POV-Ray : Newsgroups : povray.binaries.images : Mesh leg bones Server Time
24 Mar 2026 09:05:57 EDT (-0400)
  Mesh leg bones (Message 23 to 32 of 32)
Subject: Re: Mesh leg bones
Date: 12 Aug 2013 15:30:00
Message: <web.5209372f975c0a2fd9fa81c30@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> On 12/08/2013 7:47 PM, Stephen wrote:
> > And remove the one from the line above.
> #local INT = difference {
> object {  Tibia }
> plane {y, Level*Slice  }
> plane {y, (Level+1)*Slice inverse}
> Regards
>      Stephen
Sorry Stephen,
but as ever I was to inaccurate. That was the thing I had in my mind...
Please forgive me,
Michael
Date: 12 Aug 2013 16:00:24
Message: <52093ed8$1@news.povray.org>
On 12/08/2013 8:27 PM, MichaelJF wrote:
> Please forgive me,
Nope! I won't :-P
Nothing to forgive. ;-)
Regards
Date: 12 Aug 2013 17:08:30
Message: <52094ece$1@news.povray.org>
> object {  Tibia }
If you want all your slices to have the same thickness, you should add
the +1 after the multiplication.
plane {y, (Level*Slice)+1 inverse}
Otherwise, Slice=0 will be zero thickness, Slice=1 be 1 unit thick,
Slice=2 be 2 units thick...
Date: 12 Aug 2013 21:25:07
Message: <web.52098a22975c0a2f73fc9ebb0@news.povray.org>
The way I read an interpret my code is that I work from 0 to 100.
0 (Level) * Slice (thickness) = 0
(Level+1)= 0+1 = 1 * Slice = Slice thickness
Next is 1 and 2, 2 and 3, etc.
But then I've been known to have my brain convolute in upon itself like a
Gordian knot..
What you propose seems to me to actually produce the zero-thickness slices
you're warning about.  But I will try it.
What makes me think my code is ok, is that when I ran some "wrong" code that
DIDN'T use the plane intersection the way I thought, I got a nice blue and green
bone with the layers stacked in the y direction.  So clearly I was getting SOME
kind of actual thickness...  So much unraveling to do.
Date: 12 Aug 2013 21:35:01
Message: <web.52098c53975c0a2f73fc9ebb0@news.povray.org>
Switching the placement of the inverse statement did the trick.
{whew!}
Thanks, sometimes these simple things really tie me up for far longer than they
ought to.
I need to develop a suite of "noobie tools" to help visualize these things
better.
Transparent spheres for blobs, transparent halves of planes, lines from light
locations to point at coordinates, etc.
Then I can turn on "hand-holding mode" while I create my scenes, and then turn
it off for the final render.
Oy.  What would I do without you guys?
Many thanks as always!
Date: 13 Aug 2013 01:59:37
Message: <5209cb49$1@news.povray.org>
Am 13.08.2013 03:21, schrieb Bald Eagle:
> Gordian knot..
 From what I see, Alain must have misinterpreted your code. With "Slice"
being the slice thickness, you're doing it right.
Date: 13 Aug 2013 03:13:49
Message: <5209dcad$1@news.povray.org>
> ought to.
Sounds familiar. Been there, done that ;-)
Date: 13 Aug 2013 07:19:43
Message: <520a164f@news.povray.org>
   I'm considering building a new home there, as I expend more time
there than here... :)
Jaime
Date: 13 Aug 2013 13:20:01
Message: <web.520a6a2a975c0a2f73fc9ebb0@news.povray.org>
Yeah, between the missing curly braces, missing end statements, confusing x, y,
and z, bouncing between different world coordinate systems, and general noob
stoopid moves like wondering why I can't see my object with thickness zero...
POV-Ray therapy group, anyone?
Anyway - one step closer to the goal.
Download 'bone_rotate.png' (16 KB)
Preview of image 'bone_rotate.png'
Date: 13 Aug 2013 14:20:20
Message: <520a78e4@news.povray.org>
There is a waiting list. ;-)
Regards
