.
An absurd argument is saying that RDP isn't encrypted when every piece of
documentation about it says that it is. ;)
>> If you want something more specialized, you can do a custom
>> roll-your-own with SUSE Studio. No need to download anything you don't
>> want, because you build the distribution on a remote system using a web
>> browser, test it, and then download it.
> Now that's what I'm talking about... That sounds actually useful.
Indeed it is.
>>> Yes. Because spending a week trying to fix something it *totally* the
>>> same as just giving up and complaining about it. Oh, wait...
>> You spent a week trying to fix something that had you asked a question
>> in an online forum, you probably could've gotten an answer for in a day
>> or two.
>> And then you complained that you couldn't figure it out.
>> Yeah, ultimately, you gave up without asking for help. If you'd asked
>> for help, someone probably would've been able to help you.
> 1. You're assuming that it's /possible/ to fix this.
I'm basing that assumption on years of experience in troubleshooting
Linux systems.
You're giving up and assuming it's impossible to fix it, so why bother
even asking for help?
*That's* absurd.
> 2. You're assuming that had I asked, somebody would have actually
> bothered to reply. And that their reply would have been helpful.
Again, based on decades of experience in online forums. Is there a
chance of a useless answer or no answer? Sure. But I guarantee you you
won't get an answer IF YOU DON'T FUCKING ASK.
>> You don't need a super expert to explain it. You need someone with
>> more knowledge than you have to explain it. Plenty of normal everyday
>> non- technical end users manage to use it without problems.
> As I say, I can get Linux to /work/ OK. Indeed, my dad still uses it on
> a daily basis. It's just that one or two things - like getting the
> package manager to install just the packages I actually need - are
> annoyingly fiddly.
If you asked for help in understanding it, you might just learn something.
Heaven forbid *that* should happen. ;)
Jim
Date: 16 Oct 2011 18:42:13
Message: <4e9b5dc5$1@news.povray.org>
On Mon, 10 Oct 2011 09:55:08 -0700, Darren New wrote:
> On 10/9/2011 21:42, Jim Henderson wrote:
> > Are you sure about that?
> Pretty sure. Certainly people like suing Microsoft more than they like
> suing open source projects. :-)
You haven't been following the legal battles against Android and the
extortion Microsoft has engaged in over supposed 'patent infringements'
Linux has on Microsoft patents.
Something Microsoft rattles a lot of sabers over, but which they refuse
to be specifically precise about *which* patents are involved, because OSS
developers would work around that.
>> If Acrobat Reader crashed a Windows box, it would be Adobe's problem
>> regardless of if Microsoft distributed the file or if they got it from
>> Adobe.
> Yet, oddly, people blame Windows when a video driver crashes. Fancy
> that.
Odd that nobody's ever sued Microsoft over that (at least not that I've
heard of), but somehow there's a threat of that happening with Acrobat
Reader, apparently.
>> But a "repository" for Windows is just a "download" site. It doesn't
>> include actual software management elements per se.
> The management elements are built into the software you download. That's
> why, for example, you have things like "Programs\Common Files" and
> "Add/Remove Programs" and things like that.
> Now, yes, the fact that each program manages its own means you have to
> deal with legacy software repositories, so it doesn't always work as
> cleanly as it might. DOOM still installs to C:\DOOM or some such.
> However, there are actual software management elements available, *if*
> you want to make use of them. Many small projects don't.
Installation directories aren't "software management elements" - things
like dependency resolution are.
Jim
Android isn't open source any more. Let me rephrase and say that nobody sues
community-developed open-source that doesn't have multi-billion-dollar
companies backing it.
> Reader, apparently.
I'm just guessing. I can't think of any upside to Microsoft trying to run
their own repository if they don't get money from it. On the other hand, in
places where Microsoft takes a cut (a la xbox arcade) they do indeed run the
download servers.
That wasn't my point. There *are* dependency resolution things in installs.
Look at ClickOnce or MSI for example. It's just that people might have stuff
on their machine that did *not* come from a repository, and they won't
necessarily know how to fix it if you delete libraries out from under them
after 4 out of 5 applications using that library get uninstalled.
>>>> explorer, methinks.
I think it's safe to say that there are things that are easier for the vast
majority of people. If 99% of everyone finds A easier than B, and indeed if
B provides a subset of the functionality of A with more work, then B is
indeed superior to A.
For example, a UI that locks up the interface for 30 seconds each time you
insert a CD is inferior to an interface that is identical except doesn't
lock up when you insert a CD.
>> serving.
> grep.
And what expression would I give to grep to give me the list of document
roots that Apache is serving on my machine right now?
Date: 16 Oct 2011 18:58:47
Message: <4e9b61a7@news.povray.org>
On 10/10/2011 3:11, Invisible wrote:
> Every Windows protocol I know of sends everything unencrypted by
> default, and most of them offer no possibility of adding encryption.
Actually, every internet protocol up to about the invention of SSL sends
everything unecrypted by default. Including the Windows protocols.
Pretty much everything after SSL is encrypted.
Date: 16 Oct 2011 22:29:00
Message: <4e9b92ec$1@news.povray.org>
>> yet.
Wrong. Windows 8 is now close to out on the market, and *tries* to make
itself into a sort of cloudish, but not cloud, I wish I was a cell
phone, instead of a desktop, type mess. At least, based on everything I
have seen about it so far.. lol
Date: 16 Oct 2011 23:12:00
Message: <4e9b9d00@news.povray.org>
>>> is serving.
>> grep.
grep -ri documentroot /etc/apache2
Of course, you might've changed the apache2 config and not restarted the
server, so then instead you would use:
/etc/init.d/apache2 restart && grep -ri documentroot /etc/apache2
Jim
Date: 16 Oct 2011 23:15:42
Message: <4e9b9dde@news.povray.org>
>>>>> explorer, methinks.
> vast majority of people. If 99% of everyone finds A easier than B, and
> indeed if B provides a subset of the functionality of A with more work,
> then B is indeed superior to A.
> you insert a CD is inferior to an interface that is identical except
> doesn't lock up when you insert a CD.
It depends on the use case in most instances. I suppose there are
instances where one could say "yes, shooting yourself in the foot with
a .22 calibre pistol is more user friendly than finding an RPG to do the
job."
However, saying that using Explorer is easier than using find or locate
is ridiculous. I type much faster than I use the mouse.
Similarly, using voice commands with a phone might be faster for some
people, whereas using the touch interface might be faster for others.
Case in point, a friend of mine and I were looking up a phone number. He
used his blackberry and tried to say the name of the business. I used my
android phone and pulled up Google Maps and entered the name of the
business.
I got a result first.
Had he been in a quieter place, he might have gotten a result first.
If he'd been English, though, he might well not have received his results
first no matter what (I have heard from a few Brits that voice
recognition doesn't work so well for them).
There's no objective way to say which is "better" in this case.
Jim
Date: 16 Oct 2011 23:16:37
Message: <4e9b9e15@news.povray.org>
>>> it yet.
Windows 8 isn't the latest release version. Sorry, no cigar. ;)
"close to market" isn't "latest release". When Win8 is released, *then*
and only then does it become the "latest release".
Jim
Date: 16 Oct 2011 23:18:57
Message: <4e9b9ea1@news.povray.org>
> sues community-developed open-source that doesn't have
> multi-billion-dollar companies backing it.
I cited a counterexample, and you changed the criteria.
>> Reader, apparently.
> run their own repository if they don't get money from it. On the other
> hand, in places where Microsoft takes a cut (a la xbox arcade) they do
> indeed run the download servers.
They do indeed. I'm sure they could work out a licensing arrangement for
"approved by Microsoft" software if they wanted to, and take a cut for
distribution.
Apple does, after all.
> installs. Look at ClickOnce or MSI for example. It's just that people
> might have stuff on their machine that did *not* come from a repository,
> and they won't necessarily know how to fix it if you delete libraries
> out from under them after 4 out of 5 applications using that library get
> uninstalled.
So, that can happen on both Linux and Windows. I'm not sure what your
point is.
Jim
I was under the impression that
<DocumentRoot>
/home/me/blah
</DocumentRoot>
was a legal declaration of a document root, right?
And that it's possible to include configurations from other files?
And that it's possible to put configuration files in /etc/apache2 which
apache won't read?
