POV-Ray : Newsgroups : povray.binaries.images : city buildings-- WIP 9_29_2020 Server Time
28 Sep 2024 17:40:29 EDT (-0400)
  city buildings-- WIP 9_29_2020 (Message 41 to 49 of 49)
Subject: Re: city buildings-- WIP 9_29_2020
Date: 5 Oct 2020 00:15:01
Message: <web.5f7a9cca32341a55d98418910@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> second h/d and place all '/tmp/' and working directories on it (faster i/f than
> USB).
and Bald Eagle wrote:
> You can also do that thing where you use a (cheap) USB drive to boost your
> memory - no idea how fast/slow that is, but it will save on the HDD thrashing.
At my 'advanced' age, these 21-century technological changes and improvements
are a bit slow to digest, ha. I'm not sure as to how all of this works. I do
have a 500GB Samsung USB external memory (a solid-state 'thumb drive'); can
POV-ray and all my files be loaded onto it and actually RUN from there? I would
imagine that a bunch of library-paths would need changing(?), at the very least.
And/or changes to the Windows registry(?) It's all a mystery to me, I admit.
Btw, I was told by a local computer-repair shop that my Win 7's HD could be
retro-fitted with a SSD, while keeping all of my files, the OS, etc intact. Hmm,
I wonder if that's true.
Date: 5 Oct 2020 05:20:01
Message: <web.5f7ae45b32341a55f5e85bab0@news.povray.org>
hi,
> > USB).
> are a bit slow to digest, ha. ...
get with it, granddad!  :-) :-)
go for it.  not only is the read/write performance so much better, you'll also
save money.  (here I moved two "always on" machines to SSD, and saw a small drop
in daily electricity consumption (amounting to ~4 pence per day); given the
than their cost over that time, ie 1825 days)
regards, jr.
Date: 5 Oct 2020 16:45:05
Message: <web.5f7b85ae32341a551f9dae300@news.povray.org>
> Using a single image_map, and *without* pre-#declaring the image,
> the parsing took a LOT of time (with constantly increasing memory use as the
> image had to be 're-processed' for each iteration.) By pre#declaring the image,
> the entire parse/render occured in mere seconds, with a much-reduced memory
> load.
Right, because the POV-Ray parser can't know that it's already red that image
file in, and so it re-reads it from disk, reloads it into a new memory slot,
etc...
> Yep, I agree. Sad to say, when I started working on this scene, I used jpg's,
> and have continued that way ever since. The reason being, that my OLD version of
> Photoshop has wonky problems with correct png gamma when saving an edited image.
> So no png's. But otherwise I LOVE my old version of PS; it's just easier to use
> (for me) than GIMP.
I have not found GIMP to be user-friendly.
In windoze I used wingif, winjpg, Irfanview, and paint.net
> > Buy more RAM -
> Ha! But that would defeat my purpose of trying to get me scene to run in, uh,
> 256K  :-P
I look forward to the Inigo Quilez Demoscene version in 8k.   :P
> > I ignored the people who said I couldn't put 16 GB of RAM in my
> > laptop after researching the issue. Been running fine for years.
> THAT'S interesting. Yeah, AFAIK, my Win 7 box has an 8MB limit(?), so I never
> thought of trying to increase it. So, my computer wouldn't actually explode,
> right??
It will just not be able to access the memory properly.
It's all very architecture dependent.  YMMV
Flip it over and have someone pop in different (but proper _type_) memory and
reboot it.  If it works (system stats report all the GB you installed are
recognized, then I'd buy it.
Date: 5 Oct 2020 19:05:01
Message: <web.5f7ba52c32341a55d98418910@news.povray.org>
Yes, Irfanview is handy. and fast. The others I'll have investigate.
> > > Buy more RAM -
> > 256K  :-P
I had to look that up :-O  And Shadertoy. WOW, some *stunning* procedural CG.
Meanwhile, just for a bit o' fun, I ran my scene code again as-is, but with 5000
buildings, the most ever-- just to observe the parse/render/computer
performance. On my lowly Windows 7 box: disk-swap hell!!
Download 'buildings_5000_10_5_20.jpg' (774 KB)
Preview of image 'buildings_5000_10_5_20.jpg'
Date: 5 Oct 2020 19:40:00
Message: <web.5f7bae2632341a551f9dae300@news.povray.org>
wingif and winjpg are OLD, but because of that, they are tiny programs and FAST.
If you can't find them, I will look and see if I have them archived anywhere.
paint.net is mammoth, and you have to install all of that .net framework stuff,
but I found it very useful - probably what GIMP should be in terms of usability
paired with capability.
I'd say that IQ has such a good foundation in what he does because of the
limitations of what he had to work with.   ALL the fat had to be trimmed and
everything had to be re-used to squeeze as much out of the code as possible.
I learn a LOT from studying the Shadertoy stuff because it's all written from
scratch.  Camera, light source, shadows, geometry, patterns, shading...
Find a used / surplus computer reseller - you can likely get something better
than what you have for ~$100  I haven't bought a NEW computer since .... 2008.
The way people go through technology these days to get the newest flashing crap
- you can pick up their discards for pennies on the dollar.  Yard sales, pawn
shops, Goodwill, classifieds, Ebay, Craigslist, .... I could probably find a
fully functioning laptop at the dump/transfer station up here if I went there
often enough...
It's been a while since I've seen the development of this project, but depending
on the resolution of the images, maybe you could replace some of them with
procedurally generated functions - esp if you're doing 5000 buildings - can you
really see the detail?
ATM, I've got 48,000 tiles making up a whole planet - there's no way I'm parsing
and rendering all of them if I don't have to.   That's the next phase, once I
get done with all of the Bezier editing.
Good work - I'm glad you're back, working on your projects, and having fun.
-BW
Date: 6 Oct 2020 10:39:29
Message: <5f7c81a1$1@news.povray.org>
>>>> Buy more RAM -
>>> 256K  :-P
Time to add some more RAM
Date: 6 Oct 2020 23:55:00
Message: <web.5f7d3b6232341a55d98418910@news.povray.org>
Or else to render less-complex scenes! :-P
I do like my old Windows 7 machine, but it has it's limitations, as I'm seeing
now... unless I try increasing the RAM 'over its limit' as Bald Eagle suggested.
Meanwhile, I just came up with a simple trick to make the *many* semi-repetitive
buildings look a bit different from each other: by randomly varying their
finish{diffuse...} values. I don't know why that idea didn't occur to me before.
It wasn't easy to implement, because of the way the building textures are
constructed-- but it turned out to be a simple code change in the end.
The effect may look subtle in this example image-- the buildings all use the
same window image_map and 'concrete' color-- but it looks quite nice when it's
'multiplied' by all of the various buildings and their image_maps.
BTW, I have added 3 more 'window images' to me collection-- now at 37!
Download 'buildings_comp_10_6_20.jpg' (757 KB)
Preview of image 'buildings_comp_10_6_20.jpg'
Date: 7 Oct 2020 02:31:06
Message: <5f7d60aa$1@news.povray.org>
Op 07/10/2020 om 05:52 schreef Kenneth:
Very effective indeed.
Date: 18 Oct 2020 16:50:07
Message: <web.5f8caa1c32341a55d98418910@news.povray.org>
SO.. with two basic changes to my code...
1) using arrays for pre-#declaring both the window/building image_maps AND their
window hold-out image_map mattes (for the reflections)
2) switching from an image_pattern to a MUCH-better pigment_pattern syntax per
Ive's suggestion, to now make efficient use of both sets of those image_maps
....the scene parses *much* faster, and uses a fraction of the RAM that it did
previously.
With 30,000 buildings(!) plus probably 200,000+ roof-top greebles, RAM use is
down to 3.7GB. I could probably run 100,000 buildings now before disk-swapping
would occur.
With these changes, I've discovered that the greebles consume 3/4 of the memory
use! That was a surprise; I obviously need to make them more efficient.
Here's the 30,000-buildings render, just as an exercise in absurdity ;-P I'm
still adjusting the lighting.
But my ultimate plan is to make an animated fly-over of the city...so the more
buildings, the better.
Download 'buildings_30000.jpg' (669 KB)
Preview of image 'buildings_30000.jpg'
