POV-Ray : Newsgroups : povray.binaries.utilities : Lightweight DXF to SDL converter Server Time
3 Apr 2026 05:36:43 EDT (-0400)
  Lightweight DXF to SDL converter (Message 1 to 10 of 11)
Subject: Lightweight DXF to SDL converter
Date: 12 May 2024 15:39:44
Message: <66411b00$1@news.povray.org>
Hi, folks !
While working on Gems factory:
https://github.com/syanenko/povgems
and Gems viewer:
https://gemview.povlab.online/demo.html
I was need a tool to convert geometry data (DXF), produced by:
https://www.gemcad.com
to SDL 'on the fly' under Ubuntu.
I've put it to repository for those, who will need it:
https://github.com/syanenko/dxf2pov
Happy poving :)
YB.
Subject: Re: Lightweight DXF to SDL converter
Date: 28 May 2024 16:09:44
Message: <66563a08$1@news.povray.org>
Il 12/05/2024 21:39, yesbird ha scritto:
> Hi, folks !
> and Gems viewer:
> Happy poving :)
A _brilliant_ work, indeed!
And - btw - Gems viewer site is well done.
Thank you,
    Paolo
Date: 29 May 2024 08:57:14
Message: <6657262a$1@news.povray.org>
Hi, Paolo.
I'm glad that you found it useful.
Always welcome :)
YB
Date: 5 Jun 2024 01:38:04
Message: <665ff9bc@news.povray.org>
Hmm, I missed that one before. I'm just trying to turn my old POVMosaic
into something reasonably structured (already compressed most of them in
two programs, most of others will be cancelled) with human-editable POV
output. So far it seems like your gem shapes are rather plugguble into
it as mosaic elements. Not going to copy your files, but, assuming I
will be strong enough with the Force to build a preview webpage for my
stuff to replace the old messy one, I'll definitely add a link. It would
be against my creed to leave good stuff unborrowed :-)
Ilyich the Toad
https://dnyarri.github.io/
Date: 5 Jun 2024 16:11:19
Message: <6660c667@news.povray.org>
Really interesting ! I've seen your mosaic works and like an idea to
play with orientation of elements. May be now it's a time to play with
geometry and materials also ?
>  Not going to copy your files ...
Why not ? You are welcome :)
> It would be against my creed to leave good stuff unborrowed :-)
Thanks, I've note it ).
YB.
Date: 6 Jun 2024 01:34:59
Message: <66614a83@news.povray.org>
If you wish, you may take a look at "develop" branch at
https://github.com/Dnyarri/POVmosaic
Well be merged to "main" as soon (or as long?) as I finish writing more
or less useful preview page for a site.
Can't resist - attached is an example of one of presets. Main idea of
this general rewrite is condensing most of controls I put at the first
time here and there into compact set of #define, supposedly easy to
understand (yeah, help file is still a bit smaller than a program
itself! great achievement for me!) and definitely easier to edit,
including the possibility to just link some preset.inc (the one for
attached image includes, beside dice thingie rotate instructions, dice
CSG itself) written in some more or less standard form.
There are also some predefined finishes and normals (the latter may be
modified on a per thingie basis to avoid getting perfect Empire clones).
Surely, predefined finishes are basic, but it may be changed.
I didn't try to use fully blown texture template since it will make
things overly complicated, but one can change my simple Python programs
any way he/she want.
But it will make your part of the whole pack bigger than mine, rising
questions who is actual author here :-)
Ilyich the Toad
Download '4pre2.png' (199 KB)
Preview of image '4pre2.png'
Date: 6 Jun 2024 12:53:38
Message: <6661e992@news.povray.org>
Yes, it looks promising, I like an idea in general and examples you
provided in particular. Using dices is a very good finding !
Nevermind - you can use it as you want. If this question is really
important for you - just rename variables and change the logic a little
and you will have your own code :).
Good luck,
YB.
Date: 24 Aug 2024 07:59:49
Message: <66c9cb35@news.povray.org>
Speaking of DXF - I'm completely unable to find any official info on DXF
coordinate system handidness. It seems like you just ignore it. Do you
know some secret truth hidden from me, or simply exploit the symmetry of
jewels?
Ilyich the Toad
Date: 24 Aug 2024 18:33:41
Message: <66ca5fc5@news.povray.org>
> jewels?
I am not sure that understand you well, but I was following this
document while writing the code:
https://images.autodesk.com/adsk/files/autocad_2012_pdf_dxf-reference_enu.pdf
YB
Date: 25 Aug 2024 02:36:03
Message: <66cad0d3$1@news.povray.org>
Oh, sorry, I just found it in ECS, it's right-hand. I'm using this
description you suggested, but, comparing to, say, OBJ, DXF is hardly
the most clean and logical format ;-)
Just wanted to add DXF export to my img2mesh. Considering stl and obj
exports already added in previous version, this will fully cover all the
non-POV formats I ever encountered.
Ilyich the Toad
