POV-Ray : Newsgroups : povray.off-topic : Computer language quirks Server Time
29 Jul 2026 01:56:28 EDT (-0400)
  Computer language quirks (Message 14 to 23 of 33)
Subject: Re: Computer language quirks n C++ :-)
Date: 11 May 2011 15:01:13
Message: <4dcadcf9$1@news.povray.org>
In C++ it is supported at lead for function templates:
template<class T>
T foo(int x)
   if(x>10) {
      // ... do something interesting
      return foo<T>(x-1);
   } else {
      // ... do something else and finally
      return foo<T>(x*3);
int main()
    foo<double>(23);
    foo<void>(42);
				Lars R.
Date: 11 May 2011 15:13:24
Message: <4dcadfd4$1@news.povray.org>
Interesting!
   "Coding without comments is like
    driving without turn signals."
Date: 11 May 2011 15:57:32
Message: <4dcaea2c@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> I find it mildly distracting that I can't do this:
> void xyz() { ... }
> void abc()
>      if (...)
>         return xyz();
>      else blah blah blah;
  I assumed this to be so in C++ without actually checking. However, now
that I checked it, it seems to work. For example:
#include <iostream>
void bar() { std::cout << "bar()\n"; }
void foo(int i)
    if(i < 0) return bar();
    std::cout << "foo()\n";
int main()
    foo(1);
    foo(-1);
compiles and runs just fine.
Date: 11 May 2011 16:17:27
Message: <4dcaeed7$1@news.povray.org>
Huh. I wonder if that's just a GCC thing or whether that's actually in the
standard.  I just *actually* tried it with C# and I get "since XYZ returns
void, the return statement may not be followed by an expression."
Date: 11 May 2011 16:27:00
Message: <4dcaf114@news.povray.org>
  C# isn't C++...
Date: 11 May 2011 16:52:00
Message: <4dcaf6f0$1@news.povray.org>
>    C# isn't C++...
Presumably that's the whole point of C++. ;-)
Oh, wait...
http://blog.orphi.me.uk/
Date: 11 May 2011 19:19:36
Message: <4dcb1988@news.povray.org>
On 5/11/2011 13:27, Warp wrote:
>    C# isn't C++...
I know that. I'm just saying that I was surprised it worked in C++ because
everything I've ever read except the standard implies it shouldn't. Every
tutorial etc etc etc says "You can't put a value after a return in a void
function, and you have to put a value after a return in a non-void
function."  So it surprised me this was actually not true for C++. So I
figured I'd try specifically for C#, because maybe all the tutorials for
*that* were wrong. :-)
Date: 13 May 2011 03:44:28
Message: <4dcce15c$1@news.povray.org>
>> C# isn't C++...
> because everything I've ever read except the standard implies it
> shouldn't. Every tutorial etc etc etc says "You can't put a value after
> a return in a void function, and you have to put a value after a return
> in a non-void function." So it surprised me this was actually not true
> for C++. So I figured I'd try specifically for C#, because maybe all the
> tutorials for *that* were wrong. :-)
except that your "value" is actually a non-value by itself:
the function "bar" doesn't return anything, so if "foo" returns the
return-value of "bar", it also doesn't return anything.
I suppose it wouldn't work if "bar" really had a return-value.
cu!
ZK
Date: 13 May 2011 04:25:08
Message: <4dcceae4$1@news.povray.org>
>>> C# isn't C++...
> cu!
Hmm. Interesting point. Its possible that over the long time C++
compilers have been around a test was added to it, which simply tossed
the return functions, in cases where the result would never produce
output. Mind, a warning would have made more sense on those, at least.
Possible you might have an overloaded function, possibly, that would be
void in some cases, or return a value in others, thus it would be
perfectly reasonable to both get nothing from such a function, as well
as return something, in the case of bar(). Bar itself doesn't attempt to
return a value. The other one should, I would think, at least throw a
warning that you are trying to return a result in a function that
doesn't support it. Whether it should be an error, instead of a warning
though...
But, very odd.
Date: 13 May 2011 04:46:56
Message: <4dccf000$1@news.povray.org>
It would be possible in C where prototypes are not mandatory (but
overloading in C is not part of the language).
But I would expect a C++ compiler in C++ mode to barf on a change of
prototype will overloading or a return not matching the declaration.
The return function is not really a function: it put the value inside
the stack and then pop from the current function.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
