POV-Ray : Newsgroups : povray.binaries.images : Diffuse albedo and radiosity Server Time
27 Oct 2025 19:24:15 EDT (-0400)
  Diffuse albedo and radiosity (Message 1 to 10 of 11)
Subject: Diffuse albedo and radiosity
Date: 8 Jul 2012 21:30:00
Message: <web.4ffa333d160b252f85de7b680@news.povray.org>
The sphere on the left uses diffuse 0.6.
The sphere on the right uses diffuse albedo 0.6.
Does this mean that when we're /not/ using radiosity, we should adjust the
ambient accordingly?
Download 'albedo_radb-montage.png' (167 KB)
Preview of image 'albedo_radb-montage.png'
Subject: Re: Diffuse albedo and radiosity
Date: 8 Jul 2012 21:47:51
Message: <4ffa3847$1@news.povray.org>
Am 09.07.2012 03:26, schrieb Cousin Ricky:
Something strange is happening there.
Are you using radiosity in the scene?
I didn't think about it when I implemented the albedo for diffuse, but
it won't play nice with radiosity. Because radiosity actually doesn't
support brilliance, and always computes diffuse illumination from other
objects as if the surface had brilliance 1.0.
Date: 8 Jul 2012 22:10:00
Message: <web.4ffa3cc9e507305985de7b680@news.povray.org>
Yes, I am.
Date: 9 Jul 2012 09:39:37
Message: <4ffadf19$1@news.povray.org>
Is there a reason for that, other than speed?
Date: 9 Jul 2012 11:25:25
Message: <4ffaf7e5$1@news.povray.org>
Am 09.07.2012 15:39, schrieb Zeger Knaepen:
Yes: Algorithm design, and the simple fact that nobody ever seriously
cared about brilliance in radiosity scenes before.
Radiosity samples only store the level of illumination, but no
information about the direction(s) from which this illumination comes.
But this information is vital for the brilliance feature.
Storing detailed information about the individual illumination intensity
from all the sampled directions is obviously an absolute no-go for
memory reasons.
The issue could be addressed by taking brilliance into account when
averaging the individual illumination intensities for one sample, and
storing the information for which brilliance the sample was taken; the
sample would then not be taken into account for textures with different
brilliance values.
Another possible approach would be to store the illumination intensity
not as a scalar but as spherical harmonics, which is essentially an
efficient way of storing a blurred "image" of the illumination pattern.
This could then be used to compute angle-dependent effects when re-using
a sample rather than at gathering time. As an added benefit this could
then also be used for handling perturbed normals without significant
memory & speed penalty (currently extra samples are taken for this), and
might also significantly improve the quality of cylindrical surfaces at
little extra cost. It's an idea I've already pondered for future
versions of POV-Ray, but I'll have to dive deep into spherical harmonics
math for that.
Date: 10 Jul 2012 07:10:58
Message: <4ffc0dc2$1@news.povray.org>
Well, I did notice a "rubberlike" quality in all radiosity-lit scenes
though, now I know why :)
Date: 10 Jul 2012 07:57:36
Message: <4ffc18b0@news.povray.org>
>> the
what about having albedo for diffuse ignored if radiosity is used ...
I've ran into this problem  as well. Thanks to the OP for bringing this
up, I had forgotten about it working on other higher priority stuff. If
a change is not possible perhaps a "Note" in the docs will suit until a
better idea comes along ;-)
Date: 10 Jul 2012 08:06:26
Message: <4ffc1ac2$1@news.povray.org>
Am 10.07.2012 13:57, schrieb James Holsenback:
A change is definitely possible; I'll probably go for ignoring the
albedo correction factor only for radiosity computations.
Date: 10 Jul 2012 08:41:26
Message: <4ffc22f6@news.povray.org>
Working on the fix.
Back row: using "diffuse 0.3"
Front row: using "diffuse albedo 0.3"
 From left to right: Brilliance 10, 1, 0.1
First image: RC6
Second image: With fix
(Note that this fix will only work with the "albedo" keyword, /not/ a
manually corrected diffuse value using the "VooDoo formula".)
Download 'albedo_radiosity_diffuse_rc6.png' (186 KB) Download 'albedo_radiosity_diffuse_fix.png' (187 KB)
Preview of image 'albedo_radiosity_diffuse_rc6.png'
Preview of image 'albedo_radiosity_diffuse_fix.png'
Date: 10 Jul 2012 16:45:00
Message: <web.4ffc932ae507305985de7b680@news.povray.org>
Sounds reasonable.
