POV-Ray : Newsgroups : povray.newusers : Reducing memory usage Server Time
25 Jul 2025 10:51:42 EDT (-0400)
  Reducing memory usage (Message 1 to 10 of 12)
Subject: Reducing memory usage
Date: 29 Oct 2003 11:40:01
Message: <web.3f9fec9736065ca65c5446640@news.povray.org>
While rendering the demo image stackergold.pov, I noticed something I
thought was odd.  The memory usage continued to grow as the image rendered.
 In my very-newbie limited-understanding mode, I would have thought that
POV would setup all the objects in memory up front, and use them to
generate the image as it went along.
1) Can someone fill in the blanks for me as to why this behavior is so?
2) Depending on the reasons for the growing memory usage, can one then do
partial renders using partial data (I'm thinking here of very large meshes)
and combine them, where the entire data set would be too big to fit into
memory?
Thanks,
Dave
Subject: Re: Reducing memory usage
Date: 29 Oct 2003 11:52:02
Message: <co7571-0vn.ln1@triton.imagico.de>
Your description lacks an important thing - what makes you think the
memory usage of POV-Ray grows while rendering, i don't know any version
of POV that shows the change in memory use while rendering.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 29 Oct 2003 17:00:10
Message: <3fa0386a@news.povray.org>
>> rendered.
> Christoph
*cough* task manager *cough*
Date: 29 Oct 2003 18:31:12
Message: <3fa04dc0@news.povray.org>
In article <web.3f9fec9736065ca65c5446640@news.povray.org> , "David Jaquay"
Where do you think the image that is previewed and the messages in the
message window are stored?  And who said there are only objects in the
scene.  Radiosity and photons as well as numerous other things will be
generated while rendering.  All this needs memory.  It is not the plain
scene.
Besides, there is no accurate way for you to track the memory allocated by
POV-Ray, so you should not base any conclusions on the observation from
whatever source you used to determine that the memory allocation of the
application grows.
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Oct 2003 18:31:59
Message: <3fa04def@news.povray.org>
In article <3fa0386a@news.povray.org> , Brent G <pov### [at] bc-hqcom>  wrote:
But that doesn't show the memory allocated by the application.  It only
shows the memory used by the application process.  Besides, the user didn't
mention the platform POV-Ray was running on.
    Thorsten
Date: 29 Oct 2003 19:08:55
Message: <3fa05697$1@news.povray.org>
>     Thorsten
I was merely pointing out that is IS possible
Date: 29 Oct 2003 20:29:31
Message: <3fa0697b@news.povray.org>
  Strictly speaking all photons are generated between the parsing
and the rendering steps, and no new photons are created in the rendering
step...
Date: 29 Oct 2003 21:20:01
Message: <web.3fa0746dbb9f7a074e8cf70c0@news.povray.org>
>In article <3fa0386a[at]news.povray.org> , Brent G <pov### [at] bc-hqcom>  wrote:
This behavior shows up under 'top' on Linux, and task manager under NT; I've
run POV on both platforms.  And indeed, as another post mentioned, this
particular scene uses radiosity, IIRC.
So what about #2, in my original post?  Can I expect to render the image in
halves and get reduced memory usage?  (I suppose I can try it and see, but
I was hoping for an informed opinion, rather than experimental
guesswork...)
Thanks,
Dave
Date: 29 Oct 2003 22:26:52
Message: <cjameshuff-8E2B5F.22245329102003@netplex.aussie.org>
In article <3fa05697$1@news.povray.org>, Brent G <pov### [at] bc-hqcom>
But...your message doesn't do that. The memory allocated to the
application process is at best a very crude measurement of the memory a
program is using. This is a common mistake, Christoph's question was
perfectly valid, as was Thorsten's response.
http://tag.povray.org/
Date: 30 Oct 2003 04:12:02
Message: <4u0771-t43.ln1@triton.imagico.de>
No, stackerday and stackernight use radiosity, the others not.
> guesswork...)
I am pretty sure if the observation is correct you can reduce the amount
of memory shown by the windows task manager by rendering in several
parts - i can't think of any advantage of this though.
Rendering a scene in several parts is a common method for radiosity
scenes but this is a completely different topic.
