POV-Ray : Newsgroups : povray.binaries.images : weird media artifacts? Server Time
26 Mar 2026 17:47:04 EDT (-0400)
  weird media artifacts? (Message 13 to 22 of 22)
Subject: Re: weird media artifacts?
Date: 28 Feb 2009 01:51:16
Message: <49a8dee4$1@news.povray.org>
Hash: SHA1
Kenneth wrote:
> CShake <cshake+pov### [at] gmailcom> wrote:
>> Thanks, the increased samples with fewer intervals makes a huge
>> difference in render time, I tried this scene first with 30 intervals
>> (ratio 0.5) and minimum 10 samples, then 1 interval with 100 samples and
>> it ran at less than 1/4 the time and produced superior results.
>> Seems like my problem has been fixed!
> Good to hear. (I ran your test code and got the same results you did; but I
> didn't think about the media parameters being at their defaults.)
> Meanwhile, I dug up another problem-scene, just to show off another oddity, that
> may or may not have a similar root cause to the one in the link I posted
> earlier. (I'll have to run it with the latest beta to see if this one is
> solved.) The blue 'couch' is media-filled--emission and absorption media-- with
> an IOR and reflection. The only difference between the two images is the
> scattering-media-filled spotlight in the 2nd image. (A cone is the media
> container, which I made partly visible.)  As you can see, the spotlight doesn't
> really impinge on the couch; but the entire couch goes wacky!
	The first thing I'd try is to increase the max trace level. Then if
it doesn't change anything, remove elements from the couch one by
one starting with the reflection then the IOR.
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkmo3uYACgkQd0kWM4JG3k80wgCeNHnqrzDQ5qru6yPt0XGYcQh3
rIIAniOdN2mI0TGwYzfT6ip2pgH3LJrV
=/Dr0
-----END PGP SIGNATURE-----
Date: 28 Feb 2009 01:55:42
Message: <49a8dfee@news.povray.org>
Hash: SHA1
clipka wrote:
> Alain <ele### [at] netscapenet> wrote:
>> intervals 1 samples 100 is much FASTER than intervals 10 samples 10 or samples
>> 10,10. If you use samples 10, 50 the value after the coma is always ignored when
>> using the default sampling method.
> I never really managed to grasp why the intervals are there in the first
> place...
	Historical reasons and method 1. Until pov 3.1 included, the  only
available method was method 1. In this case, sampling is completely
random inside each interval, but the intervals take into account the
cones of the available spotlights. This was simply a way to force
more samples to be taken inside spotlights than outside. With
adaptive sampling, there is much less need (especially since the
optimal number of intervals is now computed automatically anyway).
		Jerome
iEYEARECAAYFAkmo3+8ACgkQd0kWM4JG3k+yIgCggcZ5VmRw1X9ORSVOJATZ/ecu
/2YAn1/OF7wBSOIV5htpJN7v+pVWwz6O
=6SaJ
Date: 28 Feb 2009 04:30:01
Message: <web.49a901ac7ce87223f50167bc0@news.povray.org>
I had not actually worked with this particular scene in awhile, but I started
thinking about it after posting my image. Before reading your suggestions, I
did indeed try turning off reflection and IOR in the couch--which helped
tremendously. (Max_trace_level is OK, BTW.) I also removed the cone object and
its media, so the only thing remaining is the spotlight. There's still some
kind of flaw where the spotlight 'cone' passes between the camera and the
couch. I'm thinking it's a transparency-related issue (the couch's
partial transparency) coupled with the spotlight. Or else it's related to the
couch's media interacting with the light. (And as far as I can remember,
spotlights and cylinder lights do have an intrinsic problem of their own; I
posted something about that long ago.)
KW
Download 'reworked_problem.jpg' (45 KB)
Preview of image 'reworked_problem.jpg'
Date: 28 Feb 2009 05:15:01
Message: <web.49a90e6f7ce87223f50167bc0@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> There's still some kind of flaw where the spotlight 'cone' passes between the
> camera and the couch.
I'm happy to report that I've just found a solution! (This scene has been
bugging me for *way* too long.)
By turning OFF the spotlight's media_interaction, it solved everything! Even
with the couch's IOR and reflection turned back ON, and with (or without) the
media-filled cone object surrounding the spotlight!  Of course, the light no
longer illuminates it's own media; but right now, that's a small price to pay.
Why media_interaction should have any effect, I have no idea. Neither the
spotlight nor its cone object even touch the media-filled couch.
But I'm not complaining!  :-)
Ken W.
Date: 28 Feb 2009 07:30:00
Message: <web.49a92d417ce87223e41007250@news.povray.org>
> solved.)
Do so. From the looks of it, I definitely expect it to have the same root cause.
Date: 28 Feb 2009 07:30:01
Message: <web.49a92e3a7ce87223e41007250@news.povray.org>
A bad max trace level gives you "blackouts", but never "boosts" colors.
From what I saw in the earlier posts, my first guess is that the reason is some
transformations gone wild, messing up calculations of distance within the
media. Quite definitely a POV internal error, not a problem with the scene.
And, as already mentioned, probably fixed already.
Date: 28 Feb 2009 11:05:14
Message: <49a960ba@news.povray.org>
Hash: SHA1
	Not exactly: a bad max trace level gives you pixels with the
background colour. It all depends on what that colour is, but if it
had been set to cyan, it could cause this effect.
	Well, a POV internal error would be my first guess too, but that
doesn't tell Kenneth how to work around it in this scene...
		Jerome
iEYEARECAAYFAkmpYLsACgkQd0kWM4JG3k9JyACeOxOKdlhHhyVLimCyyn8OUiOl
YcMAoKV06LkUOF+tEJEEH9Ja892OT0nX
=t7cv
Date: 28 Feb 2009 13:05:01
Message: <web.49a97c897ce87223e41007250@news.povray.org>
Um... well, yeah, you're right. How often do you set your background color to
cyan though? ;)
I think it does: Use POV 3.7 instead :P
(Yeah, you're right though; admittedly I'm seeing this more from a developer's
perspective, not the user's one...)
Date: 28 Feb 2009 18:50:00
Message: <web.49a9cd257ce87223f50167bc0@news.povray.org>
That's OK!  Keep those good comments and suggestions coming.
KW
Date: 1 Mar 2009 17:32:11
Message: <49ab0ceb$1@news.povray.org>
clipka nous illumina en ce 2009-02-27 19:38 -->
> place...
They are usefull when using sampling method 1 and 2. Useless, time consuming,
and can cause some artefacts with the default method 3. Method 3 is the default
since version 3.5. Before that, only method 1 was available.
Also, the syntax "samples Value1, Value2" is a left over of method 1 and 2. With
method 3, Value2 is always ignored.
Now, samples must be set to at least 3.
intervals default's to 1, and should be left alone.
A true friend is someone who reaches for your hand and touches your heart.
