POV-Ray : Newsgroups : povray.off-topic : Speedy thing goes in... Server Time
16 Jan 2026 02:59:56 EST (-0500)
  Speedy thing goes in... (Message 1 to 10 of 38)
Subject: Speedy thing goes in...
Date: 3 Jun 2011 16:30:40
Message: <4de94470$1@news.povray.org>
Okay, figure this out:
Since Update 10, Oracle's Java SE 6.0 comes with a tool called "Java
Quick Starter" (JQS). Its purpose? To speed up starting Java software,
by loading the most commonly used stuff ahead of time.
And loading ahead of time it does.
It does this not only once though, but - for whatever sake - every
bloody hour. Over and over again. The same bloody files. Which on my
system (maybe due to a sinister conspiration with the Anti-Virus
software I use) takes about 1 or 2 /minutes/ each time. Oh, and did I
mention that all this time it starves every other piece of software
running from hard disk I/O?
Heck, maybe it /does/ speed up startup of Java software, but seriously:
*I DON'T GIVE A BLOODY DAMN!*
Did I mention that the official procedure how to turn off this bullshit
mysteriously doesn't work on my machine? >_<
(Fortunately I stayed resolute and resourceful in an atmosphere of utter
pessimism...)
Subject: Re: Speedy thing goes in...
Date: 3 Jun 2011 17:40:50
Message: <4de954e2$1@news.povray.org>
and I bet it's documentation sux too ;-)
> pessimism...)
lol then ... I admire your half full glass (rather than empty) outlook
on things!
Date: 3 Jun 2011 18:40:55
Message: <4de962f7$1@news.povray.org>
Am 03.06.2011 23:40, schrieb Jim Holsenback:
Documentation?? *What* documentation??
>> pessimism...)
> on things!
Yeah; those 1-2 minutes an hour have been pestering me for months now,
until today I finally managed to identify the culprit... and nail it down.
*WIN!*
Date: 4 Jun 2011 02:31:36
Message: <4de9d148@news.povray.org>
> pessimism...)
  Someone has been playing too much... :P
Date: 5 Jun 2011 07:24:59
Message: <4deb678b$1@news.povray.org>
I'm pretty sure JQS has been there for years. Lots of software does this
(e.g., Acrobat Reader). The idea, presumably, is to load stuff into
memory ahead of time.
Except that isn't this the entire point of the Windows prefetch cache?
Also, won't the unused data simply get swapped back out to disk after a
while? (Thus utterly defeating the entire purpose of it.) Unless you
lock the pages in memory - in which case you're taking resources away
from applications that *definitely* need to run in order to benefit an
application which *might* need to run at some unspecified future point.
Personally, I dislike quick-starter services. They're a waste of resources.
OK, that's pretty screwed up. It shouldn't take anywhere near that long.
(Unless your AV product is decompressing all the JAR files to check
there's no viruses inside them...)
It's news to me that there's even an official procedure to turn it off...
> pessimism...)
Outstanding! You <subject name here> must be the pride of <subject
hometown here>.
http://blog.orphi.me.uk/
Date: 5 Jun 2011 07:25:25
Message: <4deb67a5$1@news.povray.org>
On 04/06/2011 07:31 AM, Warp wrote:
>> pessimism...)
What is this "too much" concept of which you speak? ;-)
Date: 5 Jun 2011 08:13:02
Message: <4deb72ce$1@news.povray.org>
http://www.thinkgeek.com/homeoffice/mugs/c7cc/action/215f43a/?cpg=160SS
Date: 5 Jun 2011 17:29:39
Message: <4debf543$1@news.povray.org>
I don't know how long, but I think that it was there with Java SE 5.x.
OR you reload the stuff periodicaly to reinitiate the countdown...
I share your opinion on those. I hunt them down, and kill them, as much
as I can.
1 - It reloads the files to prevent them been pushed on the page file.
2 - The AV is to agressive. Scanned files should be remembered, and,
unless they have been changed, skipped on the next scan.
3 - Yes, the AV need to uncompress and extract files from any archive if
it wants to scan it's content. JARs are compressed archives.
>> pessimism...)
> hometown here>.
If it's impossible to turn JQS off, then you kill the process, then you
delete JQS.exe.
Date: 5 Jun 2011 17:38:14
Message: <4debf746@news.povray.org>
>> resources.
> as I can.
If it works as intended, it's making one application faster by making
every other application in the system slower. How selfish is that?
Don't you just love the way most AV product insist on down periodic
manual scans?
1. If a file is never opened, it doesn't *matter* how's inside it. It
can't possibly run.
2. If a file is opened, the on-demand scanner will scan it anyway.
There's no need to do a manual scan as well.
3. I've yet to see any AV product which "remembers" which files it's
scanned and stops rescanning them unless they changed. (Presumably
because that would make it too easy for a virus to slip past; just tweak
the file timestamp...)
For that matter, I've yet to see an AV product that's any good at
*removing* malware. Most of them will *detect* an infection, but they do
an utterly crap job of *removing* it.
A Jar file is just a Zip file. (Actually, a surprising number of files
are just orginary Zip files...) But yes, if it's loading a lot of Jar
files, that would explain it. I don't know what JQS is loading. Maybe
just [uncompressed] executable files, IDK.
> delete JQS.exe.
That's probably not an especially good idea; the product repair routine
will probably restore it for you.
Actually, I just checked my system. JQS is a normal Windows service.
Just configure it to not run at startup. Done.
Date: 5 Jun 2011 17:54:33
Message: <4debfb19$1@news.povray.org>
>>> resources.
>> as I can.
> manual scans?
> can't possibly run.
Avast does it. It have a local database of files scanned and found sane.
They are excluded from autoscans for a set, and configurable, duration.
They are NOT excluded from scheduled and manual scans.
>> delete JQS.exe.
