POV-Ray : Newsgroups : povray.binaries.utilities : df3 file utility Server Time
20 Mar 2026 11:35:30 EDT (-0400)
  df3 file utility (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: df3 file utility
Date: 27 Jul 2017 17:26:30
Message: <597a5a86$1@news.povray.org>
On 7/27/2017 6:20 PM, clipka wrote:
> Am 27.07.2017 um 16:58 schrieb Stephen:
>> On 7/27/2017 2:31 PM, jr wrote:
>>> the first tool, df3util, is now "feature complete"[1], documented,
>>> and builds cleanly from a regular source tarball.  it is a "Swiss army
>>> knife"-type utility, providing ten commands from the command-line.
>>> quoting from the man page, the program can "copy, merge, and recode DF3
>>> data, mirror, shift, and rotate it, and output informative summaries
>>> of volumes and their contents", and more.
>> You wouldn't happen to have a Windoze executable about your person or
>> something that could be run from a DOS box?
> Modern Windows 10 can build and run Linux software, thanks to the
> confusingly named "Windows Subsystem for Linux" (aka "Bash on Windows"),
> which is based on Ubuntu (14.04 if I recall correctly). IIRC there's a
> Windows setting to be frobbed first, and then the feature needs to be
> actually installed, but once that's done, a Unix terminal environment is
> at your fingertips. And ever since the Creator's Update, it even no
> longer crashes when trying to rename a directory.
Interesting, thanks.
Regards
Date: 27 Jul 2017 18:44:46
Message: <597a6cde$1@news.povray.org>
hi,
> Drat! I thought not. :(
> That means more reading and stuffing my overcrowded brain to the limits.
> [Or beyond. ;)]
if you're comfortable with DOS, and ignoring some fundamental
differences for the moment, you'll find your typical *NIX shell is a bit
like DOS on steroids.  I'm quite certain that with some reading and
trial + error :-) etc you'll transition quickly.
regards, jr.
Date: 28 Jul 2017 03:54:25
Message: <597aedb1$1@news.povray.org>
On 7/27/2017 11:44 PM, jr wrote:
> hi,
>> [Or beyond. ;)]
> regards, jr.
Thanks for the encouragement jr.
But it will take more than that to make me leave the dark side. ;)
I am comfortable with DOS and I take it out and look at it a couple of
times a year.
I hadn't thought about using a VM. I might put that on my list of things
to be done.
Regards
Date: 28 Jul 2017 09:20:00
Message: <web.597b397bc58fd36d16086ed00@news.povray.org>
jr <cre### [at] gmailcom> wrote:
> hi,
> some time ago I came across an animation of a fireplace on a website,
> done with povray and DF3s, really nice, still managed to lose the
> reference though :-(  anyway, that lead to a (fruitless) search for
> software to work with DF3 files and, eventually, to a decision to
> write my own "df3 tools".
Thanks, and great effort, but just so we know what's wrong with it from your
opinion...
Were you aware that Blender's POV-Ray exporter/importer uses a the DF3 python
library to use the format, previews in 3D view, and can also cache smoke in the
other Blender cache format?
Download 'file_blendertopovraysmoke[1].gif.htm' (15 KB)
Date: 28 Jul 2017 11:03:05
Message: <597b5229$1@news.povray.org>
hi,
>> hi,
> opinion...
not sure what you mean by "wrong with it" -- with what?
no, never used Blender.
regards, jr.
Date: 28 Jul 2017 12:31:25
Message: <597b66dd$1@news.povray.org>
hi,
>> opinion...
well I re-read the sentence, and still don't understand it.
I should, however, been more positive + thanked you; can I read "great
effort" to mean that you installed the program + played with it?  if
yes, I'd love to know which GNU/Linux + kernel version, and whether
there were any "hiccups".
regards, jr.
Date: 29 Jul 2017 18:30:00
Message: <web.597d0beec58fd36d61ea16670@news.povray.org>
> hi,
> >> opinion...
> regards, jr.
Sorry, I use Windows.
I meant to bring to your knowledge the existence of a tool you might have
ignored. and since you said you had a (fruitless) search for it, i figured maybe
you found it and still disqualified it for some reason, which i ask because
Lanuhum and I being contributors to the development of this tool (the Blender
exporter with DF3 support)...if we receive no feedback, we just can't know when
anything's wrong. Am I clearer?  :-)
Date: 30 Jul 2017 07:27:50
Message: <597dc2b6$1@news.povray.org>
hi,
> you found it and still disqualified it for some reason, ...
very much clearer Mr, thanks.  I only use Windows for web access and
running one (occasionally two) virtual machines, and have no other
s/wares installed on that machine.  my "fruitless" search appears to
have missed some programs (like the viewer Stephen mentioned), but no, I
never looked at Blender + its plugins at all, so cannot offer any
comment.  fwiw, I know exactly how the "no feedback, we just can't know
when anything's wrong" feels, fingers crossed for you + LanuHum.
regards, jr.
Date: 2 Aug 2017 04:15:01
Message: <web.598188f3c58fd36d61ea16670@news.povray.org>
> hi,
> regards, jr.
Thanks and the same to you.
Date: 3 Aug 2017 20:23:22
Message: <5983be7a@news.povray.org>
hi,
On 27/07/2017 14:31, jr wrote:
> ... "df3 tools".> there are still some problems:
still no homepage.  still no unified build.  and still no feedback wrt
building on other GNU/Linux platforms.
> ...  also, following a recent mention of
> R Suzuki's float extension in one of the povray newsgroups,
> I plan to add support for reading 'dfd' data.  however,
> without more specific information than is given on the website,
> some functionality (like '[Cyclic]') may not get included.
updated versions of both library and df3util are attached.  the library
now has "__attribute__((warn_unused_result))" on two prototypes
(df3_open_file + df3_create_file), and the df3Handle has been made more
robust.  df3util now has fewer bugs (I hope) and a partial
implementation of the Extended Density File Description format via a new
command: 'dfd'.  there's no "[format] binary" yet, "[cyclic]" must be
'off', and the program doesn't do any data interpolation (beyond my
abilities anyway).
enjoy, jr.
Download 'libdf3-0.2.1.tar.gz' (335 KB) Download 'df3util-0.3.8.tar.gz' (170 KB)
