![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The sphere on the left uses diffuse 0.6.
The sphere on the right uses diffuse albedo 0.6.
Does this mean that when we're /not/ using radiosity, we should adjust the
ambient accordingly?
Download 'albedo_radb-montage.png' (167 KB)
Preview of image 'albedo_radb-montage.png'
![albedo_radb-montage.png](/povray.binaries.images/attachment/%3Cweb.4ffa333d160b252f85de7b680%40news.povray.org%3E/albedo_radb-montage.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.07.2012 03:26, schrieb Cousin Ricky:
Something strange is happening there.
Are you using radiosity in the scene?
I didn't think about it when I implemented the albedo for diffuse, but
it won't play nice with radiosity. Because radiosity actually doesn't
support brilliance, and always computes diffuse illumination from other
objects as if the surface had brilliance 1.0.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I am.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there a reason for that, other than speed?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.07.2012 15:39, schrieb Zeger Knaepen:
Yes: Algorithm design, and the simple fact that nobody ever seriously
cared about brilliance in radiosity scenes before.
Radiosity samples only store the level of illumination, but no
information about the direction(s) from which this illumination comes.
But this information is vital for the brilliance feature.
Storing detailed information about the individual illumination intensity
from all the sampled directions is obviously an absolute no-go for
memory reasons.
The issue could be addressed by taking brilliance into account when
averaging the individual illumination intensities for one sample, and
storing the information for which brilliance the sample was taken; the
sample would then not be taken into account for textures with different
brilliance values.
Another possible approach would be to store the illumination intensity
not as a scalar but as spherical harmonics, which is essentially an
efficient way of storing a blurred "image" of the illumination pattern.
This could then be used to compute angle-dependent effects when re-using
a sample rather than at gathering time. As an added benefit this could
then also be used for handling perturbed normals without significant
memory & speed penalty (currently extra samples are taken for this), and
might also significantly improve the quality of cylindrical surfaces at
little extra cost. It's an idea I've already pondered for future
versions of POV-Ray, but I'll have to dive deep into spherical harmonics
math for that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, I did notice a "rubberlike" quality in all radiosity-lit scenes
though, now I know why :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> the
what about having albedo for diffuse ignored if radiosity is used ...
I've ran into this problem as well. Thanks to the OP for bringing this
up, I had forgotten about it working on other higher priority stuff. If
a change is not possible perhaps a "Note" in the docs will suit until a
better idea comes along ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 10.07.2012 13:57, schrieb James Holsenback:
A change is definitely possible; I'll probably go for ignoring the
albedo correction factor only for radiosity computations.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Working on the fix.
Back row: using "diffuse 0.3"
Front row: using "diffuse albedo 0.3"
From left to right: Brilliance 10, 1, 0.1
First image: RC6
Second image: With fix
(Note that this fix will only work with the "albedo" keyword, /not/ a
manually corrected diffuse value using the "VooDoo formula".)
Download 'albedo_radiosity_diffuse_rc6.png' (186 KB)
Download 'albedo_radiosity_diffuse_fix.png' (187 KB)
Preview of image 'albedo_radiosity_diffuse_rc6.png'
![albedo_radiosity_diffuse_rc6.png](/povray.binaries.images/attachment/%3C4ffc22f6%40news.povray.org%3E/albedo_radiosity_diffuse_rc6.png?preview=1)
Preview of image 'albedo_radiosity_diffuse_fix.png'
![albedo_radiosity_diffuse_fix.png](/povray.binaries.images/attachment/%3C4ffc22f6%40news.povray.org%3E/albedo_radiosity_diffuse_fix.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sounds reasonable.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
