POV-Ray : Newsgroups : povray.binaries.images : Bathtub - take 2 Server Time
23 Mar 2026 10:28:12 EDT (-0400)
  Bathtub - take 2 (Message 36 to 45 of 65)
Subject: Re: Bathtub - take 2
Date: 20 Dec 2008 10:55:01
Message: <web.494d14796655db18b4cbed3d0@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> The actual water (as a heightfield as in the renders):
> -tgq
Big enough to see the tile is starting to swirl like the outdoor pool image.
I am scaling the tile to get an approx 0.4 to 1 tile size (eyeballed), but that
scales the grout also. It's boggling.
This pool has a depth of 60; I wanted to see how far down the wall could be
seen. The outdoor pool looked like 3.5 feet. (about 10 for Lego ppl)
Tile scaling needs ... ? doh!
#declare tileplaid =
    pigment { uv_mapping
      gradient x
      pigment_map{
        [1/7 rgb 1][1/7 gradient y
          colour_map{
            [1/7 rgb 1]
            [1/7 rgb <.6,.6,1> ]
      scale <1/160,1/20,1>*.7
    finish { basic_finish }
#declare pool_box =
difference {
    box { <-16, -66.5, -16> <224, 0, 224> } // legoworld hole
    box { <-8, -60, -8> <216, 1, 216> }
    texture { tileplaid }
Many thanks go to Professor Trevor G Quayle.
Thank you, this is great water.
(have yet to discover what went wrong with 1st poolwater)
Beginning to look like "outdoor-pool-image" could be achieved.
Download 'legoworld_pool2test.png' (529 KB)
Preview of image 'legoworld_pool2test.png'
Date: 20 Dec 2008 11:30:00
Message: <web.494d1d1f6655db18c67b294d0@news.povray.org>
> texture {
>       gradient x
>       pigment_map{
>           colour_map{
>             [1/7 rgb 1]
The 1/7 value is the grout width value. The tile is 6/7 units and the grout is
1/7 units.
Use declare and math to adust tile/grout sizes:
#declare TilSiz= <xdim,ydim,0>;  //tile offsetting (tile size plus grout line)
#declare GrtSiz= gwid; //grout width
      gradient x
      pigment_map{
        [GrtSiz/(TilSiz.x+GrtSiz) rgb 1]
        [GrtSiz/(TilSiz.x+GrtSiz) gradient y
          colour_map{
            [GrtSiz/(TilSiz.y+GrtSiz) rgb 1]
            [GrtSiz/(TilSiz.y+GrtSiz) rgb <.6,.6,1> ]
      scale TilSiz
This way you can make the tiles bigger (change TilSiz) without changing the
grout size, or vice versa.
-tgq
Date: 20 Dec 2008 14:00:01
Message: <web.494d3fe76655db18b4cbed3d0@news.povray.org>
previously had a lego-floor bottom,
bottom tiled at a depth of 65.
#declare RHIT=0.25;
#declare WHit=0.45;
ripple height
and
wave height
Am I understanding your naming convention? Kinda important to grasping the math
logic.
Ship looks like it sustained damage or landed on the wicked, depraved witch.
Download 'lego_pool.png' (537 KB)
Preview of image 'lego_pool.png'
Date: 20 Dec 2008 15:40:01
Message: <web.494d57626655db18c67b294d0@news.povray.org>
> #declare RHIT=0.25;
> #declare WHit=0.45;
> ripple height
> and
> wave height
> logic.
OK, my original water pattern was just thrown together using some previously
developed code so it wasn't commented or named with consistency.  I have
reworked it with better naming conventions and commenting and have also
optimizified the code somewhat.  Note that the dimensions used for the declared
values (PoolSiz, PoolDep, WavHt, WavSpac, RipHt, RipSpac) correspond to the
final scene level dimensions for ease of use.
//START
#declare PoolSiz=216+8; //length of pool sides (square)
#declare PoolDep=75;    //depth of pool
#declare WavHt=0.45;    //height of waves
#declare WavSpac=30;    //spacing of waves
#declare RipHt=0.25;    //height of ripples (pool sides)
#declare RipSpac=4;     //spacing of ripples
#declare TotDep=PoolDep+WavHt+RipHt; //total water depth
#declare FWav1 = //wave function
function{
  pigment{
    marble frequency PoolSiz/WavSpac sine_wave
    scale 1/5
    warp{turbulence 1.5}
    scale 5
    warp{turbulence 0.5}
#local FWav2 = function {FWav1(x,y,z).gray*0.5+FWav1(y,x,z).gray*0.5} //wave
function 2
#local FRip1 =  //ripple function
function {
  pigment{
    function{pow(max(min(abs(x*2-1),1)-0.5,0)/(1-0.5),3)}
    pigment_map{
      [0.0 rgb 0]
      [1.0 marble frequency PoolSiz/RipSpac sine_wave]
    scale 1/5
    warp{turbulence 0.05*x}
    scale 5
#local FRip2 = function {FRip1(x,y,z).gray*0.5+FRip1(y,x,z).gray*0.5}  //ripple
function 2
#declare WHt=WavHt/TotDep; //relative depth of waves (% total depth)
#declare RHt=RipHt/TotDep; //relative depth of ripples (% total depth)
#local FWat = function {FWav2(x,y,z)*WHt+FRip2(x,y,z)*RHt+(1-WHt-RHt)}  //water
surface function
#declare WatHF=  //water heightfield
height_field{
  function 600,600 {pattern{function{FWat(x,y,z)}}}
  smooth
  hollow
  scale <PoolSiz,TotDep,PoolSiz>
#declare WatCol=rgb <0.51373, 0.70588, 0.70588>; //Water colour
#local FadeDis=-60/ln(0.58);                     //fade distance
#declare MWater= //water material
  material{
    texture{
      pigment{rgbt 1}
      finish{conserve_energy  diffuse 0.0  ambient 0  reflection{0 1 fresnel on
metallic 0}}
    interior{
      ior 1.33
      media{
        absorption rgb 1-WatCol //coastal
        density{rgb 1/FadeDis}
// water
object{WatHF translate <-8,-76,-8> hollow material { MWater translate
<-10,0,-10>}}
//END
-tgq
Date: 20 Dec 2008 16:25:01
Message: <web.494d61676655db18b4cbed3d0@news.povray.org>
> 1/7 units.
> texture {
>       gradient x
>       pigment_map{
>           colour_map{
>       scale TilSiz
> -tgq
when you said "The 1/7 value is the grout width value." , a light sort of went
on ... but there is y grout and and x grout.
the math for the correct y-grout-[scale] due to y-scaling is ... ? puzzling
 ".5" value which I guessed at, since it looked 2 times too big.
In the real Lego world this is what worked:
#declare TilSiz= <6/7,12/7,1>;  //tile offsetting (tile size plus grout line)
#declare GrtSiz= 1/7; //grout width
//0.142857
echof(GrtSiz/(TilSiz.x+GrtSiz))     // 0.14286
cr()
echof(GrtSiz/(TilSiz.y+GrtSiz))     // 0.07143
cr()
#if (10)
      gradient x
      pigment_map{
          colour_map{
      //scale TilSiz*.01
#else
      gradient x
      pigment_map{
        [1/7 rgb 1]
        [1/7 gradient y
          colour_map{
            [(1/7)*.5 rgb 1]
            [(1/7)*.5 rgb <.6,.6,1> ]
      scale <1/160,1/20,1>*.7 // ==  0.00625 / .05 = 0.125 1/8
} #end
still had to scale by something else not TilSiz
scale by TilSiz = a grout line half the pool's width and tiles with a greater
xdim
Download 'lego_pool2.png' (169 KB)
Preview of image 'lego_pool2.png'
Date: 20 Dec 2008 17:45:01
Message: <web.494d74666655db18c67b294d0@news.povray.org>
> //0.142857
> cr()
> cr()
> #if (10)
> texture {
>       gradient x
>       pigment_map{
>           colour_map{
>       //scale TilSiz*.01
> #else
> texture {
>       gradient x
>       pigment_map{
>         [1/7 rgb 1]
>         [1/7 gradient y
>           colour_map{
>             [(1/7)*.5 rgb 1]
> } #end
> xdim
x grout and y grout should be handled just fine the way I showed, as long as you
want it the same tickness for both.
I'm not sure how you are applying the texture, but it's likely the uv mapping
that is causing you an issue as the pattern is not getting scaled as expected
(or rather as wanted...).  The scale you are using is 1/160 x 1/20 which is an
8:1 ratio, whereas you are getting the pattern to work by misscaling by a 2:1
ratio.  You need to determine how the uv mapping is effecting the pattern and
scale both the x/y of the tiles and have a separate x&y grout scaling that is
based on the proportional scaling that the uv mapping is applying.
-tgq
Date: 20 Dec 2008 18:15:00
Message: <web.494d7c296655db18b4cbed3d0@news.povray.org>
texture applied like any other ...
      gradient x
      pigment_map{
          colour_map{
            [(1/7)*.5 rgb 1]
#declare pool_box =
difference {
    box { <-8, -66.5, -8> <232, 0, 232> } // legoworld hole
    box { <0, -65, 0> <224, 1, 224> }
    translate <-8,0,-8>
union {
object { pool_box }
object { TQ_water2 }
object { beachball scale 8.5 rotate z*45 rotate y*-55 translate <30,6.5,55> }
translate y*4
You have been such a fantasic source on this, didn't mean to derail your thread.
I could see someone had a clue on water.
That is the code, 2:1 and 8:1, that made the image which all speaks for itself:
I never expect perfection, but expect imperfection that is for me to... enhance.
I hesitate to say perfect.
Date: 20 Dec 2008 18:50:01
Message: <web.494d83ba6655db18c67b294d0@news.povray.org>
> texture {
>       gradient x
>       pigment_map{
>           colour_map{
>             [(1/7)*.5 rgb 1]
> #declare pool_box =
> difference {
>     translate <-8,0,-8>
> union {
> object { pool_box }
> translate y*4
Not a problem. I always like to help.  (Unfortunatly my real work suffers when I
get preoccupied elsewhere...)
If you know the size of the pool box, then refer to uv_mapping in the docs to
see how it gets applied.  You should be able to work out the proportions and
mathematics from that.  I may do some more playing with it later when I get a
chance.
"3.5.7.1  Supported Objects"
This section shows how the texture gets sampled and applied to a box object.
-tgq
Date: 20 Dec 2008 21:38:43
Message: <op.umhqyg0e6b35ac@your-727a0a4e7c.vipowernet.net>
> "Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote:
> > I am not entirely sure if this function is really natural to a
> bathtube or
> > any confined water surface, up to a certain scale.
> I'd love to see someone find something better than f_ridge for the Lego
> pool.
I don't know what your criteria are for the Lego pool, but I'm sure
someone can do better than both f_ridged_mf() and f_ridged().  Please find
attached isocolor and shaded relief illustrations of these functions.
They are:
   - waves-ridge1.jpg - f_ridged_mf() as Christoph used it;
   - waves-ridge2.jpg - Christoph's usage as I modified it;
   - waves-ridge3.jpg - f_ridge() as alphaQuad used it.
They don't exactly look like water waves from this angle.
These function calls appear to be the sort of tool that does its job well
 from certain perspective--namely, water waves at typical viewing
angles--but are hardly general solutions.
> I doubt anyone can.
Very fragile generalization.
<Insert witty .sig here>
Download 'waves-ridge1.jpg' (104 KB) Download 'waves-ridge2.jpg' (122 KB) Download 'waves-ridge3.jpg' (72 KB)
Preview of image 'waves-ridge1.jpg'
Preview of image 'waves-ridge2.jpg'
Preview of image 'waves-ridge3.jpg'
Date: 20 Dec 2008 21:50:00
Message: <web.494dae6c6655db18c67b294d0@news.povray.org>
> chance.
> -tgq
OK this took a little work, but should take the guesswork out of tiling the
pool.  I've added a few tricks to this as well.  The uvmapping you were using
can be adapted to a square shape pool, but if you were to change to a
rectangular shape, it would cause big problems.  This pattern will avoid this
and let you have reactangular pools with a consistent tile size and grout size.
 You'll also noticed that I offset the grouting by half its size and added a
half grout to the opposite side so the each full tile rectangle is bounded on
all sides by a half width of grout.  This makes it work nice at the edges so
that the tile is not butting the edges, but rather grout.  Each individual
x/y/z plane pattern is sized independently and then added to the areas
corresponding to the uv mapping of the box.  Next step will be to make it as a
single pattern...
-tgq
//START
#declare BSiz=<20,6,10>;  //Size of box
#declare TilSiz=<2,1>;    //Size of tile (x,y)
#declare Grt=0.1;         //Width of grout
#declare TilCol=rgb 0;  //Tile colour
#declare GrtCol=rgb 1;  // Grout colour
#declare DimX=Grt/TilSiz.u; //Grout scaling x
#declare DimY=Grt/TilSiz.v; //Grout scaling y
#declare DimZ=Grt/TilSiz.v; //Grout scaling z
#declare PX=pigment{  //Tile pattern x plane
      gradient x
      pigment_map{
        [  DimZ/2 GrtCol]
        [  DimZ/2 gradient y colour_map{[DimY/2 GrtCol][DimY/2 TilCol][1-DimY/2
TilCol][1-DimY/2 GrtCol]}]
        [1-DimZ/2 gradient y colour_map{[DimY/2 GrtCol][DimY/2 TilCol][1-DimY/2
        [1-DimZ/2 GrtCol]
      scale <TilSiz.u/BSiz.z/4,TilSiz.v/BSiz.y/3>
#declare PY=pigment{  //Tile pattern y plane
      gradient x
      pigment_map{
        [  DimX/2 GrtCol]
        [  DimX/2 gradient y colour_map{[DimZ/2 GrtCol][DimZ/2 TilCol][1-DimZ/2
TilCol][1-DimZ/2 GrtCol]}]
        [1-DimX/2 gradient y colour_map{[DimZ/2 GrtCol][DimZ/2 TilCol][1-DimZ/2
        [1-DimX/2 GrtCol]
      scale <TilSiz.u/BSiz.x/4,TilSiz.v/BSiz.z/3>
#declare PZ=pigment{  //Tile pattern y plane
      gradient x
      pigment_map{
        [  DimX/2 GrtCol]
        [  DimX/2 gradient y colour_map{[DimY/2 GrtCol][DimY/2 TilCol][1-DimY/2
        [1-DimX/2 gradient y colour_map{[DimY/2 GrtCol][DimY/2 TilCol][1-DimY/2
        [1-DimX/2 GrtCol]
      scale <TilSiz.u/BSiz.x/4,TilSiz.v/BSiz.y/3>
#declare BoxUV= //Tile pattern for uv box
  pigment{
    uv_mapping
    gradient x
    pigment_map{
      [1/4 PX]  //Xmin
      [1/4 gradient y pigment_map{
                                  [1/3 PY]  //Ymin
                                  [1/3 PZ]  //Zmax
                                  [2/3 PZ]  //Zmax
                                  [2/3 PY]  //Ymax
      [2/4 gradient y pigment_map{
                                  [1/3 PY]  //Ymin
                                  [1/3 PZ]  //Zmax
                                  [2/3 PZ]  //Zmax
                                  [2/3 PY]  //Ymax
      [2/4 PX]  //Xmax
      [3/4 PX]  //Xmax
      [3/4 PZ]  //Zmin
box{0, BSiz pigment{BoxUV}}
//END
