POV-Ray : Newsgroups : povray.general : Difference object that cant be scaled Server Time
21 Jul 2025 03:53:02 EDT (-0400)
  Difference object that cant be scaled (Message 1 to 8 of 8)
Subject: Difference object that cant be scaled
Date: 26 Apr 2004 07:07:57
Message: <408ced8d@news.povray.org>
Hi. I've got this difference object:
difference {   // a cylinder subtracted with another cylinder with smaller
radius -> a ring
        cylinder {
          <5, 0, 5>,
          <5, 1, 5>,
          1
          pigment { rgb <1, 0, 0> }
       cylinder {
          <5, 0, 5>,
          <5, 1, 5>,
          0.9
          open
    //scale <2,1,1>   is this the right place to insert the scaling?
if i try to scale it in x- or z- direction, the object simply fails to show
in the render. scaling i y-direction however, works fine.
why is this?
-greets,
    lars petter
Subject: Re: Difference object that cant be scaled
Date: 26 Apr 2004 07:20:02
Message: <c6ir4a$4he$1@chho.imagico.de>
You seem to have a wrong idea what 'scale' does.  What you probably want is:
difference {
   cylinder { <0,0,0>, <0,1,0>, 1 }
   cylinder { <0,0,0>, <0,1,0>, 0.9 }
   scale <2,1,1>
   translate <5,0,5>
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 26 Apr 2004 07:33:59
Message: <408cf3a7@news.povray.org>
> radius -> a ring
>         cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           1
>        cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           0.9
>           open
> show in the render. scaling i y-direction however, works fine.
> why is this?
Because your scaling scales the position of the cylinder. It's still there
but has moved to <10,0,5> (Scaled x by 2)
Better would be to define your object at the origin <0,0,0> and then
translate it to where you want it to be.
So
difference {
    cylinder { <0, 0, 0>, <0, 1, 0>, 1 }
// Make the inner cylinder longer then the outer one to avoid
// accidental surfaces
    cylinder { <0,-1, 0>, <0, 2, 0>, 0.9 }
// Move the pigment out of the cylinder definition so they both use it
// Here you apply scaling
    scale < 2, 1, 1 >
// Last you apply translation
    translate < 5, 0, 5 >
    //scale <2,1,1>   is this the right place to insert the scaling? Nope :)
Ger
Date: 26 Apr 2004 07:50:58
Message: <408cf7a2@news.povray.org>
Program ended abnormally on 26/04/2004 07:07, Due to a catastrophic lars petter
error:
> radius -> a ring
>         cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           1
>        cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           0.9
>           open
> why is this?
Others have already explained why.
You also have the problem of coincident surfaces as the ends of your first and
second cylinders are at the same place you should do:
difference {
   cylinder { <0,-1,0>, <0,2,0>, 0.9 }
   scale <2,1,1>
   translate <5,0,5>
This way, you will be certain that you object looks like a tube and does not
have artifacts at the ends.
Secondly, you put the pigment on your first cylinder only.  This makes the
second one have the "default" texture (black by default), so the inside of your
tube would be black, not red.  If you want the whole tube to be red, move the
pigment to the end of the difference block, like I did above.
Date: 26 Apr 2004 12:19:16
Message: <opr62nkrnmp4ukzs@news.povray.org>
On Mon, 26 Apr 2004 13:07:56 +0200, lars petter <lar### [at] higno>
> smaller
> radius -> a ring
>         cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           1
>        cylinder {
>           <5, 0, 5>,
>           <5, 1, 5>,
>           0.9
>           open
> show
> why is this?
> -greets,
>     lars petter
I've also been caught out by this; the help file states that scale is used
to change the size of an object or texture pattern with a origin sphere
example. IMHO an additional non-origin sphere to demonstrate how it also
affects the vector location(s) would make this a bit more obvious. The way
scale works makes sense if you stop and think about it, but it's not
something you you might stop and think of :)
Actually I'll post this to povray.documentation.inbuilt as a suggestion.
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 26 Apr 2004 12:36:17
Message: <408d3a81$1@news.povray.org>
Me so stupid=)
Thanks for the help!
-    Lars Petter
Date: 26 Apr 2004 13:28:56
Message: <408d46d8@news.povray.org>
In article <opr62nkrnmp4ukzs@news.povray.org> , Phil Cook
Well, even if you don't think about it, you should know that there has to be
some center of scaling.  And once you start thinking about where that center
could be, you eventually starting thinking about how scaling does work ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Apr 2004 05:14:00
Message: <opr63yj0e0p4ukzs@news.povray.org>
On Mon, 26 Apr 2004 19:28:55 +0200, Thorsten Froehlich <tho### [at] trfde>
>> used
>> way
> to be
> center
Which is how I worked it out, but only after being giving a large nudge in
the right direction. After that of course it's obvious.*
However by that measure it's obvious that there has to be some common
point of rotation for objects and that it is obviously the origin so all
the warnings and notes about how rotation works should be removed from the
help file :P
Phil Cook
*Well at least how it appears to work from the users perspective I don't
want to get into an argument with Christoph Hormann about how POVRay
really does it :)
