POV-Ray : Newsgroups : povray.binaries.images : The Orthographic Decapitation Server Time
27 Oct 2025 13:11:56 EDT (-0400)
  The Orthographic Decapitation (Message 1 to 10 of 26)
Subject: The Orthographic Decapitation
Date: 12 Dec 2012 09:00:02
Message: <web.50c88d26cb32d3e47b8a80e0@news.povray.org>
Hi. I was starting to experiment with the use of povray to make a single-image
sprite sheet.  It would of course be useful to make it using an orthographic
camera.  But my figures are getting cut off.   Is there a way around this?
TIA.
Download 'stylesheet0041.png' (617 KB)
Preview of image 'stylesheet0041.png'
Subject: Re: The Orthographic Decapitation
Date: 12 Dec 2012 09:44:50
Message: <50c89862@news.povray.org>
Am 12.12.2012 14:56, schrieb gregjohn:
> TIA.
Move the camera further away, maybe?
Date: 12 Dec 2012 10:25:01
Message: <web.50c8a0d8b526f522ae3cb5160@news.povray.org>
> > TIA.
hmm, no.  It still doesn't want objects in the bottom of the image, even with
the height doubled.
Download 'stylesheet0041.png' (628 KB)
Date: 12 Dec 2012 12:00:01
Message: <web.50c8b6dbb526f522d09d0ca60@news.povray.org>
> > > TIA.
> the height doubled.
Did you actually move the camera away? Or did you just mess with its angle,
right/up vectors or scaling? Moving the camera away should be doing the trick,
unless your objects are still inhabiting the camera's location. You might want
to try something like this: location <0, .5, -1>*1000
Sam
Date: 12 Dec 2012 12:45:01
Message: <web.50c8c187b526f52247b8a80e0@news.povray.org>
> > > > TIA.
> > the height doubled.
> Sam
No, I actually doubled it (but at the same time moved new figures closer to the
bottom.
Will post code at p.g.
Date: 12 Dec 2012 13:34:29
Message: <50c8ce35$1@news.povray.org>
Am 12.12.2012 18:40, schrieb gregjohn:
>> Sam
> bottom.
That was the mistake: At the same time as doubling the distance to the
coordinate origin, you also doubled the viewport and scene dimensions.
So while the camera now doesn't cut off the heads of the old population,
you have moved new figures into the region where heads are being cut pff
/now/.
/Only/ increase the camera's distance, leave the viewport size
unchanged, and don't add new people.
The whole reason for this effect is that the camera must shoot its rays
from /somewhere/ - infinity won't work, as it's not a good value to do
math on ;-). So the rays are shot from the plane going through the
camera position and being perpendicular to the camera direction. If one
of your figures sticks its head through this plane, the camera rays will
hit (and thus see) only his inside, effectively decapitating him.
Date: 15 Dec 2012 13:40:01
Message: <web.50ccc39bb526f5225474b7bd0@news.povray.org>
clipka <ano### [at] anonymousorg> wrote:>
Thanks for the articulate explanation.  I still think the diagrams in the povray
camera docs drive me crazy: when I eventually figure out how to do some new
trick, it seems it was after I left a blind alley I was led to from my
presumptions about the picture of the angles, etc.
Anyway, this was an idea I saw at StackOverflow for sprites.  And this is the
one case where povray knocks all other apps flat for being able to make a bunch
of sprites at once.
Download 'orthocam093_600.png' (375 KB)
Preview of image 'orthocam093_600.png'
Date: 15 Dec 2012 14:55:01
Message: <web.50ccd4c2b526f5228c12479d0@news.povray.org>
> > TIA.
Moving away an orthographic camera? What should be achieved from this?
Best regards,
michael
Date: 15 Dec 2012 15:15:00
Message: <web.50ccda15b526f5228c12479d0@news.povray.org>
> of sprites at once.
Moving away an orthographic camera usually yields nothing since the camera is
orthographic.
That is the nature of an orthographic camera.
You must fit your scene into the orthographic view.
Best regards,
michael
Date: 15 Dec 2012 15:32:29
Message: <50ccde5d@news.povray.org>
Am 15.12.2012 20:51, schrieb MichaelJF:
>>> TIA.
Making the figures not getting cut off.
Even in an orthographic render, the camera position determines what you
see: Everything "in front" of the camera is visible, everything "behind"
is not.
