POV-Ray : Newsgroups : povray.off-topic : Memories Server Time
4 Jul 2026 13:17:04 EDT (-0400)
  Memories (Message 71 to 80 of 94)
Subject: Re: Memories
Date: 22 Aug 2011 11:07:27
Message: <4e5270ae@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> On 8/20/2011 11:55, Warp wrote:
> >    So no, you don't get it "almost for free". Not if you want a high degree
> > of accuracy.
> Actually, I think you do, if you keep the slope of the line positive and
> below 45-degrees. Then you use basic rotations of the algorithm to handle
> other cases. The trick is the line will never go through more than 2 pixels
> in the same column, so whatever doesn't go into the first pixel does go into
> the second picture.
  If the line is anything else than 0 or 90 degrees, it can cover a
triangular area of a pixel, not just a trapezoidal one.
  Also, likewise, both edges of the line can go through the same pixel
(unless the width of the line is at least sqrt(2).)
  Symmetries do not help here at all.
Date: 22 Aug 2011 11:09:24
Message: <4e527124@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> You realise that all of the quantities involved are rational, right? And
> that a rational number is just two integers?
  In practice the integers have a maximum value they can hold, so too much
precision in your rational value can easily overflow either (or both) of
the integers.
  (If you were to use integers of unbounded size, you might just as well
use floating point values. They would be faster too.)
Date: 22 Aug 2011 11:28:17
Message: <4e527591$1@news.povray.org>
> the integers.
Yes. But if the quantities you're calculating with are pixel
coordinates, overflow is highly unlikely to be a problem.
Date: 22 Aug 2011 11:53:18
Message: <4e527b6e@news.povray.org>
> > the integers.
  Except that we are talking about antialiasing here, which by definition
is calculating at subpixel accuracy.
Date: 24 Aug 2011 15:21:46
Message: <4E554F49.5090800@gmail.com>
On 19-8-2011 17:44, Jim Henderson wrote:
> On Fri, 19 Aug 2011 16:32:22 +0100, Invisible wrote:
>>>> ...but it was somewhat baffling to walk into a classroom and discover
>>>> that I know more about the subject than the lecturer does.
>>> Oh c'mon now!  Anyone who can think his way out of a wet paper bag has
>>> had this experience repeatedly. We're just socially trained not to say
>>> so.
>> What, that the person being paid to teach you something knows less about
>> it than you already do?
> Yes, it's not that uncommon.  In my case, it was an assembly language
> class I took in college - it started from how to use MASM, but I'd
> already used TASM quite extensively - but the course was a required
> course in my degree program.
Mine were e.g. in computer graphics related subjects. We had one teacher
that tried to keep ahead of the class by one week, but failed because of
over consumption of C2H5OH. To this day he is also the only person I
have ever met with a technical university degree that did not understand
the equation for a straight line.
The practical part was more fun, but we had a japanese arts student to
help us there...
The exam was a joke too, we could use our book and the questions were
like 'give the definition of...', 'what two problems are there when
using technique X'.
Aside: my main surprise in this was that the students from CS simply
accepted this level of teaching, many did not even notice.
Date: 24 Aug 2011 15:51:22
Message: <4e55563a$1@news.povray.org>
That was something that surprised me as well - but then again, when I
took my Assembly class, I had programmed in something like 15 different
languages - more than anyone else in the class - and had been programming
(even was paid to write code) since I was about 10.
So many CS students need that level of teaching, because they have
(perhaps) math aptitude, but not (a lot of) hands-on experience writing
code.
Jim
Date: 24 Aug 2011 16:39:30
Message: <4E556182.6040104@gmail.com>
> code.
A low level would be acceptable for that reason. But a guy that writes a
straight line and axes on the blackboard with a formula that does not
match what he has drawn? Adding that there is a problem with either
horizontal or vertical lines, because something might become infinitive
and choosing the wrong one (matching neither his formula, nor his
graph)? Or the assistant at the practical part that does not know the
difference between a variable and a parameter?
Nobody needs that level of teaching.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 24 Aug 2011 19:45:02
Message: <4e558cfe$1@news.povray.org>
>> programming (even was paid to write code) since I was about 10.
>> code.
> difference between a variable and a parameter? Nobody needs that level
> of teaching.
That's certainly true - what's being taught has to be taught effectively
*and* correctly.
Jim
Date: 25 Aug 2011 20:18:41
Message: <4e56e661$1@news.povray.org>
After further consideration, I think you're right, yes. :-)
   How come I never get only one kudo?
Date: 25 Aug 2011 20:20:39
Message: <4e56e6d7$1@news.povray.org>
Uh, no?  Sqrt(2) for a 45-degree line thru a pixel sort of thing?
That would be the "fixed point" part of my comment. Of course, if you want
high precision rationals, you might wind up with multi-word integers, at
which point you might as well just use floating point unless you're back on
8-bit hardware or something.
