POV-Ray : Newsgroups : povray.newusers : Anti-aliasing Server Time
4 Jul 2026 19:07:15 EDT (-0400)
  Anti-aliasing (Message 46 to 55 of 55)
Subject: Re: Anti-aliasing
Date: 2 Apr 2002 12:51:43
Message: <3ca9efaf@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3ca9aeed@news.povray.org...
> > What about writing the same as function in 3.5 ?
>   How?
Its easy for mosaic filtering and subsequent resizing.
I will write such a macro to avoid future discussions.
But in my eyes correction of gamma, brightness or contrast are much more
bending the rules than the antialiasing methods in discussion.
By the way using Pov-Ray for filter effects one can do some nice effects.
Does anybody know the exact algorithm for Gaussian Blur?
How the image edges are processed?
Norbert
Date: 2 Apr 2002 12:55:57
Message: <u2sjausb7r0g011em62gir4o87q3561mq0@4ax.com>
On Tue, 2 Apr 2002 19:51:42 +0200, "Norbert Kern"
not exactly blur but uses general method for such kind of effects:
http://news.povray.org/p8r76u08vo673fksp4jaks59h2au3bppkb%404ax.com
ABX
Date: 2 Apr 2002 13:14:36
Message: <3ca9f50c$1@news.povray.org>
news:u2sjausb7r0g011em62gir4o87q3561mq0@4ax.com...
> ABX
thanx, but I thought more in the direction of a seperate pass for
postprocessing with Pov-Ray.
It is because proximity pattern is extremely useful in some cases, but it is
slow.
Norbert
Date: 2 Apr 2002 13:19:27
Message: <8atjauoiokuh7am873r6bckplh6bs3go5v@4ax.com>
On Tue, 2 Apr 2002 20:14:35 +0200, "Norbert Kern"
> "W?odzimierz ABX Skiba" <abx### [at] babilonorg> schrieb im Newsbeitrag
> > ABX
> slow.
as I said I wasn't reffering to usefulnes of proximity in the subject of this
thread but reffered to general method of applying filters - sampling one pattern
(image_map, object pattern, whatever), then apply some weighting/equation,
subsample if necessary, output new rgb
ABX
Date: 2 Apr 2002 13:59:43
Message: <3CA9FFA1.E7550D43@luxlab.com>
Jaime Vives wrote:
> The "artifact" or "moire"
> removing step is done with the previous gaussian filter, and *this is*
> postprocesing, not the resizing.
It's just another resampling filter. Look at the table.
http://www.genaware.com/html/support/faqs/imagis/imagis10.htm
Will all IRTC images that have been resized with other than
nearest neighbour method have to be disqualified now?
_____________
Kari Kivisalo
Date: 2 Apr 2002 14:06:33
Message: <3caa0139@news.povray.org>
  IMO the rule allowing resizing should be removed (and the FAQ changed
to the opposite of what it's now).
Date: 2 Apr 2002 15:31:27
Message: <3CAA1594.90509@ignorancia.org>
   Yes, technically speaking, it's a resizing (resampling).
   !? ...why? Resizing is allowed, at least for the moment.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 2 Apr 2002 15:43:19
Message: <oiqiau4c9m169usbtpqol03sieplqv9hru@4ax.com>
My thoughts exactly :) Neither Gaussian blur nor Mosaic should be very
hard to do in 3.5, esp. the latter. With the orthographic camera and
an image_map on a plane in front of the camera, one could almost as
much as make Warp happy :) <ducks>
I haven't really done much in POV recently... maybe I should play
around with image functions and try to recreate the post-processing
filters that were in MegaPOV. If RL permits, that is :(
Peter Popov ICQ : 15002700
Date: 4 Apr 2002 19:26:27
Message: <3CACEF39.31922A83@luxlab.com>
Jaime Vives wrote:
> (still, I can't get such good results even using the gaussian blur on
> "The Gimp"... he surely cheated even more! ;).
I tried both Gaussian filters in Gimp and can't get good results.
Use Photoshop :)
_____________
Kari Kivisalo
Date: 5 Apr 2002 02:46:39
Message: <3CAD56D9.8000301@ignorancia.org>
   Yes, results with the Gimp are only a bit better than +a0.0. Anyhow,
I will surely never use such technique, mostly because more detail on my
images usually helps to make my mistakes more visible... :(
> Use Photoshop :)
   Well, I don't have a valid plataform... ;) Also, it's perhaps
excessive for my little use of such programs... since I now use internal
height_fields and rarely use image_maps, I mostly use the Gimp to put my
sig and to convert to jpg.
